Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thanks Tree1Thanks
Thread: Allwinner A13 7 Inch Tablet Problems
  1. #1
    128200
    Jul 2012
    Hi, I owned an Allwinner A13 7 inch tablet, and I have one app called LuckyPatcher installed, but yesterday when I accidentally restart the tablet, all my data including games/apps gone, just like factory reset.
    1) That is the first time, now everytime I restart the tablet, it perform as if factory reset, all data gone.
    2) And further problems, now I cannot download apps from google play, it stucks at downloading...
    3) I try to install third party apk, but when I install it keeps telling me storage insufficient.
    I suppose all my problems caused by this LuckyPatcher, the tablet is nice, after searching for solutions, to solve problem 3, I should go to data/app folder and delete relevant app's odex file, but I can't seem to find any file inside that folder?
    So I wonder whether the device already been rooted? If not rooted then how to root it? Does reinstall firmware will solve all the problems?
    THANKS IN ADVANCE!!!!
    Regards,
    bizarreaster
    Ads
  3. #2
    Junior Member Achievements:
    500 Experience Points 3 months registered 250 Experience Points 100 Experience Points 31 days registered
    128342
    Jul 2012
    Oxford UK
    9
    unbranded chinese tablet A13(A8 cortex)
    I have two A13(A8cortex) tablets from China.
    One failed after 1 hour of use, Programmes sstopped working.
    Now only boots to android animation and logo and no further.
    Investigating flash of firmware. I have livesuit working and i have the driver installed but looking for the firmware.
    Trying to get it from the source in China but as usual not very helpful.
    There's going to be a need for the firmware as the tablet is going to be sold in thousands.
    I'll let you know when I get the firmware.
    Does your device manager show mass storage device or composute device when you connect the tablet?
  4. #3
    1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    9766
    Dec 2010
    India
    41
    Thanked
    3 times
    Can u guys pls tell me the battery life?
    Sent from my HTC HD7 Pro/+ using Tapatalk 2
  5. #4
    128384
    Jul 2012
    bizarreaster,
    The same thing happened to me after downloading an App from Google Play. There are no USB drivers available. My tablet would always show up as other device in Device Manager. Tried the flashing method posted elsewhere in this forum by McBub to install the drivers and it would not work. The tablet worked nicely before it was trashed by installing the App. Without proper driver support and a method to reflash the tablet, this product is basically a joke. Do yourself a favor and treat it as a learning experience (e.g. never buy a cheap Android tablet from a Chinese vendor). Just bite the bullet and pay a little more for a tablet from a reputable vendor. I finally purchased an Archos 80 G9 and it works flawlessly. If something goes wrong at least I can get waranty support.
  6. #5
    1,000 Experience Points 1 year registered 500 Experience Points 250 Experience Points 100 Experience Points
    24720
    Apr 2011
    Massachusetts
    20
    Thanked
    2 times
    None yet
    Me, I went downmarket and picked up a "loss leader" Polaroid ICS tablet (PMID 702C) @ the Big Lots that just opened in my town. Other than some issues in the browser if it's too busy a page, it's not bad for the $. (Every time I have a complaint, I answer myself with "it was just $80" and move on. No Google Play, had to use google to find out how to get Google: $80; Display a bit grainy because it's only 800x480: $80). I'll use this until Christmas or so, and then get either the Nexus 7, or some other cool 7 incher.
    I won't buy another piece of portable electronics from an overseas seller unless the batteries come out. Nothing like finding out that it would cost more to ship back than replace.
    Sent from my HTC Vision using Tapatalk 2
  7. #6
    128384
    Jul 2012
    Tronmech
    You are lucky. There is a forum for the "upscale" tablets ($80 vs. $69.95),
    [link] Polaroid Tablets
    Try to find anything on the A13 tablets and it's SOL. The A13 is a newer stripped down version of the A10.
  8. #7
    128200
    Jul 2012
    Quote Originally Posted by gordonbell20 View Post
    gordonbell20, yes it shows up as mass storage device as usual and i can still copy files into the tablet, it's just i cannot seem to download from google play, and pops up "insufficient storage available" when i try to install certain apk.
    very frustrating.
  9. #8
    9766
    Dec 2010
    India
    41
    Thanked
    3 times
    Quote Originally Posted by kethan View Post
    Anyone pls?
  10. #9
    Senior Member Achievements:
    150,000 Experience Points 100,000 Experience Points 1 year registered 50,000 Experience Points 25,000 Experience Points
    84844
    Jan 2012
    Shenzhen, Guangdong, China
    465
    Thanked
    40 times
    Ainol NOVO 7 Paladin, NOVO 7 Elf, Samsung Galaxy SII, iPad 2
    Anyone pls?
    Sorry to answer you late.
    About the battery time, it depends on how you use your tablet, and if you want the battery to last longer, you should find some skills, like the change the screen brightness, add some battery control app or what? usually the battery can last about 2-4 hours.
    any questions,feel free to contact us.
  11. #10
    129690
    Jul 2012
    some of the games i download not able to play error as in not compatible.. anyone facing these
Ads:
a13 tablet factory reset
all winner tablet
allwinner a13 battery life
allwinner a13 driver
allwinner a13 factory reset
allwinner a13 hard reset
allwinner a13 hard reset: how to do it?
allwinner a13 tablet battery life
allwinner a13 tablet driver download
china table a13 hard reset tools
china tablet allwinner a13 firmware
drivers for allwinner tablet
