Results 1 to 6 of 6
  1. #1
    Points: 83, Level: 1
    Level completed: 66%, Points required for next Level: 17
    Overall activity: 0%
    Achievements:
    7 days registered
    154343
    Nov 2012
    Philippines
    Points
    83
    Level
    Ideos S7 Slim
    Problem Playing Flash Videos on My Ideos S7 Slim
    Hi there just finished flashing my s7 slim into Jellybean 4.1.2, its great, but i found it cannot play flash videos i installed adobe flash player but it does not support. Is there a way i can play flash videos?
    Ads
    Advertising world
  3. #2
    Super Moderator
    Points: 12,971, Level: 74
    Level completed: 31%, Points required for next Level: 279
    Overall activity: 56.0%
    Achievements:
    10000 Experience Points Recommendation Second Class 1 year registered 5000 Experience Points 1000 Experience Points
    Awards:
    Frequent Poster
    77592
    Dec 2011
    Norcross, GA
    3,290
    Thanked
    585 times
    Points
    12,971
    Level
    74
    Transformer Prime & TF700
    Quote Originally Posted by chaozzs View Post
    Welcome to the forum
    Did you install Flash 11.1.x, or earlier, and where did you get the APK? JB does support Flash but some browsers don't. My suggestion is that you try Dolphin Browser or FireFox. both have support for Flash, Chrome for Android does not.
    Locked out of your Tablet? - Printing from an Android tablet (or phone) - Connecting to the Internet with no WiFi - Move/copy/cut/paste files to and from your tablet - WiFi connection issues - Getting Flash Player
    TF201 & TF700 (stock) with dock, .
  4. #3
    Achievements:
    7 days registered
    154343
    Nov 2012
    Philippines
    Points
    83
    Level
    Ideos S7 Slim
    Quote Originally Posted by leeshor View Post
    Yes i did install adobe flash 11.1.115.27 got it in adobe flash player archives i did try firefox and dolphin downloaded them from Google play and still i cannot play flash videos from the likes of animeseason.com, movie2k.to, and other streaming video sites it says adobe flash player is not supported in my device. thank you for fast response mr. leeshor
  5. #4
    Super Moderator
    Achievements:
    Awards:
    Frequent Poster
    77592
    Dec 2011
    Norcross, GA
    3,290
    Thanked
    585 times
    Points
    12,971
    Level
    74
    OK, 2 things you need to check in the browser you're using as it sounds like you are on the right track. Make certain in the settings for the browser that it is allowing add-ons and also that it is set to request desktop mode. The locations and names differ between the browsers so you may need to fish around a little. In Firefox there is an add-on called phony that you may need to add.
  6. #5
    Achievements:
    7 days registered
    154343
    Nov 2012
    Philippines
    Points
    83
    Level
    Ideos S7 Slim
    Hi mr leeshor i did set all youve said in firefox i can play flash videos but not stable only got black screen on videos and got sound cracklings and for dolphin browser still cannot play thank you mr leeshor if there are some other fix for my s7 slim android 4.1.2 JB to play flash videos i would be gladly to try it out thank you again.
  7. #6
    Super Moderator
    Achievements:
    Awards:
    Frequent Poster
    77592
    Dec 2011
    Norcross, GA
    3,290
    Thanked
    585 times
    Points
    12,971
    Level
    74
    2 more suggestion. Go to settings - apps - all and find Flash, tap it and tell it to clear cache and force stop then restart your tab. If that doesn't help try uninstalling Flash and start over.
Ads:
  1. Ideos s7 slim cm7 - working !
    By blackwolf102 in forum Huawei Ideos S7 Slim Technical
    Last Post: 10-10-2012, 12:00 AM
  2. problem with playing FLV videos on a500 tablet.
    By vivisectvi242 in forum Android Tablet Video
    Last Post: 03-05-2012, 11:32 AM
  3. Got myself a new Huawei S7 slim ... Adobe flash problem
    By Vla__Dimir in forum Huawei Ideos S7
    Last Post: 08-27-2011, 07:35 AM
  4. Ideos S7 Slim
    By Ollie1991 in forum Huawei Ideos S7
    Last Post: 04-30-2011, 08:07 AM
  5. Huawei Ideos S7 Slim
    By caijoe in forum Huawei Ideos S7
    Last Post: 04-13-2011, 02:59 PM
adobe flash player for huawei ideos s7
adobe flash player on ideos s7 slim
does ideos s7 slim support flash player 12
flash for ideos android tablet
huawei ideos s7 adobe flash
huawei ideos s7 flash players
huawei ideos s7 problem
huawei s7 slim problem video
ideos s7 slim don't play flash player
install adobe flash player on huawei ideos s7 slim
my ideos
why does my s7 slim video messed up
