Results 1 to 8 of 8
Thanks Tree4Thanks
  • 1 Post By J515OP
  • 1 Post By Johna2u
  • 2 Post By LePandroid
Thread: Problem with Le Pan II & Verbatim 97537 Wireless Bluetooth Mobile Folding Keyboard
  1. #1
    Junior Member Achievements:
    500 Experience Points 31 days registered 3 months registered 250 Experience Points 7 days registered
    86235
    Jan 2012
    United States
    7
    Le Pan II
    Problem with Le Pan II & Verbatim 97537 Wireless Bluetooth Keyboard SOLVED
    I was trying to get my Verbatim 97537 BT keyboard with my new Le Pan II and ran into a problem. When I attempt to pair and connect these devices everything works at the beginning. Tablet displays a code, I enter it on the keyboard and afterwards it displays it as "Paired & Coneected". However, when I attempt to type anything with it, keyboard disconnects from the tablet immediately. Did anybody encounter anything like it and/or know of a fix? Keyboard works just fine with my Android 2.3.5 EVO 3D.
    Click image for larger version.
    Ads
    Advertising world
  3. #2
    Points: 7,400, Level: 57
    Level completed: 25%, Points required for next Level: 150
    Overall activity: 0%
    Achievements:
    1 year registered 5,000 Experience Points 3 months registered 1,000 Experience Points 31 days registered
    84893
    Jan 2012
    St. Louis Mo
    474
    Thanked
    49 times
    Points
    7,400
    Level
    57
    iPad2 32, Toshiba Thrive 32. Lenovo IdeaPad A1, ICOO D90W
    Hopefully some one will be able to help you with this.
    My self, I have had little use for any BT devices. The cell ear buds never worked for squat. You pay hi dollar for some and they work 3 months and then won't hold a charge and the place you bought it from wont help you and the manufacturer makes it almost impossible to file a warranty claim. Any who......I hope you get this resolved.
    To all members. Remember to thank those who help you with a problem by clicking on the "Thank" icon/link on the right of the screen in the post.
    It helps us (members) to know that we are actually helping you.
  4. #3
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    You might need to use a bluetooth key board app like Blue Keyboard JP to get it to work https://market.android.com/details?i...oard.ime&hl=en.
    KEHT thanked this.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  5. #4
    Points: 9,697, Level: 66
    Level completed: 12%, Points required for next Level: 353
    Overall activity: 31.0%
    Achievements:
    Veteran 5,000 Experience Points Recommendation Second Class 1 year registered 1,000 Experience Points
    31926
    May 2011
    orangevale ca
    365
    Thanked
    52 times
    Points
    9,697
    Level
    66
    Le Pan II
    I have two le pan II's. I installed the update on one. Bought a bluetooth keyboard today and the one that has been updated connected to the keyboard with no problem. I installed bluekeyboard jp to complete the connection. The other Le Pan that was not updated would pair on first attempt but keyboard wont work and the le pan does not even see it now. I went to install bluekeyboard for that one and the market says it is not compatible with that device. Anybody else have any experience with this?
    KEHT thanked this.
  6. #5
    86235
    Jan 2012
    United States
    7
    Le Pan II
    Quote Originally Posted by Johna2u View Post
    So, there's an issue with Le Pan's bluetooth stack! Now if only I woud've been able to download that update successfully.
    Quote Originally Posted by J515OP View Post
    Thanks!
  7. #6
    Achievements:
    31926
    May 2011
    orangevale ca
    365
    Thanked
    52 times
    Points
    9,697
    Level
    66
    Le Pan II
    I decided to go ahead and update my wifes Le Pan. I guess the update is no longer available.
  8. #7
    250 Experience Points 31 days registered 3 months registered 100 Experience Points 7 days registered
    86240
    Jan 2012
    Atlanta GA USA
    10
    Thanked
    7 times
    Le Pan II, LG Thrive
    I read many posts about the Le Pan II before getting mine and it looked like many were having problems with the update. So when I got mine 3 days ago and saw the update notification I called Le pan support tto ask about it because someone had posted that when they spoke to sopport about it they were told that the update was not ready yet. When I asked about it, he stated that's correct... the update should be ready in about 2 weeks and they will post something on their site to let us know when its ready.
    I hope this helps and good luck with your new tablet
    Johna2u and KEHT thanked this.
  9. #8
    86235
    Jan 2012
    United States
    7
    Le Pan II
    The v118 firmware solved the problem. The two play nice together. If you like to use languages other than English you have to switch to something like MultiLing keyboard and type while the on-screen keyboard is up.
Ads:
  1. Apple wireless bluetooth keyboard and Nook Color... HELP!
    By Rhonda19 in forum Nook Color Technical
    Last Post: 04-26-2012, 01:40 PM
  2. Issues with bluetooth and wireless
    By teh_willis in forum Creative Tablets
    Last Post: 12-13-2011, 05:18 PM
  3. backlit wireless keyboard
    By timpanum in forum Acer Iconia Tab A500 Accessories
    Last Post: 09-20-2011, 11:09 PM
  4. Wireless Keyboard
    By ernieo2 in forum Samsung Galaxy Tab 10.1
    Last Post: 08-18-2011, 08:32 AM
connecting bluetooth keyboard from verbatim to nook hd
folding keyboard
having trouble pairing wireless keyboard lepan tablet
le pan 11 keyboard
le pan ii bluetooth
verbatim 97537
verbatim 97537 bluetooth mobile keyboard
verbatim 97537 connection problem fix
verbatim 97537 pairing problem
verbatim bluetooth mobile keyboard nook hd
verbatim keyboard nook hd
verbatim keyboard not ready to pair
Tags for this Thread
