Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 55
Thanks Tree22Thanks
Thread: [RECOVERY] S7 Clockworkmod Recovery Port for Android 2.1 Builds
  1. #1
    Administrator Achievements:
    100,000 Experience Points Veteran 50,000 Experience Points 25,000 Experience Points 10,000 Experience Points
    795
    Jul 2010
    Canada
    3,486
    Thanked
    432 times
    This does not work on Android 2.2 builds in its current state
    Calling this xauBeta so we can distinguish between versions. Tested with Bestbuy Huawei Ideos S7-104 White (external microSD and internal 8GB).
    Tested on BestBuy S7-104 running the newer Singapore ROM S7V100R001C61B011, for Android 2.1.
    This was not tested on a stock BestBuy ROM. I do not know if this will work properly on that firmware. Please report your findings.
    Use fastboot to flash (install fastboot and fastboot drivers, enter fastboot via vol+/- and power button combo, issue the command 'fastboot flash recovery recovery.img')
    Download
    v0.11
    Internal NAND + External SD Version for S7-104 BestBuy, Radioshack:
    I do not expect this version to work properly for single SD variants
    Multiupload download
    de54cb057b6b9ebbd5912588e4aad628 recovery.img
    External Single SD Version for S7-105 Telstra:
    aa0c883aac0edb8f5d9929148cf56136 recovery.img
    Changelog
    v0.11
    -forgot nandroid-md5.sh
    v0.1
    -initial version
    Notes
    This recovery image is functional enough for use.
    If you have the dual-nand variant of the S7, you can still use the recovery image for the single-sd version. If you do so, installable update zip files will need to be placed on the external microSD instead of the internal nand. You also lose the ability to mount the internal nand to the computer via recovery.
    What works: Nandroid works. USB mounts work (choose between internal and external mount hacked in for the dual-sd version). Flashing installable update zip files work. Fix permissions works.
    This is still an ugly hack of a recovery image. Instead of waiting for developers, I threw this together so I can use it.
    This recovery does not read the misc partition flags and boots into user mode every time. Hopefully this does not break too many things. It only displays only 50% of the screen, but it is still readable. It works for me, so I'm not going to touch the kernel framebuffer or whatever was causing the quad-screen craziness.
    Buttons in this recovery image:
    Up - vol +, dpad up
    Down - vol -, dpad down, menu (cycles when menu reaches bottom)
    Select - home, dpad select, power, send call
    Back - end call, back
    The weird color and the half-screen issues are known. No fixes are planned.
    What hasn't been tested
    Need someone to help figure out which would be the ideal way to deploy this. I typically fastboot. Will look into an easier method of deployment possibly in the future.
    Not tested:
    formatting external SD for apps2sd feature (under advanced)
    format sdcard (not sure what this option does)
    nandroid with apps2ext
    Screenshots
    boot
    nandroid
    Credit to koush and everyone who has worked on Clockwork recovery
    Also HOWTO: Unpack, Edit, and Re-Pack Boot Images - Android Wiki
    razor950 for the device files
    perivarlura for some binaries from his ramdisk
    shanksv, frankbo168, pa49 and 5 others thanked this.
    Huawei Ideos S7-104 on Singapore ROM, HSG X5A, RK2818 RT7, (Past: IMX515 APAD, RK2808 APAD)
    My written articles are licensed under a Creative Commons Attribution-NonCommercial 3.0 Unported License
    本人現在已比較小時間瀏覽此論壇。有關和此論壇的合作關係,請聯絡admin或4Nines。
    Ads
    Advertising world
  3. #2
    795
    Jul 2010
    Canada
    3,486
    Thanked
    432 times
    Easier Windows Install
    Requires full root on your tablet, and USB debugging enabled. Plug your S7 in via USB while booted into Android. This is a Windows install script. Just run install_now.cmd and follow the prompts.
    Download from Multiupload
    This is a script that will try to automatically install this recovery image to your device. You will still need to install the Windows drivers on your computer.
    Have the drivers ready from Huawei -> Direct Link
    http://bit.ly/gjH9f9
    Credit to install script for malez recovery: http://code.google.com/p/acer-liquid-malez-recovery/
    pvella, rictec, Who Dat and 3 others thanked this.
  4. #3
    795
    Jul 2010
    Canada
    3,486
    Thanked
    432 times
    Forgot the md5sum check script for nandroid. Repacking. Give me 10 minutes.
    Edit:
    all good now. windows install script will be up shortly.
    nandroid works fine. Tested on my Bestbuy S7-104 on new Singapore ROM via my Windows 7 64 bit PC.
  5. #4
    Senior Member Achievements:
    500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    8433
    Dec 2010
    Kansas City MO
    146
    Thanked
    20 times
    Huawei S7 & Droid X
    Xaueious, great work on this. I am going to hold off on putting this on for now since it is running so well right now. However once we start to see some custom ROMs I will be all over this. This is a huge first step.
    -Huawei S7 Rooted with apps on internal SD card
    -DroidX rooted with Fission 2.6.1
  6. #5
    50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 5,000 Experience Points 1,000 Experience Points
    4111
    Sep 2010
    Edina, MN USA
    3,651
    Thanked
    556 times
    Who thinks X gets the bounty? I do!
    Peter B. - email: tardis@androidtablets.net | Twitter: pbbrauer | Google+: pbbrauer | gTalk: pbbrauer@gmail.com
    Current Devices, ROMs:
    (Active) VZW Samsung Galaxy Nexus- Rooted, Android ICS 4.0.2 | ASUS Transformer Prime TF201- Rooted, Unlocked, Virtuous Prime-9.4.2.15 v1 ROM
    (Retired) Viewsonic gTab - Rooted, Flashback 10.3 (Honeycomb) | Huawei S7 - Rooted, Froyo Fusion R2 | (Other) Nook Color (2 of these) | Gentouch 7/8 - Rooted, Lincrackers Pirate 3
    Remember to "Thank" people that help you out! |Click here for general Questions?
  7. #6
    795
    Jul 2010
    Canada
    3,486
    Thanked
    432 times
    Not aware of a bounty anymore. I only have a personal Paypal address, so people have to PM me for it.
    Those of you who are using this, I would appreciate feedback if you are using it on another device.
  8. #7
    9830
    Dec 2010
    Melbourne
    392
    Thanked
    38 times
    Huawei S7
    Happy to test this on the version without internal sdcard. I assume this is not like a normal reboot recovery where your machine gets wiped to factory settings. Is this likely to break link2sd setup? How do you get out of recovery mode, is it just another reboot?
    Huawei S7-105 (Telstra) Rooted
    Froyo 2.2.2 ROM (S7V100R001C98B021)
    Rooted with SOC
    Telstra pre-paid
  9. #8
    16968
    Feb 2011
    Lowell, ma
    31
    Thanked
    1 times
    Huawei Ideos s7
    I like that script for windows makes it easier for all of us. As for me I use terminal emulator flash_image to flash recovery but that aside. (My computer gets used by my kids more than me so I have to fight for it)
    So will this work (my step to backup then restore test procedure)
    From terminal
    reboot recovery
    Create a nandroid backup
    Reboot and delete some files to break it (excluding recovery partition of course)
    Boot into recovery using the button combo
    Restore nandroid
    there's no other special method that's involve?
    I'm just trying to confirm
  10. #9
    795
    Jul 2010
    Canada
    3,486
    Thanked
    432 times
    If you have no internal sdcard, please give me the output from shell of:
    Code:
    cat /proc/mtd
    Basically we have to work on a new BoardConfig...
    I also need to know which mmcblk the internal sd resides in for your S7.
    so...
    Code:
    ls /dev/block/mmc*
    This recovery wont wipe your device when you boot it. But there are definitions for where the recovery expects to find a SD partition that might make a difference. Nandroid might not work properly.
    Paste it into [RECOVERY] Working recovery with UI glitches
    @mecha2010
    No special tricks required. Just make sure you don't screw up the internal SDCard FAT partition it reads the recovery from as well. Or else you would just reflash to a Huawei ROM, enable USB debugging, run the Windows install script, and finally restore nandroid from CWR recovery. You could use flash_image to flash as well, but fastboot will probably be the safer to do it correctly.
    Backup up to internal memory is the method we are keeping because it is stock, and negates the need for an external SD.
  11. #10
    Junior Member Achievements:
    19929
    Mar 2011
    San francsico
    11
    Nexus one-cm7 rc2, nexus s-stock,huawei s7 (sold), Nook Color-running CM7 Nightlies
    Quote Originally Posted by xaueious View Post
    Requires root and USB debugging enabled.
    Plug your S7 in via USB.
    Credit to install script for malez recovery: acer-liquid-malez-recovery - Project Hosting on Google Code
    I'm sorry I know this sound stupid. How do I go into the recovery mode? Same as before by pressing vol-up, send and power buttons? I'm ready to try out your work, I just need to confirm the methods of getting into the recovery before I get started. Thanks!
Ads:
  1. Replies: 7
    Last Post: 04-08-2011, 10:51 AM
  2. No clockworkmod recovery?
    By Rick09 in forum Nook Color Technical
    Last Post: 04-07-2011, 09:05 PM
  3. ClockworkMod Recovery Question
    By woohhaa in forum Huawei Ideos S7
    Last Post: 04-01-2011, 10:14 PM
  4. Replies: 1
    Last Post: 01-24-2011, 07:22 PM
  5. ClockworkMod Recovery 3.0.0.2 available !
    By lifeisfun in forum Nook
    Last Post: 01-02-2011, 09:58 AM
bootable clockwork recovery image of android 2.2
clockworkmod compatible with 2.1 eclair
clockworkmod for 2.1
clockworkmod recovery android 2.1
clockworkmod recovery for android 2.1
cwm recovery android 2.1
download clockworkmod recovery for android 2.1
download cwm versi 2.1
how to get clockworkmod recovery for android 2.1
malez recovery via terminal emulator
recovery-clockwork img android 2.1
skyworth s7 recovery via pc
