Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 24
  1. #11
    Junior Member Achievements:
    500 Experience Points 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    96191
    Feb 2012
    Muscat, Oman
    27
    Thanked
    9 times
    Download a stock firmware(known devil) first, if you do not already have, available via this forum at different links. Format an external sdcard using Windows in FAT32. Unzip the downloaded stock firmware to your sdcard. It should have only one directory named "dload". Under dload three files named unlmt.cfg, UPDATA.APP and upg can be found. While upg is a log file and may not be necessary its presence does not harm but the cfg file should be "unlmt.cfg". Remove sdcard safely and insert it in S7. You do not need your battery to flash. Connect your charger and power on the charger. Wait for IDEOS on screen and then power on your device. The flashing should start. Watch out for fast flashing or stalling. If it does, disconnect your charger - as it will not proceed any further - and retry. If it still does not complete flashing the device apparently has not entered recovery mode and you will need adb on your PC to verify that.
    If you do have adb, connect your device to the PC and wait for few minutes before invoking adb. Assuming you have Windows, you can check if the device is recognized under Device Manager. It will be listed as an Android device. Open a command window and cd to the directory where adb is installed. Issue a command "adb devices" to check if your device is seen by adb. If it does it will list your device probably as "1234567890ABCDEF". I do not remember the position of "0". If it does not list anything then you are in trouble. :-(. You need an expert assistance then.
    After the device is listed issue a command "adb reboot recovery" with sdcard with firmware still inserted. It will flash your device. Good Luck.
    Ads
    Advertising world
  3. #12
    32081
    May 2011
    Philippines
    9
    Huawei Ideos S7
    Quote Originally Posted by kaysun View Post
    1. Without battery connect charger and then power on charger. Let know if IDEOS is displayed on screen. Assuming ROM is corrupt.
    2. With or without battery but with charger connected and powered on press and hold Back and Send buttons then power up. Does the unit display a white bar in the middle?
    If any of the above symptoms is present, the unit can be rebooted in recovery via ADB and a stock firmware can be flashed. I killed my tab so many times like an over zealous modder and could recover back all the time. it did happen to me that the flashing stopped after about 5 bars and then on some other occasion at bar 12 or 13. On two occasions the lights will suddenly start blinking fast and flashing will not continue. Please let know.
    Suspecting a faulty charger, I checked the charger using a DMM, it still kicks out 5V and 2A. Assuming nothing is wrong with my S7 and charger, it should be able to power on even without the battery, right? Tried #1 and #2, unfortunately my S7 still does not power up at all. So there must be really something wrong with my S7.
    Since I had a failed reflash, my S7 now has no firmware and since I cannot power it on, I am not able to do a reflash via the SD card method. I cannot even get to bootloader mode.
    Does anyone have a schematic diagram of the S7? I am thinking if this can be reflashed via JTAG?
    Huawei Ideos S7 SV-105 (Globe Telecom)
    Android ver. 2.2.2 - Rooted
    Build No. S7V100R001C98B021
  4. #13
    32081
    May 2011
    Philippines
    9
    Huawei Ideos S7
    Ok, so I had my S7 plugged into the AC charger for 2 days and still does not power up. I measured the voltages to check as well if this is a hardware issue. Here are my readings:
    1. AC charger output = 5.223V, 2A
    2. Battery voltage (- to + terminals) = 2.34V
    3. Battery voltage (- to middle terminal) = 0V
    4. Battery voltage (middle terminal to +) = 2.34V
    5. S7 w/out battery but AC charger connected (- to +) = 0V
    6. S7 w/out battery but AC charger connected (- to middle terminal) = 2.85V
    7. S7 w/out battery but AC charger connected (middle terminal to +) = 2.85V
    Could anyone confirm if you get the same measurements? Any help would be appreciated.
    Also, here are some questions I would like to ask:
    1. Is it possible to wipe-out the bootloader during an unsuccessful reflash? No bootloader, can't reflash.
    2. If there is no firmware, will the S7 still power on and charge? Isn't the power management controlled by the FW?
    I am looking at JTAG as a last resort although I'm not sure if anyone has done this before.
  5. #14
    7 days registered 31 days registered 100 Experience Points
    165337
    Jan 2013
    CHCH, NZ
    S7 Slim
    I was attempting to do just this, and it got about 1/4 the way through and then said "Update Failed, Please Try Again" I put it away until I got home again and then tried turning it on again to discover it wouldn't power up (either on mains or battery) and when put on charge it wouldn't even display the charging animation... PLEASE HELP !!!!! :S
  6. #15
    173478
    Apr 2013
    hi, have you solved your problem? i have a S7-105. it doesn't turn on with or without power supply. no lights. please help me if you can.
    regards.
  7. #16
    165337
    Jan 2013
    CHCH, NZ
    S7 Slim
    Quote Originally Posted by egone01 View Post
    regards.
    Hi Egone,
    Unfortunatly, No, for the time being i have had to put it down as we are packing to move house,
    im looking at the possiblity of actually having to find myself another android device as there doesnt seem to be any solution i have found
    please, if you find something that works in the meantime let us know, im sure it will be appreciated
    Cheers,
    David
  8. #17
    Points: 60, Level: 1
    Level completed: 20%, Points required for next Level: 40
    Overall activity: 0%
    Achievements:
    7 days registered
    187181
    Dec 2013
    Sri Lanka
    Points
    60
    Level
    Huawei s7-104
    Hey Did you get any answer
    Quote Originally Posted by lite751 View Post
    Hi, I need your expert opinions regarding my S7. It refuses to turn on or power up either with the battery or the charger plugged after an "unsuccessful" firmware upgrade. Did I brick my tablet?
    I have already successfully upgraded from the stock 2.1 to 2.2.2 (Indo ROM) previously. Then recently, my S7 hung on the "IDEOS" logo after powering-up. Tried hard reset, recovery and fast-boot to no avail. So I eventually decided to re-flash via SD using 2.2.2 Indo ROM again. During the upgrade process, the progress bar stopped midway and my S7 reset. Tried to repeat the process with similar results, simply the upgrade failed. After that, my S7 does not turn on anymore. I tried removing the battery and plugged the AC charger but still it won't power up. I don't think this is a hardware issue and I suspect it has something to do with the failed upgrade.
    Any thoughts on how to resolve this issue? Thanks in advance!
  9. #18
    Points: 27, Level: 1
    Level completed: 54%, Points required for next Level: 23
    Overall activity: 10.0%
    193498
    Apr 2014
    Points
    27
    Level
    Huawei Ideos S7-105
    I have the sameproblem.Isdueto the power jackonthe tablet.If you lookinside it,themetalin the middle isbroken.I searchedajackidenticalbuthave not found.The only wayis toremove thetwo wires from the(+) and(-) and connecta different type ofplug.The problem isI do not knowwhich arethe polaritieson the motherboard.Name:  contacts.JPG
  10. #19
    Super Moderator
    Points: 23,805, Level: 94
    Level completed: 46%, Points required for next Level: 545
    Overall activity: 9.0%
    Achievements:
    Tagger Second Class 1 year registered 10,000 Experience Points 5,000 Experience Points Recommendation Second Class
    Awards:
    Arm of Law
    122577
    Jun 2012
    1,800
    Thanked
    778 times
    Points
    23,805
    Level
    94
    Coby Kyros MID9742, Dell Streak 5
    Check the polarity symbol on the case. It will look like either of these:
    The third contact of the five that have lines running through them in the image you provided is the center pin, which is the dot with the line leading to the + or - mark on the right. The barrel connectors will be the opposite polarity.
    "Most people bake cookies. I bake motherboards."
    I do not accept PMs asking for one-on-one tech support. Ask on the forums so everyone can benefit.
    Play Store Tweaks For Stock Coby 9742 ROMs | Rooting Instructions For Coby Generation 3 Devices
  11. #20
    193498
    Apr 2014
    Points
    27
    Level
    Huawei Ideos S7-105
    Thanks Traveller1701. I can measure the power jack polarity. The problem is on the motherboard.
    It is correct?
Ads:
  1. Huawei Ideos S7 - Please Help!
    By secretdude0 in forum Huawei Ideos S7 Technical
    Last Post: 11-07-2011, 03:16 PM
  2. Need help with my Huawei Ideos S7 Slim
    By Kel in forum Huawei Ideos S7
    Last Post: 09-25-2011, 08:41 AM
  3. got any ROMS for the huawei ideos s7?
    By vernon15 in forum Huawei Ideos S7
    Last Post: 06-02-2011, 01:25 AM
  4. SOS!!! Need HELP ON MY HUAWEI IDEOS S7!!!!!!
    Last Post: 06-01-2011, 05:52 AM
  5. Huawei Ideos S7 Bug List
    By xaueious in forum Huawei Ideos S7 Development
    Last Post: 02-03-2011, 06:19 AM
huawei tablet not turning on
huawei tablet s7 doesn't want to switch on what to do
huawei tablet won't power on
huawei tablet wont turn on
ideos how does it boot
ideos s7-104 battery not chargeing
my huawei ideos doesnt swich on
my huawei s7-931u can not turn on. its only the screen display when i charge it
my huawei tablet wont turn on
my ideos doesnot power on
s7-104 brick
what happened if ideos s7 slim huawei doesn't want to charge and switch on
