Results 1 to 6 of 6
  1. #1
    Junior Member Achievements:
    7952
    Dec 2010
    Question WiFi connection does not connect
    Hello everyone.
    I bought two pieces of a WMT2.1_105 tablet. After some research I found some roms that are working fine. But one of them is having a problem with WiFi.
    I didn't find any answer to my question, and I decided to come here to ask for some help.
    Here's the problem.
    When I try to connect to any network, the tablet take like 5 seconds and WiFi disconnect. The tablets are the same model, one is working, the other dont. I tried every ROM and always get same error. Tried to change my security and didn't work too. Tried factory reset.
    The tablet can see the existing networks, including if I put the wrong pass, it says that the pass is wrong. But still not conecting any way. I tried the WiFi Buddy app too, but the same thing happens, can see the networks, but no connect to.
    Im losing my hope that it can be repaired. At least w/o send it back to China...
    If someone had this problem, or know any chances to fix, please, let me know.
    Thank you guys.
    BTW this forum is amazing, good job.
    Ads
  3. #2
    Super Moderator Achievements:
    10,000 Experience Points 5,000 Experience Points 1,000 Experience Points 500 Experience Points 250 Experience Points
    1530
    Aug 2010
    Near 39.11N 94.6W
    1,464
    Thanked
    128 times
    There was a person about 2 months ago with a similar problem. One person suggested popping the case to adjust the antenna. In your case, I think it is the network chip and not just the antenna. They could at least connect when right next to the AP. Yours sounds like it never connects. The QA is pretty quick with the low price tabs. So I bet the chip is both functional and defective. It could be a simple solder connection issue to the antenna. So the network chip is functional, it just has no signal capture strength. To check this, Do you even see the connection points/APs. If so, then it is not the antenna connection but something specific to the board interface.
    Bottom line, I think the only fix is a return. You sound like you have done all the other appropriate diags and steps to take. Sorry for your bad luck on this unit
    gurgle Tech stooge of the Internet
    Tablets Currently in Possession -Partial List
    MS --Fujitsu Stylistic LT TabletPC-Win98 / HP4400-W7U / Samsung Q1U- XPPro/V-Ult/Archos 9
    Android -- WItS A81E/ Archos 5/500 Archos 7HT/Archos 101/16/Asus Transformer 10.1/32 / G1
    Remember-If You do not open it, you do not Own it
  4. #3
    Developer
    Achievements:
    50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 5,000 Experience Points 1,000 Experience Points
    1423
    Aug 2010
    USA
    1,505
    Thanked
    109 times
    COBY KYROS 7015 | 7015A
    There is a code to boost the Wifi but that's in my newer ROMs here.
    PowerCode 1000 DCX
    Coby Kyros 7012, 7015, 7015a, 7016, 7022, 7042, 7125, 7126, 7127, 8125, 8126, 8127, 9742, 1042, 1125, 1126 (Gingerbread, Ice Cream Sandwich, Jelly Bean)
    Skytex Skypad Alpha, Gemini (Ice Cream Sandwich)
    Visual Land Connect, Prestige Ice Cream Sandwich)
    45x Tablets Owned/Tested/Configured/Tweaked/GUI: Running OS: 1.6, 2.0, 2.1, 2.2, 2.3, 3.0, 4.0, 4.1 | Since 2010
  5. #4
    48550
    Aug 2011
    east sussex
    android mid 2.1 tablet
    Hi can anyone help me i have been happily using my android 2.1 tablet for some time now but all of a sudden it will not connect to the internet. It still says that i am connected to my wifi and that i have a signal yet everytime i try to access the internet it says page unavailable. My daughter has taken it and tried it on her wifi it is connected and giving strong signal but still will not connect to internet. i will be grateful for any help. Thanks
  6. #5
    52613
    Sep 2011
    Rockford Il.
    Nextbook Android Tablet
    Having the same problem with mine, I just got it today, I'm taking it back!!!
  7. #6
    50044
    Sep 2011
    Katanning
    flytouch3
    Try changing your wifi settings on your router from wpa to wep, less secure apparently but at least it works. It took me days to figure this out, never had any trouble since
    Sent from my DISCO10 using Android Tablet Forum
Ads:
  1. 10.2" android 2.1 i can't connect via wifi
    By danezu1925 in forum Gome Flytouch II
    Last Post: 02-13-2012, 04:31 PM
  2. Can't connect to wifi overseas
    By jim harvest in forum Telechips TCC8902 Tablets
    Last Post: 12-02-2010, 10:10 AM
  3. Please Help with USB connection to PC
    By Rich6510 in forum Android Tablet Q&A
    Last Post: 11-20-2010, 10:01 AM
  4. Apad Rockchip WiFi keeps dropping internet connection.
    By clu55ter in forum Rockchip RK2808 Tablets
    Last Post: 09-17-2010, 10:36 AM
  5. Replies: 0
    Last Post: 09-17-2010, 08:52 AM
Tablet will not connect to wifi
my microsoft tablet wont connect to the wifi correctly
my rca tablet wont connect to wifi
rca tablet not connecting to wifi
rca tablet says connected but cant do anything
rca tablet wifi not working
rca tablet wifi wont turn on
rca tablet will not connect to wifi
why won,t my rca 7 tablet connect to the internet
why wont my rca tablet connect to wifi
Tags for this Thread
