Problems with turning on USB storage
I have an Impression 10-50, and having issues when trying to turn on the USB storage mode. I emailed the corporation, they said to do a factory reset (press & hold the power & camea buttons), but that didntt fix it. Is anybody experiencing the same thing and found the fix?
To reproduce:
- turn on tablet, and unmount sd card
- connect tablet to computer via usb
- turn on usb storage mode on tablet
- keeps hanging, as though the sd card is not there
02-03-2012 02:06 PM
# ADS
I don't have anything constructive to offer BUT going on the first line "- turn on tablet, and unmount sd card" you have removed the sd card? therefore "- keeps hanging, as though the sd card is not there" makes sense IF you have removed it.
