Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
  1. #1
    Points: 9,462, Level: 65
    Level completed: 38%, Points required for next Level: 188
    Overall activity: 17.0%
    Achievements:
    Veteran 5,000 Experience Points 1 year registered 1,000 Experience Points 500 Experience Points
    16695
    Feb 2011
    Northcoast, OH
    435
    Thanked
    7 times
    Points
    9,462
    Level
    65
    Google Nexus 7-13, 32 Gb
    Auto-Rotation not working
    On my S7 slim, it's not rotating the screen. I have auto-rotate in the Display settings checked on, and the rotation switch in the tasklist is on (lit up/green) also. I think that's how you do it, then you just turn the screen from landscape to portrait or did I miss something or need to reset or calibrate something?
    thx
    Tablet responsibly.
    Rock Music.
    Ads
    Advertising world
  3. #2
    Member Achievements:
    1 year registered 500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points
    30130
    May 2011
    Fort Worth
    89
    Thanked
    2 times
    Acer Iconia a100
    I think there is a software (maybe hardware?) bug. If you reset the device (power off, then on) the slim auto-rotate should work just fine. My slim (and at least 1 other who mentioned it) have this problem as well. Basically, after letting the device fall asleep (when screen turns off) it sometimes gets stuck in the last orientation it was in (either portrait or landscape). I don't know any other way to fix it other than restarting the device. Mine gets stuck about 25-50 percent of the time after falling asleep--which is very annoying.
  4. #3
    Achievements:
    16695
    Feb 2011
    Northcoast, OH
    435
    Thanked
    7 times
    Points
    9,462
    Level
    65
    Mine doesn't rotate at all, but the accelerometer(s) seems to work.
    Have you contacted Huawei about the bug? I see a bunch of annoying things, like it vibrates when it shuts down. They should know about it so they can update the OS, and we can see if the update feature works!
    Not only that bug, but mine hates it when I try to restart it while it's charging. If you get the green battery screen, leave it plugged in, or you'll crash it and have to remove the battery.
    I think I will give them a call on Monday.
    Tablet responsibly.
    Rock Music.
  5. #4
    Junior Member Achievements:
    7 days registered
    45229
    Aug 2011
    Hi
    my slim also doesn't rotate
    when i restarted i have to remove the battery
  6. #5
    Achievements:
    16695
    Feb 2011
    Northcoast, OH
    435
    Thanked
    7 times
    Points
    9,462
    Level
    65
    Sorry, I actually do get the screen to rotate, but I can't get it to rotate back or to rotate it to the orientation I want. I think the one app I was using st the time had a rotate feature, so that is why the screen rotated. Usually the Market app rotates automatically, but it's not working now. I had to uninstall the Market update because it stopped working (AGAIN!) and the previous version doesn't have a rotate feature.
    So as of now, My home screen screen won't rotate, but AFAIK, it worked when I got the device, and I don't want to reinstall every app AGAIN...
    Tablet responsibly.
    Rock Music.
  7. #6
    Points: 3,883, Level: 39
    Level completed: 56%, Points required for next Level: 67
    Overall activity: 11.0%
    Achievements:
    Veteran 1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points
    18030
    Feb 2011
    32
    Thanked
    1 times
    Points
    3,883
    Level
    39
    If you tap the information button in the upper right hand corner of your screen, you should see that the rotation lock is in the off position.
    I have found that with some android devices, this one included, respond to a slight shake if the rotation does not occur quickly enough.
    Sent from my IDEOS S7 Slim using Android Tablet Forum
  8. #7
    Achievements:
    16695
    Feb 2011
    Northcoast, OH
    435
    Thanked
    7 times
    Points
    9,462
    Level
    65
    I don't think that's a 'lock' in the status area, I would call those toggles (WiFi, Bluetooth, GPS, orientation on/off toggles, and a 3-way brightness switch).
    If you set the auto-rotation in the Display settings to on, the toggle will be lit or not, according to the Display setting. But I tried it your way, assuming the toggle was off, without the desired result.
    Is it possible to reset the accellerometers or something like that so the device knows it was shaken or rotated?
    I'm contacting Huawei later (1800-4-HUAWEI)
    Tablet responsibly.
    Rock Music.
  9. #8
    Achievements:
    16695
    Feb 2011
    Northcoast, OH
    435
    Thanked
    7 times
    Points
    9,462
    Level
    65
    I recently learned that the auto-orientation only works under certain conditions.
    You need an application that supports it, like the System settings application or IM+, for example. The home screen on the S7 Slim doesn't change orientation, as it would if you had something like Zeam launcher.
    Tablet responsibly.
    Rock Music.
  10. #9
    3 months registered 250 Experience Points 31 days registered 7 days registered 100 Experience Points
    52203
    Sep 2011
    Hungary
    16
    S7 Slim
    This is a known bug. Try this firmware link. I dont have auto-rotation promlems whit this, unlike other firmwares.
  11. #10
    27654
    Apr 2011
    Brunei
    22
    Huawei ideos S7
    just bought this Huawei S7 Slim few week.
    i have been tested for few firmware, but i still have auto-rotation problem.
    for the begining its working well, after few day or manybe few hours. the auto rotation wont work anymore.
    have to turn off and restart S7 slim , then my auto rotation get back to work.
    make me very piss off.
    do you guy have this issue ? anyway to solve this problem ?
    thank you !!
Ads:
  1. 7022 Screen Rotation not working
    By penecow290 in forum Coby Generation 2
    Last Post: 03-13-2012, 08:48 AM
  2. Rotation Lock Fail
    By romhad in forum Acer Iconia Tab A500 Forum
    Last Post: 07-12-2011, 12:36 PM
  3. MID7015 Rotation Weirdness
    By Dragonblade629 in forum Coby Generation 1
    Last Post: 02-13-2011, 08:29 PM
  4. Is my auto rotation working like yours
    By spb37 in forum Huawei Ideos S7
    Last Post: 01-28-2011, 10:18 PM
  5. Permanent Screen Rotation
    By mmullen in forum Augen Gentouch
    Last Post: 10-09-2010, 12:29 AM
after falling screen rotation not working in android
android rotate not working
android tablet doesn't rotate
android tablet screen doesn't rotate
android tablet wont auto rotate
auto rotate tablet
how do i get screen to rotate on nextbook tablet
in huawei how to set auto rotation
tablet auto rotate not working
tablet not rotating
tablet will not rotate
