Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 73
Thanks Tree2Thanks
Thread: Huawei S7 - connecting USB external hard disc or flash memory
  1. #1
    Junior Member Achievements:
    8874
    Dec 2010
    Hi,
    Is it possible to connect to Huawei S7 external USB memory (expl. WD passport 320GB)? Should I look for some adapter for USB port?
    Thank you!
    Justas
    Ads
  3. #2
    8876
    Dec 2010
    Thanked
    1 times
    Wired i am not sure as i dont own one, but through wifi it should be possible, connect to yr pc, (wired or wireless) or to yr router (or nas directly) through wifi, and look up yr hdd.
    alternativlely, mostly you can buy usb connectors for ext HDD's (but as i said.. not sure)
  4. #3
    8874
    Dec 2010
    Thanks Koets. The thing is that I want to have this memory connected to HS7 withought PC. I am planning to travell and I would like to take my films and other stuff with this WD passport 320GB.
    I think it should be possible. I saw in one of the videos that Huawei had a stand for HS7 with USB connections for storage. I do not know if it is commercially available, but that shows possibility. Anyway USB port is in place. the question is only if some adapter is available in shops and if SW can support this.
  5. #4
    1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    8221
    Dec 2010
    Greenbackville, Virginia, USA
    26
    Acer A500
    I read a rumor somewhere that the mini USB port on the S7 MIGHT serve as a host port, with some kind of dongle adapter, breaking out to a USB A female socket. I would love to get some kind of confirmation on this and if so, if the adapters are in the works. That would really make what you want to do easy. Plus, you (and the rest of us) could avoid having to haul a dock with us everywhere we go, just to have the USB host connection.
    I would like to do something similar to what you described, only I would probaly use hi-capacity USB thumb drives in lieu of a full USB backup drive.
    Jason
    RPC Electronics, LLC
    www.rpc-electronics.com
  6. #5
    8874
    Dec 2010
    so nobody tried that or it is not possible?
  7. #6
    Senior Member Achievements:
    1 year registered 500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points
    7784
    Nov 2010
    UK
    365
    Thanked
    38 times
    Huawei S7, Nokia X3-02, Nokia E71
    The sometimes seen docking station shows external USB ports so should support external mass storage, but don't ask me where you get one. The dock is connected via the bottom expansion port.
    Sent from my Ideos S7 using Android Tablet Forum App
    Just *****ing
    The forum even censors my signature!
    http://www.mediafire.com/file/nq5bvz..._trzmod-v3.zip
  8. #7
    500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    7743
    Nov 2010
    Lousiana
    47
    Thanked
    16 times
    Too Many
    No go on USB host. I had an adapter (micro USB to USB host) I used with my Archos 7HT.
    Tablets:
    Huawei S7
    Huawei S7 Slim
    Nook Color
  9. #8
    13206
    Jan 2011
    Bucharest Romania
    Gome Flytouch (camera version)
    I think what you need is this:
    Cabluri tip IPAD to USB - PC-Tablet
    It's used by lots of the chinese tablets. It has a 30 pin connector on one side that goes into the dock connector on the tablet and a USB Female on the other end.
  10. #9
    7784
    Nov 2010
    UK
    365
    Thanked
    38 times
    I have a new Nokia phone which supports USB OTG (On The Go) and allows the phone to be used as a host to enable reading of attached mass storage devices. This includes thumb drives and hard drives (when eternaly powered).
    Unfortunately the S7 does not support this feature and the USB OTG adapter cable will not fit into the micro USB port as the plug configuration is non standard micro USB.
    The bus on the bottom of the S7 does allow this with the correct connector, but, as I said, they are like hen's teeth!
  11. #10
    Points: 10,467, Level: 68
    Level completed: 5%, Points required for next Level: 383
    Overall activity: 7.0%
    Achievements:
    10,000 Experience Points Veteran 5,000 Experience Points 1 year registered 1,000 Experience Points
    16695
    Feb 2011
    Northcoast, OH
    469
    Thanked
    7 times
    Points
    10,467
    Level
    68
    Google Nexus 7-13, 32 Gb
    I would love that too, even if I had to connect an adapter to the dock port. That's because the biggest reason I got a tablet is to capture video or photos while driving in the car, and I don't really like having a laptop with a spinning HDD while bumping down rural roads.
    Tablet responsibly.
    Enjoy Rock Music.
Ads:
  1. Flash vs hard drive
    By Andrewinsa in forum Archos Tablets
    Last Post: 12-14-2010, 01:31 PM
  2. Hard Choice on new tablet - Moonse apad e7002
    By cmolson in forum Android Tablet Discussions
    Last Post: 09-12-2010, 10:46 PM
  3. Hard to choose
    By Pumbkin in forum Android Tablet Discussions
    Last Post: 09-08-2010, 09:15 AM
android tablet not recognize external disc
can external usb keyboard be use on huawei s7 android tablet
can i hook an external hard drive to my huawei ideos s7?
cannot get huawei to recognize external memory device
circuit otg usb
huawei ideos s7 usb
huawei s7 not reading flash drrives
huawei s7 usb flash
ideos s7-104 usb external drive
pin micro usb
pin usb
q5 usb memory manager requeriments
