Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thanks Tree8Thanks
Thread: Performing a True Full Reset
  1. #1
    Administrator Achievements:
    50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 5,000 Experience Points 1,000 Experience Points
    4111
    Sep 2010
    Edina, MN USA
    3,651
    Thanked
    556 times
    So I am giving the S7 to my wife for a couple of weeks to get her impressions of the device (she is not as excited by gadgets as I) and wanted to perform a full reset so that for her it would be like unboxing it for the first time.
    After fighting with the USB method for days I discovered that it does not actually perform a full reset, there are still "ghosts in the machine" as it were after resetting the device. I also discovered there is no concise easy write up on how to perform a true and complete wipe and reset for the device.
    My experience has been that the only way to well and truly completely reset the device is to do the following steps. If you need firmware, please refer to this thread: http://www.androidtablets.net/forum/...-firmware.html
    Here are the instructions:
    1. Take a MicroSD Card, format it as FAT32 in your windows machine. Do not format in your android.
    2. Create a directory at the root of your MicroSD card called dload
    3. Copy the updata.app and unlmt.cfg files to the dload directory on the MicroSD Card (these files are located in the Firmware ZIP you downloaded from the link above). NOTE: DO NOT USE THE ONCE.CFG FILE. If you do, you will be unable to perform future flashes or resets.
    4. Fully power off the device
    5. Insert the MicroSD card and power on
    6. You will see the progress bar if this works
    7. When complete you will get an OK on the screen
    8. Remove the battery of your device
    9. Remove the MicroSD card. - If you don't it will reset when you start the device again
    10. Reinsert the batter and power on your device.
    If you have a true full reset it will start with the Screen Calibration. If you do not start from that screen you have not completely reset the device.
    Cheers,
    Peter
    poncespr, ScooterG, Who Dat and 3 others thanked this.
    Peter B. - email: tardis@androidtablets.net | Twitter: pbbrauer | Google+: pbbrauer | gTalk: pbbrauer@gmail.com
    Current Devices, ROMs:
    (Active) VZW Samsung Galaxy Nexus- Rooted, Android ICS 4.0.2 | ASUS Transformer Prime TF201- Rooted, Unlocked, Virtuous Prime-9.4.2.15 v1 ROM
    (Retired) Viewsonic gTab - Rooted, Flashback 10.3 (Honeycomb) | Huawei S7 - Rooted, Froyo Fusion R2 | (Other) Nook Color (2 of these) | Gentouch 7/8 - Rooted, Lincrackers Pirate 3
    Remember to "Thank" people that help you out! |Click here for general Questions?
    Ads
    Advertising world
  3. #2
    Member Achievements:
    500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    7458
    Nov 2010
    97
    Thanked
    10 times
    This should be a sticky or added to the tweaks and tips.
  4. #3
    4111
    Sep 2010
    Edina, MN USA
    3,651
    Thanked
    556 times
    Wasn't sure if this was useful enough info! ;-)
    I will move it to a sticky.
  5. #4
    7458
    Nov 2010
    97
    Thanked
    10 times
    It sure is. I like to wipe and start clean every now and then after messing around installing every game and app that catches my eye.
    Thks!
  6. #5
    Senior Member Achievements:
    9830
    Dec 2010
    Melbourne
    392
    Thanked
    38 times
    Huawei S7
    I have an sdcard setup just for this purpose permanently.
    I flashed the US Rom, instead of the Australian Telstra Rom. It is 40Mb smaller and faster. But GPS does not work for latitude and longtitude. Only works for direction. Any ideas?
    Sent from my Ideos S7 using Android Tablet Forum App
    Huawei S7-105 (Telstra) Rooted
    Froyo 2.2.2 ROM (S7V100R001C98B021)
    Rooted with SOC
    Telstra pre-paid
  7. #6
    4111
    Sep 2010
    Edina, MN USA
    3,651
    Thanked
    556 times
    That is probably due to the ROM, not the GPS. have you tried any of the other GPS apps from the market?
  8. #7
    9830
    Dec 2010
    Melbourne
    392
    Thanked
    38 times
    Huawei S7
    Tried GPS Test and GPS Status. Compass and tilt work but not latiude and longitude.
    Rooted with SOC
    Telstra pre-paid
  9. #8
    500 Experience Points 1,000 Experience Points 250 Experience Points Tagger Second Class 100 Experience Points
    6197
    Nov 2010
    133
    Thanked
    1 times
    S7
    THANKS,i just recovery my from a brick!!! now im back online...
  10. #9
    10780
    Dec 2010
    105
    S7
    Just performed this RESET and worked like a charm... Great post and great for recovery in case someone ever brick's their tablet.
    -Movado-
    Archos 70 Internet Tablet 250GB
  11. #10
    1 year registered 500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points
    9062
    Dec 2010
    Moultrie, Georgia
    39
    Thanked
    7 times
    Huawei Ideos S7
    Works great! Thanks
Ads:
  1. NOOKcolor Full Specifications
    By rico2001 in forum Nook Color Technical
    Last Post: 05-20-2011, 10:47 PM
  2. Factory Reset? or email reset
    By wronafit in forum Android Tablet Q&A
    Last Post: 12-25-2010, 07:34 PM
  3. Gentouch78 with FULL SD and 3.5mm audio jack.
    By elpolarys in forum Augen Gentouch
    Last Post: 12-10-2010, 02:34 PM
  4. Brand new MID M001 Storage full why?
    By lolyo in forum WonderMedia WM8505 Tablets
    Last Post: 10-10-2010, 01:52 PM
  5. Full system backups..can you do it???
    By eckles in forum Rockchip RK2808 Tablets
    Last Post: 08-05-2010, 04:45 PM
hard reset s7 telstra
hard reset telstra active touch
huawei s7 hard reset
t-touch tab hard reset
telstra active touch hard reset
telstra s7-104 hard reset
telstra t touch tab factory reset
telstra t touch tab hard reset
telstra t-touch tab hard reset
telstra t-touch tab s7-104 firmware update
telstra t-touch tab s7-104 hard reset
telstra touch tab firmware update
Tags for this Thread
