I wonder how many members are in this forum.
I thought at first wowwwwww this is great forum to find answers
But now after waiting for an answer for a few days, I am dissapointed and I don't think anybody wish to help
This is a discussion on [ROM]Huawei Ideos S7 official firmware (2.2.2) within the Huawei Ideos S7 Technical forums, part of the Huawei Tablets category; I wonder how many members are in this forum. I thought at first wowwwwww this is great forum to find answers But now after waiting ...
I am gonna help you bro, since i am greek too and cause i understund you.(Μήν φοβάσαι εδώ είμαι εγώ :Ρ)
Επιδεί δέν κάνει να μιλάμε ελληνικά θα γράφω στα Αγγλικά εδώ αμα χρειαστείς κάτι πες μου το σε ΡΜ.
You Need your Tabler(:P), 1external sdcard(microSD),usb cable, and usb drivers(given bellow)
1) Check under your batter which is your Tablets version and tell me correctly.
2) From this Thread download this : click here
3) Extract and put it in your External Sd Card.
4)Take anything backup you need with Titanium Backup(found in Android Market)
5)Power off you tablet and open it, then the you will see a bar loading the installation, wait until you will see "OK" and then take off you battery and put it back again.Open your tablet again and let it reinstall again.When you will see the "OK" again, power off your tablet and take off the external SD.
6)Then open your Tablet and you will have android from Joelin Indonesian 2.2.2
Do all this first and then i will tell you how to install the ClockWork
Επίσης ξέχασα να σου πώ ότι αν πηράξεις οτιδήποτε στο Tablet όσον αφορά το λογισμικό η εγγύηση ακυρώνετε αυτομάτως
Φίλε είσαι σωτήρας !!! για δές που πάλι σε αδέρφι πέσαμε
Thanks a lot mate, really appreciate you help.
First to answer your question, I have S7 105 (under the battery sign) and it is Capacitive screen purchased from Vodafone Greece.
OK, here is my next question. Suppose I do all the above, after installing Joelin Indonesian 2.2.2
1. will I have my Greek language menu? (although I never use it, but just in case I decide to see)
2. ClockWork will helpme RESTORE to original S7 version as it was when purchased?
Νά 'σαι καλά αδερφέ !!! Thanks again
The best rom for the s7-105 is the Swedish, although it has a fix with their solutions or patches
In my blog you will find information though this in Spanish
Huawei S7-105
CarTablet : Huawei S7-105 Android 2.2.2, SOC Rooted, Rom: S7-slim-trz-mod-V0.2 Características: 1G, 512, 7" 8 SD int. y 8 SD Ext.(max. 32), 3G, Wifi, Bluetooth y GPS, por micro USB OTG: hard disc y flash memory.Navegadores : Sygic 8.24, Frond-End : Car home y Amon (en pruebas)
I ask for excuses, he believed that if it had raised them to my blog, now already they are, equally I raise them here.
[ROM] Sueca 2.2.2 S7V100R001C63B110(Sweden Expert) para S7-105
DOWNLOAD S7 V100R001C63B110(Sweden)
Hi there, about a month I am the owner of S7-101, am a little beginner. Please be patient! I read all the posts, and I could not find any Brazilian ROM, either here or on the official website of Huawei. If you have one, please post it. Thanks to those who have good will and patience to improve this wonderful gadget.
P. S. If it helps, I'm from Romania, which would be more appropriate: Brazilian, Swedish or Norwegian? Once again, Thank you!
When I try do download this I get: Error 500...? And what I really tried to do was to get firefox working again.
OK, tried to download the Swedish expert, found another link but it stopped downloading, Anyway, I have an S7-103. And was running Firefox on it since middle of December. (Syncing with my PC) Android 2.1-update 1.
Then I upgraded Firefox on feb 29th. And it won't work!!! Tried to go back to factory settings on the tablet. Downloading the new files for Firefox, but nothing helps. So I thought maybe upgrade the OS.
Anyone think this would help? And please give me the link to the best for my tablet and the link how to do it!
Thanks everybody!
