Page 1 of 39 1 2 3 11 ... LastLast
Results 1 to 10 of 381
Thanks Tree42Thanks
Thread: [ROM] Indonesian Android 2.2.2 for Dual-Camera S7 S7v100R001C98B021
  1. #1
    Developer
    Achievements:
    Recommendation Second Class 500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points
    19805
    Mar 2011
    Jakarta
    197
    Thanked
    94 times
    Huawei Ideos S7
    after made private conversation with odienas this afternoon, finally we have froyo firmware ready to download.
    This update has been confirmed to work with:
    S7-103, Indonesian version with dual cameras internal/external sdcard
    S7-104, US BestBuy/RadioShack version with dual cameras and internal/external sdcard
    Partially working:
    S7-101, Austria Mobilkom version - loses camera, GPS?
    S7-103, New Zealand - loses GPS?
    S7-105, Globe telecom Philippines
    S7-105, Australian version with dual cameras and external sdcard (loses pinch-to-zoom?)
    Warnings:
    The installation of this update will result in loss of data. Please ensure that you have appropriate backups before you proceed.
    Please confirm your model/variant! While it is possible to revert back, flashing the wrong firmware onto your device may have risks and will result in temporary or permanent loss in functionality.
    You should try to perform a backup of the data of important applications using Titanium Backup (root) or another application. If you have Clockworkmod recovery installed, you may elect to perform a nandroid backup before proceeding. Note that the Clockworkmod recovery built for Android 2.1 does not work properly after this update is installed. You will need to first restore to a previous working Android 2.1 firmware before proceeding with the restore in that case.
    Until Huawei officially releases the update for your region, it may result in the voiding of your software warranty. Flash at your own risk.
    here is for you guys:
    Download Link Android 2.2.2 for Huawei S7, S7v100R001C98B021:
    Download Mirror at Megaupload
    Download Mirror at MediaFire
    MD5 checksum for updata.app : 74D031FD717D8BF68956EF3F044C8EEB
    Others Huawei Official firmwares (2.2) can be found here : [ROM]Huawei Ideos S7 official firmware (2.2.2)
    Adobe Flash APK (not pre-installed, optional):
    Adobe Flash Player APK
    Update install process:
    1. unrar the file, and copy the 'dload' folder to the root directory of a sufficiently large external SDcard formatted to FAT/FAT32 (readable by the S7)
    SDcard contents should be like this :
    +SDCard
    -+dload
    ---+updata.app
    ---+unlmt.cfg
    2. turn off the unit, and ensure that you are either plugged in with a battery inside the unit, or that you have enough charge left in your battery
    3. turn on, and a progress bar will appear in the middle of the screen. Wait until "OK" is displayed on the screen.
    4. turn off the unit by removing the battery and any powerplugs to the S7
    5. repeat steps 2,3,4 again. otherwise it will hang at boot screen (instructed by Huawei)
    6. Remove the SD card and start the device. If you wish the use the card for the device, remove the firmware files from the SD card before reinserting it.
    If the update fails to install, check that your file was properly moved into the SDcard by comparing the MD5 checksum.
    The overall process should take less than 15 minutes to complete.
    Q & A for common problems
    Q. Why upgrade fails? it will not flash new ROM, but boot the tablet normally to old ROM.
    A. - If you have SD card formatted using android, format it again using Windows system
    - If you have rename the "dload" folder using android, rename the "dload" folder using Windows system.
    Root after update:
    Use SuperOneClick with the default psneuter method. You will need to enable Android debugging mode on the device itself and install appropriate drivers for adb (Android debugging bridge).
    The discussion for this is here, along with a mirror of SuperOneClick that has been confirmed to properly root the update
    Credits:
    i am just help odienas to make a reliable upload and made mirrors, so all credits and kudos goes to odienas for his great effort.
    Last edited by tri_zet; 05-18-2011 at 04:28 AM. Reason: add Q & A for common problems
    Limey, poncespr, buzzman and 26 others thanked this.
    Ads
    Advertising world
  3. #2
    Senior Member Achievements:
    500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    16519
    Feb 2011
    Philadelphia, Pennsylvania
    208
    Thanked
    60 times
    Huawei Ideos S7, HD2, HTC Tilt
    Quote Originally Posted by tri_zet View Post
    Huawei Ideos S7 froyo
    THANK YOU TRI_ZET! downloading now to check out, can't do anything fun until i get home i can build a rom just no radio, i feel like we are going to have to flash the updata.app to upgrade to new baseband, re-root, and reflash clockwork mod before we can get this rom running custom.
    so to speak, if you flash the updata.app, root, then flash clockwork, full wipe, flash my rom, everything should be working on my rom cuz the baseband update.
  4. #3
    Developer
    Achievements:
    19805
    Mar 2011
    Jakarta
    197
    Thanked
    94 times
    Huawei Ideos S7
    Quote Originally Posted by joenilan View Post
    but recent CWM does not work with new partition. perhaps we can flash it using fastboot?
    dammit thanked this.
  5. #4
    1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    26961
    Apr 2011
    Boulder,CO
    129
    Thanked
    3 times
    Huawei S7
    Dude awesome thanks
    Sent from my S7 using Android Tablet Forum
  6. #5
    26752
    Apr 2011
    36
    Mirror at Mediafire
    Has anyone tried it yet? I'm so glad we are making progress!!!
    Sent from my HTC Desire CDMA using Android Tablet Forum
  7. #6
    26961
    Apr 2011
    Boulder,CO
    129
    Thanked
    3 times
    Huawei S7
    Hey guys ik so happy ill let u guys use my PREMIUK ACCOUNTS
  8. #7
    Developer
    Achievements:
    19805
    Mar 2011
    Jakarta
    197
    Thanked
    94 times
    Huawei Ideos S7
    it is original froyo from odienas that he got from Huawei, and i got MD5 checksum from also from odienas file.
  9. #8
    26961
    Apr 2011
    Boulder,CO
    129
    Thanked
    3 times
    Huawei S7
    Mediafire is <<REMOVED>> and password is <<REMOVED>>
    Megaupload is <<REMOVED>> password is <<REMOVED>>
    (I still have the accounts, if you want to use them for legit purposes PM Me
    tuffigirl thanked this.
  10. #9
    Junior Member Achievements:
    14929
    Jan 2011
    Belgium
    19
    Huawei S7
    So you mean that it should install like every other rom? Just copying the dload folder on an SD card?
  11. #10
    16519
    Feb 2011
    208
    Thanked
    60 times
    already downloaded, extracted fine, gotta download a couple things for my linux vm to see if everything is ok.
Ads:
  1. [APK] Camera Swap for Dual-Camera Huawei, Android 2.1 (Root only)
    By xaueious in forum Huawei Ideos S7 Apps and Games
    Last Post: 08-12-2011, 07:21 AM
  2. [Kernel] 1075MHz Overclock for Dual Camera, Resistive Touch S7
    By xaueious in forum Huawei Ideos S7 Development
    Last Post: 02-08-2011, 06:42 PM
  3. Replies: 11
    Last Post: 01-06-2011, 06:23 PM
  4. Replies: 7
    Last Post: 11-02-2010, 02:49 AM
  5. Verizon 10 inch, dual camera tablet with FIOS
    By StupidGenius in forum Motorola Tablets
    Last Post: 08-03-2010, 06:31 PM
certificate facebook security download for android 2.1 huawei ideos s7 tablets
descargar rom oficial ideos s7105
download aplikasi camera tablet huawei s7
download rom]android 2.2.2 s7v100r001c98b021
huawei ideo s7 2.2 update download
huawei ideos s7 103 android 2.2 (froyo)
huawei ideos s7 s7v100r001c98b021
huawei ideos s7-103 update
ideos s7 2.2 indonesian rom
rom tablet huawei ideos s7 4shared
s7-104 firmware download
s7-104 firmware download s7-104 download firmware
Tags for this Thread
