Results 1 to 3 of 3
  1. #1
    58638
    Oct 2011
    Denmark
    7" android 2.2 OS Tablet PC with VIA 8650 CUP and Dual Core
    Hello All - Huawei E173 Modem Problem
    Just entered the forum, so I just wanted to say hi ) And I really hope you can help me out with a major problem.... I´ve got a serious problem, I got this new: Cheap 7" android 2.2 OS Tablet PC - The thing is I´ve got 3G network card/USB Modem - Huawei E173 - that this tablet should support! Well it doesn´t ??? I keep gettin the message: DAMAGED UDISK!!! it´s NOT damaged, it works fine!!! Now I bought a micro sim card, for the tablet that doesn´t work either, doesn´t fit into the TF slot!!!
    So how do I get this thing to get on the Internet with this Huawei E173 modem ?? Please HELP!!
    Ads
    Advertising world
  3. #2
    Points: 69,871, Level: 100
    Overall activity: 100.0%
    Achievements:
    Recommendation First Class 1 year registered Overdrive Tagger First Class 50000 Experience Points
    23311
    Mar 2011
    Chicago, IL
    10,255
    Thanked
    1117 times
    Points
    69,871
    Level
    100
    NOOK Tablet Stock NOOKcolor Rooted & ManualNooted
    Hello Sarco, welcome to the forum. Glad to have you as a member of Android Tablets. Sorry to hear you're having problems with your new tablet and I'm moving your thread to the Android Tablet Q&A section. Someone there should be able to help you.
    If it's important to you, you'll find a
    way. If not, you'll find an excuse.
    If you're too busy for friends,
    You're too busy.
    Attention lurkers! Join the forum,
    and enter Spider into the referrer
    field of the application.The $0.00
    USD fee will be waived.
    People will forget what you said.
    People will forget what you did.
    But, people will never forget
    how you made them feel.
  4. #3
    Developer
    Points: 18,789, Level: 86
    Level completed: 88%, Points required for next Level: 61
    Overall activity: 5.0%
    Achievements:
    10000 Experience Points 1 year registered 5000 Experience Points Tagger First Class 3 months registered
    51130
    Sep 2011
    Brasil
    1,387
    Thanked
    239 times
    Points
    18,789
    Level
    86
    MID1024
    First of all, a micro SIM has nothing to do with TFlash, which is actually a flash drive/memory while SIM is a chip used by cell fones. You can't use one in another slot and vice-versa...
    Secondly, it seems that the tablet is trying to read the virtual CD-ROM that your modem has with drivers for normal computers. There are some commands to disable this virtual CD using terminal commands (AT-something). Look around and you should be able to disable it. Then you will have to find out if Android on your tablet supports a 3G dongle, not all do, and when they do it only works with certain modems...
    Kyros MID1024 8GB (1024n board - development)
    Iconia Tab A500 16GB
Ads:
  1. Huawei e1750 3g usb modem
    By reinoud1963 in forum Zenithink ZT180 10 Generation 2
    Last Post: 08-23-2012, 05:55 AM
  2. kyros 8024 3g modem huawei e220
    By marcio in forum Coby Generation 2 Technical
    Last Post: 02-15-2012, 08:01 PM
  3. how to connect huawei E169 usb modem on superpad
    By addeist in forum Gome Flytouch II Variant 2
    Last Post: 10-25-2011, 08:55 AM
  4. Skype 2.0 on CM7 RC1 over 3G using Huawei USB 3G Modem
    By pitks in forum Viewsonic gTablet Technical
    Last Post: 07-14-2011, 12:34 AM
  5. How to use Huawei E156G usb modem
    By shakshak1 in forum Huawei Tablets
    Last Post: 03-12-2011, 06:56 AM
android driver for huawei e173
android drivers for huawei e173
driver e173 android
e173 android
huawei e173 android
huawei e173 android driver
huawei e173 android tablet
huawei e173 driver android
huawei e173 driver for android
huawei e173 problem
huawei e173 problems
huawei e173 troubleshooting
