Register Hello & Welcome to Andriodtablets.net, is this your first visit?
Can I Root Without Removing the MicroSD Card?
This is a discussion on Can I Root Without Removing the MicroSD Card? within the Nook Color Technical forums, part of the Nook category; Hi, I've got a NC with software version 1.0.1. I see on NookColor Rooting - nookDevs and the YouTube video below that my computer needs ...
Results 1 to 7 of 7
  1. #1
    Junior Member Achievements:
    7 days registered 31 days registered 3 months registered Tagger Second Class 100 Experience Points
    16915
    Feb 2011
    Fairburn, GA
    12
    Motorola Droid
    Question Can I Root Without Removing the MicroSD Card?
    Hi,
    I've got a NC with software version 1.0.1. I see on NookColor Rooting - nookDevs and the YouTube video below that my computer needs an SD card reader. My computer does NOT have such a reader. Is there a way of rooting without the need for removing the MicroSD card I already have in it? Thanks.
    Marc F.
    www.fergytech.com
    "Let the blind lead the blind... it's more fun to watch."
    Advertising world
  3. #2
    Points: 5,197, Level: 46
    Level completed: 24%, Points required for next Level: 153
    Overall activity: 0%
    Achievements:
    1 year registered 5000 Experience Points 500 Experience Points 1000 Experience Points 250 Experience Points
    12627
    Jan 2011
    Texas
    1,007
    Thanked
    119 times
    Points
    5,197
    Level
    46
    Nook Color
    You need something other than your NC that reads an mSD card. I used my cellphone with success.
    NookColor running CM7
    Darmeen should be spelled Darme'en (for proper pronunciation) *a holdout from my role-playing days...Everyone can call me Vic
    Revert your Nook back to stock and remove CWR
    All you young nooters out there remember to 'Wipe your caches before you flash!'
    http://dl.dropbox.com/u/19975069/thanks.JPG
  4. #3
    Senior Member Achievements:
    7 days registered 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    13256
    Jan 2011
    Western, NY
    800
    Thanked
    53 times
    Nook Color Rooted
    I used the mSD slot on my printer. Nooter needs to be burned to an sdcard. Walmart has some pretty cheap standalone readers.
    Steve = Rooted Nook Color Phiremod 6.1 • Rooted Fascinate
  5. #4
    Achievements:
    12627
    Jan 2011
    Texas
    1,007
    Thanked
    119 times
    Points
    5,197
    Level
    46
    Nook Color
    I bought a Transcend 8GB mSD and it came with this little bitty reader...it works perfectly though.
    Amazon.com: Transcend 8 GB Class 6 microSDHC Flash Memory Card with USB 2.0 Card Reader TS8GUSDHC6-P3: Electronics
  6. #5
    16915
    Feb 2011
    Fairburn, GA
    12
    Motorola Droid
    Quote Originally Posted by darmeen View Post
    Excellent! I thought of using my phone, but then I wondered if I'm still using another device to transfer the data why can't I simply keep the mSD in my NC and continue with the process. Either way I'll use my Droid. Thanks.
    Marc F.
    www.fergytech.com
  7. #6
    16915
    Feb 2011
    Fairburn, GA
    12
    Motorola Droid
    Success! I'm writing you guys from my recently rooted book. The mSD through my cell phone worked just fine. Next mystery to solve is tethering. Thanks again.
    Marc F.
    www.fergytech.com
  8. #7
    13256
    Jan 2011
    Western, NY
    800
    Thanked
    53 times
    Nook Color Rooted
    I am glad it is working! For tethering with a Droid you will have to look for the instructions for Adhoc (in useful links thread) and your Droid will need to be rooted I believe.
Sponsors:
  1. Does 32GB microSD card work in S7?
    By LDW in forum Huawei Ideos S7 Accessories
    Last Post: 04-22-2012, 05:07 PM
  2. Problem with MicroSD card
    By necromonger in forum Coby Generation 1 Accessories
    Last Post: 09-28-2011, 06:12 PM
  3. Flytouch 2 will not read MicroSD card.
    By Alasdair Hutchison in forum Gome Flytouch II Accessories
    Last Post: 04-27-2011, 08:46 PM
  4. Inserting microSD card into Kyros
    By jrsharp21 in forum Coby Generation 1 Accessories
    Last Post: 04-20-2011, 10:55 AM
  5. Good retail MicroSD card for rooting?
    By jwhite in forum Nook
    Last Post: 01-11-2011, 04:22 PM
android tablet
can you root a nook color without a micri sd card
flash nook without microsd card
nook color root microsd class
remove root from nook color
remove sd card when rooting?
root a nook color without an sd card
root nook color without micro sd
root nook color without microsd card
root nook color without sd card
root nook without sd card
taking out micro sd from nook
Tags for this Thread
Copyright © 2012 vBulletin Solutions, Inc. All rights reserved.
