Page 1 of 15 1 2 3 11 ... LastLast
Results 1 to 10 of 142
Thanks Tree28Thanks
Thread: [ROM] CyanogenMod 9 for S7-105 (testing)
  1. #1
    Points: 2,793, Level: 32
    Level completed: 29%, Points required for next Level: 107
    Overall activity: 0%
    Achievements:
    1 year registered 500 Experience Points 1000 Experience Points 250 Experience Points 100 Experience Points
    32444
    May 2011
    BH, Brazil
    104
    Thanked
    8 times
    Points
    2,793
    Level
    32
    Ideos S7_105
    [ROM] CM9 / ICS for S7-105 (testing)
    For all of you who are curious to try CM9 ICS Android 4.0.4 on the S7-105 (may work with others 10x...?)
    Remember this is work-in-progress, so some things does not work as expected (yet?) !!!
    ( but some may find it is stable enough... :-) )
    What you need:
    - know how to flash using recovery or fastboot
    - flash the latest recovery
    Install:
    1. get the rom (123,7Mb)
    2. copy the file to the internal SD
    3. boot to recovery and do backup and a full wipe data
    4. select 'install zip from sdcard', choose the zip and flash
    5. reboot and wait
    Work:
    1. capacitive touchscreen
    2. wifi
    3. tablet mode enabled by default
    4. ...almost everything else ;-)
    Does not work:
    1. bluetooth
    2. cameras
    3. tethering (see Tips)
    4. skype, netflix, flash, ...??
    5. some sound noises (I've confirmed its not kernel's fault, it is something in the configs/libs, will try to debug it when a stable CM10 is available)
    NOTE:
    it is recommended to have a 2º partition (sd-ext) on the internal SD for the Data partition, to be able to install lots of apps!
    TIPS & TRICKS:
    -> wifi tether may work:
    Install from the market app WiFi tether, then go to settings and check MSS clamping and Ruting fix. Then click on Change Device-Profile and check Generic ICS/JB (wlan1) and finally click on Change Setup-Method and click on WEXT. Probably there is no need to do all of this but after one hour playing with this I can finally use hot spot. (tip by member Just_me)
    -> latest Google Apps:
    CyanogenMod Wiki
    (install from recovery)
    -> google play does not show apps or say they are incompatible:
    try download the .apk file to the sdcard and install manually, or set the Lcd density to 160.
    you can also try this (tip by member fbcomp)
    -> small performance gain:
    Disable CPU Rendering
    Enjoy!!
    Suggestions are welcome!!
    This is possible thanks to the work of ere95588, asturel, goodoane, angelsgroup and probably others..??
    luisrene88, kaysun and Gildo thanked this.
    Ads
    Advertising world
  3. #2
    Points: 413, Level: 8
    Level completed: 26%, Points required for next Level: 37
    Achievements:
    3 months registered 250 Experience Points 31 days registered 100 Experience Points 7 days registered
    139491
    Sep 2012
    Mexico
    28
    Thanked
    4 times
    Points
    413
    Level
    8
    Huawei Ideos S7 105
    thank you and all the people to do work this, follow this link to view general information abaout all huawei ideos s7 versions
    [ROM] CyanogenMod 9 for S7 Slim! (ALPHA)
    the user with a ideos s7 105 can post here the news, what you say? we need this thread to help another user want to try this alpha version.
  4. #3
    Achievements:
    32444
    May 2011
    BH, Brazil
    104
    Thanked
    8 times
    Points
    2,793
    Level
    32
    Ideos S7_105
    Quote Originally Posted by luisrene88 View Post
    Yes, that was the idea, trying to organize a little bit all the info about the CM9 rom development for the s7_105.
  5. #4
    Points: 669, Level: 13
    Level completed: 38%, Points required for next Level: 31
    Achievements:
    500 Experience Points 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    96191
    Feb 2012
    Muscat, Oman
    27
    Thanked
    9 times
    Points
    669
    Level
    13
    First of all hats off Asturel for bringing a dead tab back to life. And thanks to Jota and others for working so hard to get things going on S7. The above images work
    on my S7-101 with cap touch screen (Yes the label says 101 and its capacitive) bought last year in Oct!). While Asturel's did not go beyond boot screen with IDEOS logo - Tried various processess outlined in slim forum with no luck. I understand its more for Slim. I wish the posts by individuals carry an s after S7 to identify if it has been tested working on Slim and simple S7 for the FAT.
    But I do have a problem that it gives an audible tone every few seconds until I turn off touch sounds. No idea why? Anyone?
    Thanks again.
    After posting noticed my radio is not on so no network. And on reboot asks for password?!
  6. #5
    Points: 1,471, Level: 21
    Level completed: 72%, Points required for next Level: 29
    Overall activity: 1.0%
    Achievements:
    1000 Experience Points 1 year registered 500 Experience Points 3 months registered 250 Experience Points
    47031
    Aug 2011
    Portugal
    98
    Thanked
    3 times
    Points
    1,471
    Level
    21
    Huawei Ideos S7-105
    what is the last Recovery version for 105 model??? can someone post link? does that recovery work with CM9?
  7. #6
    Achievements:
    139491
    Sep 2012
    Mexico
    28
    Thanked
    4 times
    Points
    413
    Level
    8
    Huawei Ideos S7 105
    Quote Originally Posted by kaysun View Post
    are a fix for this in belarus forum and wifi fix to download WIFI _ PHONE fix for S7-104.zip Download - Directmirror.com - Upload & Mirror your files!
    kaysun thanked this.
  8. #7
    Achievements:
    139491
    Sep 2012
    Mexico
    28
    Thanked
    4 times
    Points
    413
    Level
    8
    Huawei Ideos S7 105
    Quote Originally Posted by co0led View Post
    https://www.dropbox.com/s/gdjkyhs6ho...%20slim%29.rar
  9. #8
    Achievements:
    139491
    Sep 2012
    Mexico
    28
    Thanked
    4 times
    Points
    413
    Level
    8
    Huawei Ideos S7 105
    new rom from asturel release, you tried installing with your system.img?
  10. #9
    Achievements:
    32444
    May 2011
    BH, Brazil
    104
    Thanked
    8 times
    Points
    2,793
    Level
    32
    Ideos S7_105
    I will look at it... maybe others will also get a rom that can run on the s7-105 and be easy to install...
  11. #10
    Points: 8,174, Level: 61
    Level completed: 8%, Points required for next Level: 276
    Overall activity: 9.0%
    Achievements:
    5000 Experience Points 1 year registered 500 Experience Points 1000 Experience Points 250 Experience Points
    7516
    Nov 2010
    Dacia
    261
    Thanked
    87 times
    Points
    8,174
    Level
    61
    Huawei s7 104
    For the one that want to try cm10 made by asturel here is the boot(kernel).
    Download fast and easy your files! - 9iqF84
    no usb mass storage
    no camera
    no bt?.. yet
    kaysun and cansat thanked this.
    Huawei S7 BB v104.
Ads:
  1. Official Lenovo A1 ICS for US Available Now for Testing?
    By xaueious in forum Lenovo IdeaPad A1
    Last Post: 08-27-2012, 07:48 PM
  2. Android Software Testing
    By isaAndroid in forum Android Tablet Q&A
    Last Post: 08-04-2012, 01:19 AM
  3. Testing GPS
    By BillyInHudsonFl in forum Toshiba Thrive
    Last Post: 02-11-2012, 05:37 AM
  4. Testing apps
    By hotmid in forum Android Tablet Apps
    Last Post: 01-19-2012, 08:40 PM
  5. Wireless Stability Testing
    By leighw101 in forum Sylvania Tablets
    Last Post: 10-16-2011, 06:12 AM
cm9 ideos s7
cyanogenmod ideos s7
huawei S7 rom
huawei ideos s7 slim cm9 ics 4.0.4
huawei s7 105
huawei s7 ics
huawei s7 roms
huawei s7-105
ideos s7 4.0 rom
ideos s7 cm9
ideos s7 cyanogenmod
ideos s7 rom
