Results 1 to 3 of 3
  1. #1
    Junior Member Achievements:
    500 Experience Points 250 Experience Points 1 year registered 100 Experience Points 3 months registered
    1879
    Aug 2010
    Generic Flytouch problem
    My power button doesn't work at all. I got one for my birthday the other day, I've had nothing but problems with it.. Yesterday it seemed fine after I flashed the firmware but about 20 minutes into messing with it the screen went black and the unit was unresponsive. I let the battery die hoping that would turn it off so I could just turn it on, now whenever I plug it in my battery charges but the power button is unresponsive. It took me 3 days to figure out what kind of tablet it actually was. (the chinese seller said it was an iRobot but looks almost exactly like this: DealExtreme: $104.90 7" Touch Screen TFT LCD Google Android 1.6 Tablet PC w/ WiFi/Camera (VIA WM8505 ARM926) except with a silver backing.) I really need help with this, the ebay seller said it was warrantied.. then told me the warranty only means I can pay to send it back and then pay to have it fixed.
    Ads
  3. #2
    1879
    Aug 2010
    is there anyway of opening the unit and disconnecting the battery or doing a hard reset or anything?
  4. #3
    Developer
    Achievements:
    50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 5,000 Experience Points 1,000 Experience Points
    1423
    Aug 2010
    USA
    1,505
    Thanked
    109 times
    COBY KYROS 7015 | 7015A
    This unit can be opened up. Since the bottom is all plastic you would open it from the top and push in all the buttons so the top panel can lift up. Make sure you unplug the power cord. I do recommend you connect the power cord directly into wall socket AC. Do not use strip with it. Strange enough to me it works better that way. Poor AC PSU units are crap. Don't listen to that ebay seller.
    No matter what I do the power can't drain 100% still 5% in there. Strange.
    PowerCode 1000 DCX
    Coby Kyros 7012, 7015, 7015a, 7016, 7022, 7042, 7125, 7126, 7127, 8125, 8126, 8127, 9742, 1042, 1125, 1126 (Gingerbread, Ice Cream Sandwich, Jelly Bean)
    Skytex Skypad Alpha, Gemini (Ice Cream Sandwich)
    Visual Land Connect, Prestige Ice Cream Sandwich)
    45x Tablets Owned/Tested/Configured/Tweaked/GUI: Running OS: 1.6, 2.0, 2.1, 2.2, 2.3, 3.0, 4.0, 4.1 | Since 2010
Ads:
  1. [ROM] Gome Flytouch Firmware Releases (VIA8505 7" Tablet)
    By xaueious in forum Gome Flytouch Firmware
    Last Post: 03-08-2013, 01:44 PM
  2. Replies: 35
    Last Post: 04-18-2012, 03:48 AM
Flytouch hard reset
factort reset fail on flytouch
fly force 1.6 android tablet
flytouch 3 wifi problem
flytouch 8 problems
flytouch 8 reset
flytouch problem
generic tablet problem
hard reset flytouch
hard reset gome flytouch 2
how to haed reset an anfriod flytouch 8
how to reset flytouch
