Results 1 to 4 of 4
  1. #1
    102369
    Mar 2012
    Iowa
    Lepan TC970
    Alternate ways to power on TC970(ADB?)
    I recently got a Lepan TC 970 for free from a friend because the power button was broken on it. After taking apart the case I was unable to reattach the power button so I used the razor part from a box cutter and held it over where the power button was on the circuit board which started the tablet up. I was able to boot it into recovery and flash CWM and Cyanogen mod but the camera was no longer working. After searching around a bit I found a newer version of CM7 with a working camera but I am now unable to use my razor trick to power the tablet on. When I plug it in the battery charging icon comes up so I'm convinced the tablet isn't fully useless.
    Is anyone aware of a way to replace the power button/mechanism on the circuit board or of an alternative method to simply power the tablet on? I haven't had the time to try using ADB to do it but will ADB boot the device even if it is powered off? Thanks for any help you all can give me.
    Ads
    Advertising world
  3. #2
    Points: 14,083, Level: 77
    Level completed: 9%, Points required for next Level: 367
    Overall activity: 0%
    Achievements:
    10,000 Experience Points 1 year registered Tagger First Class 5,000 Experience Points 3 months registered
    87883
    Jan 2012
    Ontario, Canada
    414
    Thanked
    48 times
    Points
    14,083
    Level
    77
    Le Pan TC970, Archos 101, Palm Pre2 webOS, HP Touchpad
    To be able to run ADB, the tablet would need to have USB Debugging turned ON. Since you have CM7 beta installed, that's already on, by default.
    Bad news, I don't think you can connect via ADB to a totally powered off device. Give it a try, 'adb devices' will probably not report any devices attached.
    Regarding the switch substitution, I haven't opened mine, but it should be doable for someone with a good fine tipped soldering iron and the skill to use it.
    you could also consider opening a case with Le Pan tech support (they are in California), and ask if they would replace the switch for you, for a fee even. They list batteries and the cost for replacing them, so maybe you could get them to repair it.
    Is is still under warranty? Probably, as the product was launched around July last year. You would need proof of purchase to request service under warranty, and they also might disqualify it if they think that was accidental breakage, not a component failing issue.
    Good luck! :0
    :: Le Pan TC970 (CM7 Beta) ::: Archos 101T (UrukDroid) ::: Palm Pre2 (webOS 2.2) ::: HP Touchpad (webOS 3, CM9) ::
  4. #3
    112423
    May 2012
    Canada
    Le Pan tc970
    I dropped my Le Pan Tablet on the floor and the power button was smashed. I open it and I saw that the small tini switch was removed from the board, I tried to put it back, but with no luck, I would need to weld it to the board. So I saw a button on the board when I open the board, it's the Reset switch. So to turn on the Table, just use a paper clip and press the Reset button, the table will turn on.
  5. #4
    Points: 9,305, Level: 64
    Level completed: 85%, Points required for next Level: 45
    Overall activity: 23.0%
    Achievements:
    5,000 Experience Points Recommendation Second Class 1 year registered 1,000 Experience Points 500 Experience Points
    31926
    May 2011
    orangevale ca
    364
    Thanked
    52 times
    Points
    9,305
    Level
    64
    Le Pan II
    there is also an app called "fix my broken power button" (no kidding) from what i have read it will make your volume rocker act as a power button. In addition there is a guide on how to repair a broken power button at lepanlife.com
    Sent from my Le Pan II. Most likely while slouching badly on the sofa,
Ads:
  1. Ways to I.D Chinese Epad???
    By garbagecanman in forum Gome Flytouch
    Last Post: 09-07-2012, 12:43 PM
  2. Replies: 0
    Last Post: 01-06-2012, 06:32 PM
  3. Alternate A/C Charger
    By M in KC in forum Coby Tablet Accessories
    Last Post: 07-30-2011, 07:08 AM
  4. Alternate Launcher in 2.2
    By rob_writer in forum Sylvania Tablets
    Last Post: 07-05-2011, 06:10 AM
how to change lepan battery
how to fix power button on le pan tablet
how to turn on tablet without power button
howw to remove battery from le pan
le pan battery replacement
le pan power button not working
le pan tablet broken power button
le pan tablet power button
le pan tablet power button broken
le pan tablet wont turn on
le pan tc 970 replacement charger
where to get a lepan tc970 fixed
