Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
Thanks Tree2Thanks
Thread: Balanced Power - why use it? why not?
  1. #1
    Points: 1,019, Level: 17
    Level completed: 19%, Points required for next Level: 81
    Overall activity: 0%
    Achievements:
    1000 Experience Points 500 Experience Points 31 days registered 250 Experience Points 100 Experience Points
    163401
    Jan 2013
    nc
    178
    Thanked
    38 times
    Points
    1,019
    Level
    17
    lenovo a2109
    I really haven't found much on what this does, other than someone briefly mentioning it should extend battery life but may not be a good trade off if you play games. So, what does it do and are you using it or recommending it for certain types of users? Recommending against it?
    Ads
    Advertising world
  3. #2
    Points: 24,401, Level: 95
    Level completed: 6%, Points required for next Level: 949
    Overall activity: 99.8%
    Achievements:
    3 months registered Overdrive 10000 Experience Points 5000 Experience Points 31 days registered
    162539
    Dec 2012
    466
    Thanked
    223 times
    Points
    24,401
    Level
    95
    ideatabA2109
    Re: Balanced Power - why use it? why not?
    One of those useless items I guess, battery life is solely determined by how it's used and how often
    Sent from my Evo 3D GSM using Tapatalk 2
  4. #3
    Points: 491, Level: 9
    Level completed: 82%, Points required for next Level: 9
    Overall activity: 3.0%
    Achievements:
    3 months registered 31 days registered 250 Experience Points 100 Experience Points 7 days registered
    167243
    Jan 2013
    usa
    56
    Thanked
    8 times
    Points
    491
    Level
    9
    a2109
    I don't use it.. I just adjust my brightness manually, I actually leave it on about 35%.. I leave wifi on always, and get a good 8 - 10 hours solid use.
  5. #4
    Achievements:
    163401
    Jan 2013
    nc
    178
    Thanked
    38 times
    Points
    1,019
    Level
    17
    lenovo a2109
    Quote Originally Posted by dieseltown View Post
    I adjust my brightness manually also. That's a different setting. I am not sure what the balanced power setting actually does, but they must have some reason to have added it.
  6. #5
    Developer
    Points: 13,831, Level: 76
    Level completed: 46%, Points required for next Level: 219
    Overall activity: 99.9%
    Achievements:
    Recommendation Second Class 10000 Experience Points 5000 Experience Points 1 year registered 1000 Experience Points
    Awards:
    Activity Award
    61306
    Nov 2011
    Huntington WV
    2,480
    Thanked
    830 times
    Points
    13,831
    Level
    76
    Coby 9740, Coby 8042, Lenovo A2109
    As far as I know, as the setting does is dim tne lights.
    If you like my work buy me a coffee!!!
    Donations Appreciated
    Due to the overwhelming PM's that I receive, I am unable to answer all the questions and many questions are duplicates so PLEASE post all questions on this forum so I may better help you and any others who are having the same issues.
    No PM's regarding windows questions will be answered, I am a Linux Guy.
  7. #6
    Achievements:
    163401
    Jan 2013
    nc
    178
    Thanked
    38 times
    Points
    1,019
    Level
    17
    lenovo a2109
    It is on the Display page, but there is also a separate brightness setting with the slider and check box for automatic.
  8. #7
    Developer
    Achievements:
    Awards:
    Activity Award
    61306
    Nov 2011
    Huntington WV
    2,480
    Thanked
    830 times
    Points
    13,831
    Level
    76
    Quote Originally Posted by arbarnhart View Post
    Yes, balance power overrides those settings, and adjust brightness to reduce battery use.
    All tegra 3 devices has this setting, I have never read anywhere that the setting did anything beyond adjusting brightness.
    I think if it did more then that, the info would be posted on the internet somewhere.
    arbarnhart thanked this.
  9. #8
    Developer
    Achievements:
    Awards:
    Activity Award
    61306
    Nov 2011
    Huntington WV
    2,480
    Thanked
    830 times
    Points
    13,831
    Level
    76
    This setting is designed for users who don't adjust their brightness, they want the tablet to make the adjustment for them. People who download battery saving apps, most likely would find it useful.
    My battery savings are done at kernel level, lowering the voltage used at each frequency uses less battery life to do same task.
  10. #9
    Achievements:
    163401
    Jan 2013
    nc
    178
    Thanked
    38 times
    Points
    1,019
    Level
    17
    lenovo a2109
    I turned it on on mine and the slider still adjusts the brightness up and down and it doesn't enable the automatic brightness (not checked in the UI, and testing it by taking it from shadow to light the screen doesn't change). I did find the info below about the Tegra in the Transformer Prime:
    The "normal" mode, which will be renamed "performance" in a future update, runs the Tegra 3 at its stock frequency of 1.3GHz. Out of the box, the Prime runs in "balanced" mode, which caps the processor at a slightly slower 1.2GHz. There's also a "power-saver" mode that imposes a series of frequency caps on the CPU. This mode limits the Tegra 3's CPU to 1GHz with one or two cores active, ~700MHz when three cores are active, and ~600MHz when four cores are fired up.
    In a bid to further conserve battery life, the power-saver config switches the screen into a power-efficient operating mode. This mode caps the refresh rate at 35Hz and makes some other changes that result in lower color fidelity. This muted screen setup looks fine with the monochrome hues of my favorite text editor, but any colors displayed elsewhere look dull and washed out compared to the balanced profile. The downgrade in visual quality is severe enough that I'd avoid web browsing or picture viewing in power-saver mode.
    Source: Asus' Eee Pad Transformer Prime tablet - The Tech Report - Page 6
    The odd thing about that is that if I am reading it correctly, on the Prime the balanced mode is not the power saving mode.
  11. #10
    Points: 3,368, Level: 36
    Level completed: 12%, Points required for next Level: 132
    Achievements:
    3 months registered 1000 Experience Points 31 days registered 500 Experience Points 7 days registered
    157423
    Dec 2012
    Florida
    358
    Thanked
    114 times
    Points
    3,368
    Level
    36
    Lenovo A2109
    That might be the case. You get better control with a governor though (over the cpu freqs).
    And I don't like the display quality. Just MHO.
Ads:
  1. Does anyone use power on/off app instead of power button?
    By detz in forum Acer Iconia Tab A500 Forum
    Last Post: 12-25-2012, 11:26 AM
  2. power
    By clint1 in forum Asus TF700 Forum
    Last Post: 08-18-2012, 11:07 AM
  3. MID Power On
    By staylor in forum Android Tablet Q&A
    Last Post: 02-14-2012, 11:18 AM
  4. Flytouch 3 10 inch Android Tablet - Power-up/Power-down ?
    By jonatec in forum Android Tablet Q&A
    Last Post: 10-20-2011, 02:44 AM
  5. no power on
    By giff99 in forum Android Tablet Q&A
    Last Post: 08-20-2011, 09:27 PM
android balanced power
android enable balanced power
android tablet balanced power
balanced power android 4
balanced power on lenovo tablet
balanced power on tablets
balanced power tablet
enable balanced power android
what does enable balanced power mean
what is enable balanced power
??? ????? enable balanced power
