Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
  1. #1
    Junior Member Achievements:
    7 days registered
    56352
    Oct 2011
    Germany
    11
    Huawei S7 Slim, Archos 70 250G
    Can't get fastboot to work [SOLVED]
    Hi all,
    I just bought a "Huawei S7 Slim" and wanted to play around with own kernels, but I'm completely stuck already at getting fastboot to work at all. I tried various tipps from this and many other forums already, but everything that seemed to help others still doesn't make it work for me.
    My PC setup:
    - Ubuntu 10.04 LTS, x86_64, latest updates
    - 32-bit fastboot executable
    My S7 Slim:
    - Android 2.2.2, still plain stock as you may guess already
    - Baseband-Version 504030
    - Kernel-Version 2.6.32.9-ideos
    - Build-Number S7-201uV100R001C187B010
    What works:
    - Pressing "volume-" (hold) + "power" (short):
    1. button lights turn on
    2. after a few seconds, device vibrates shortly
    3. button lights turn off
    4. a short shaded bar appears in the middle of the screen
    5. button lights start flashing
    - devices stays like this indefinitely until battery removed, "power" doesn't work
    - PC doesn't recognize device after attaching usb
    - anyone an idea what mode this is?
    - Pressing "volume+" (hold) + "volume-" (hold) + "power" (short):
    4. screen flashes shortly
    5. a long shaded bar appears in the middle of the screen
    - PC recognizes device as 12d1:36de after attaching usb
    What I tried on PC already:
    "lsusb":
    Bus 001 Device 019: ID 12d1:36de Huawei Technologies Co., Ltd.
    => device is there in principle and PC & Linux see it
    "fastboot devices"
    => nothing, initially I thought maybe no usb device or permissions wrong
    "sudo fastboot devices"
    => nothing, so non-root doesn't seem to be a problem
    "strace fastboot devices"
    open("/dev/bus/usb/001/019", O_RDWR|O_LARGEFILE) = 5
    read(5, "\22\1\0\2\0\0\0@\321\22\3366\0\0\3\2\0\1\t\0027\0 \2\1\1\340\372\t\4\0\0\2"..., 1024) = 73
    close(5) = 0
    => verifies that it reads indeed 73 bytes from the correct usb device
    => fastboot doesn't stop there, just continues to read from other usb devices
    "fastboot boot zImage ramdisk.gz"
    creating boot image...
    creating boot image - 3452928 bytes
    < waiting for device >
    => maybe just "fastboot devices" broken? no, waits indefinitely
    configure udev, add /etc/udev/rules.d/51-android.rules:
    SUBSYSTEM=="usb", ATTR{idVendor}=="12d1", MODE="0666"
    => nothing changed, tried all from above
    "sudo /etc/init.d/udev restart"
    "fastboot -i 0x12d1 reboot"
    => PC & device waiting indefinitely on each other again
    "fastboot -i 0x12d1 boot zImage ramdisk.gz" =>
    => grrrr, whoa.....tf!
    Guys, am I stupid or what do I do wrong?
    I'm experienced on linux I would say, but this puzzles even me. Does anyone have an idea?
    Kind regards,
    STYLON
    Last edited by stylon; 10-25-2011 at 06:43 PM. Reason: problem solved, changed title accordingly
    Ads
    Advertising world
  3. #2
    7 days registered
    56352
    Oct 2011
    Germany
    11
    Hi again,
    I forgot to mention that I also tried the same on a VirtualBox VM with 32-bit Ubuntu 10.04 LTS installed. Sees the USB device, but exact same behaviour of "fastboot". Maybe my fastboot executable is broken.
    Regards,
    STYLON
  4. #3
    Points: 9,978, Level: 66
    Level completed: 82%, Points required for next Level: 72
    Overall activity: 3.0%
    Achievements:
    Veteran 5,000 Experience Points 1 year registered 1,000 Experience Points 500 Experience Points
    7516
    Nov 2010
    Dacia
    266
    Thanked
    90 times
    Points
    9,978
    Level
    66
    Huawei s7 104
    Adb is working? If yes you can put your tablet in download with adb command. Is your tablet tablet boot normaly? That bar that you describe it show when your tablet is in sdcard update state. Is like an unfinished update.
    Huawei S7 BB v104.
  5. #4
    7 days registered
    56352
    Oct 2011
    Germany
    11
    Hi goodoane,
    yes, the tablet boots just fine into Froyo, the tablet and Android work just fine, no glitches at all. I remember that I had this "touchscreen not working + buttons light up" when powering down once, since I bought it, but taking battery out helped.
    Indeed, I noticed, too, that anybody who tried "fastboot" on S7 or S7 Slim ever mentioned the bars I see on the screen. I just received this one as "brand new" and I didn't yet try an update myself. How come it can have an unfinished update? As I said, it also boots fine. Wouldn't an unfinshed update mean it fails to boot?
    I also still have on my list to try adb, but due to android.git.kernel.org being down currently, I just tried to download precompiled tools and did not so with adb yet.
    Cheers,
    STYLON
  6. #5
    7 days registered
    56352
    Oct 2011
    Germany
    11
    Hi again,
    I played around a bit more, downloaded even more precompiled version of "fastboot", even to the iMac of my girlfriend. Conclusion: nothing works, so far. Honestly, I get a bit suspicious that anyone got this working at all, even with a Huawei S7 (non-Slim) . Here's why I do think so and what I found out.
    The following code is from some source version of "fastboot.c". I verified that this code is almost "as is" in my precompiled fastboot (easy -> "objdump -d"). Each USB device for which this function returns -1 does not get listed when executing "./fastboot devices". The only difference in the precompiled versions of "fastboot" I already downloaded is that some test for a few more vendor ids (but not the 0x12d1 from Huawei) in the first conditional.
    Code:
    int match_fastboot(usb_ifc_info *info)
        if((info->dev_vendor != 0x18d1) &&
           (info->dev_vendor != 0x0bb4)) return -1;
        if(info->ifc_class != 0xff) return -1;
        if(info->ifc_subclass != 0x42) return -1;
        if(info->ifc_protocol != 0x03) return -1;
        // require matching serial number if a serial number is specified
        // at the command line with the -s option.
        if (serial && strcmp(serial, info->serial_number) != 0) return -1;
        return 0;
    Then, I inspected the output of "lsusb -v" a bit more closely, especially for the ifc_ field descriptors:
    Code:
    Device: ID 12d1:36de Huawei Technologies Co., Ltd.
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            0 (Defined at Interface level)
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      idVendor           0x12d1 Huawei Technologies Co., Ltd.
      idProduct          0x36de
      bcdDevice            0.00
      iManufacturer           3 HUAWEI Configuration
      iProduct                2 HUAWEI Technologies
      iSerial                 0
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength           55
        bNumInterfaces          2
        bConfigurationValue     1
        iConfiguration          1 HUAWEI Configuration
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower              500mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           2
          bInterfaceClass       255 Vendor Specific Class
          bInterfaceSubClass    255 Vendor Specific Subclass
          bInterfaceProtocol    255 Vendor Specific Protocol
          iInterface              0
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x81  EP 1 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0200  1x 512 bytes
            bInterval              32
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x01  EP 1 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval              32
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x82  EP 2 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval              32
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x02  EP 2 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval              32
    Device Qualifier (for other device speed):
      bLength                10
      bDescriptorType         6
      bcdUSB               2.00
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
    Device Status:     0x0001
      Self Powered
    All bInterfaceClass, bInferfaceSubClass and bInterfaceProtocol are 255! Not 255, 42, 3 as expected by the match_fastboot function. What do others see when doing a lsusb -v in fastboot mode? I've also read somewhere there are special USB drivers (on PC I guess) you may need for fastboot, but it looked to me that this is only necessary on windows.
    Thanks for any help on this.
    Cheers,
    STYLON
  7. #6
    7 days registered
    56352
    Oct 2011
    Germany
    11
    Hi again,
    I found out that the device reports at least one USB Interface with values of 255, 66 (=0x42), 1 when in Mass Storage mode (booted into Froyo then USB Disk Mode). So, only the protocol is different from what fastboot expects there. SubClass = 66 = 0x42 looks like "Android", but I'm not 100% sure. At least a couple of other Android devices seem to use that SubClass, too. The question is why this mode I boot into doesn't report those numbers.
    In order to rule out a broken device or similar, the dealer borrowed me another Huawei S7 Slim (everthing same, except for the serial number). Guess what -> exact same behaviour, fastboot doesn't do anything . And there are also the bars on the screen in the 2 boot modes I described above.
    As I don't think both devices are broken in the same way (or have been both partially updated), I would like to find out wether the fastboot mode I see looks different from the one others see. So, does anyone else also have those bars on the screen in fastboot mode? Or is the screen just blank?
    Is it possible that Huawei recently changed the bootloader (possibly to a locked one)? How could I find out?
    Cheers,
    STYLON
  8. #7
    Achievements:
    7516
    Nov 2010
    Dacia
    266
    Thanked
    90 times
    Points
    9,978
    Level
    66
    Huawei s7 104
    To be able to use fastboot you need first to put your tablet in download mode (fastboot). Then you need to add permission on linux for usb device ( one for adb and one for fastboot). I don't know the keybord configuration for slim to put the tablet in fastbootmode but on fat model you need to press both volume key and power.
    Huawei S7 BB v104.
  9. #8
    7 days registered
    56352
    Oct 2011
    Germany
    11
    Hi goodoane,
    I appreciate your help very much, but I just figured you don't even have a S7 Slim. I agree, it could be that entering fastboot mode on the Slim model works different. Does anybody know? It would also help if someone else with access to a "S7 Slim" could verify my steps and report at least the same behaviour (then I would know it's the device and not me). It would also help if someone who has working fastboot with the "S7 Slim" comments what he/she did. With the 2 devices and the Linux PC + iMac I tried I have consistent non-working fastboot. I also have same consistent output of lsusb -v in all modes.
    Regards,
    Stephan
  10. #9
    7 days registered
    56352
    Oct 2011
    Germany
    11
    Hi goodoane,
    can you do me a favor and post the output of "lsusb -v" for your "S7" when in fastboot mode?
    Thanks a lot,
    STYLON
  11. #10
    7 days registered
    56352
    Oct 2011
    Germany
    11
    Hi again,
    I think I found out some more info about the 2 boot modes. The one with the long bar (volume +/- + power) seems to be hboot (and *not* fastboot), the other one (volume - + power) some update boot mode. Both bars look like progress bars being empty. At least for the update boot mode with the flashing button lights I guess it is waiting for some sd card containing an .img or some packages. I'm unsure about what can be done with hboot.
    However, the critical question now is... where's the fastboot mode on this device and how do I get there?
    Regards,
    STYLON
Ads:
  1. Mid 7015 fastboot - won't get back to android screen
    By nopro in forum Coby Generation 1 Technical
    Last Post: 01-05-2012, 04:25 PM
  2. Unwanted fastboot mode when flashing clockwork mod
    By Orutanga in forum Coby Generation 1 Technical
    Last Post: 01-04-2012, 09:23 AM
  3. Fastboot no detect my tcc8902
    By jose.tb in forum Telechips TCC8902 Tablets
    Last Post: 10-12-2011, 10:05 AM
  4. only fastboot or recovery but no android os
    By eoy1985 in forum Coby Tablets
    Last Post: 08-24-2011, 09:10 AM
  5. Xoom with Honeycomb Frozen Fastboot Protocol
    By Riprad in forum Motorola Tablets
    Last Post: 04-27-2011, 10:37 AM
android can't get fastboot usb
can't get fastboot to work
fastboot devices blank
fastboot devices shows nothing
fastboot no permissions
fastboot no permissions linux
fastboot waiting for device already add rule
huawei s7 303u enter into fastboot mode
ideos s7 slim fastboot
no permissions fastboot
virtualbox android fastboot
www.androidtablets.net 24417-can-t-get-fastboot-work
