Register Hello & Welcome to Andriodtablets.net, is this your first visit?
[Recovery] Creating a bootable CWR mSD v3.0.1.0 or higher (ext3 & ext4 compatible)
This is a discussion on [Recovery] Creating a bootable CWR mSD v3.0.1.0 or higher (ext3 & ext4 compatible) within the Nook Color Technical forums, part of the Nook category; These are all img files that can be used to create a bootable mSD with the latest ClockWorkRecovery. The *.rar files are just like zips ...
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 49
Thanks Tree11Thanks
Thread: [Recovery] Creating a bootable CWR mSD v3.0.1.0 or higher (ext3 & ext4 compatible)
  1. #1
    Moderator
    Points: 6,960, Level: 55
    Level completed: 5%, Points required for next Level: 190
    Overall activity: 4.0%
    Achievements:
    1 year registered 500 Experience Points 1000 Experience Points 5000 Experience Points 250 Experience Points
    14664
    Jan 2011
    Pittsburgh, PA
    654
    Thanked
    140 times
    Points
    6,960
    Level
    55
    NOOKcolor on CM7 nightly w/ 1.1gHz OC
    These are all img files that can be used to create a bootable mSD with the latest ClockWorkRecovery. The *.rar files are just like zips and should be extracted to *.img before attempting to burn them.
    http://mrm3.net/nook-color-updated-c...y-bootable-sd/
    (link above contains files that continue to be updated)
    Version 3.0.2.8 files are also here
    http://www.mediafire.com/?ql694b9h0w3b82f
    Instructions:
    1. Download one of the bootable files above.
    2. Extract it to a .img file using a program such as winrar or 7zip.
    3. Use win32diskimager to burn the image to a blank SD card.
    4. Place any other zip files on the SD card wich you may use for flashing (ROMs, kernels, stock images, etc.)
    5. Inter your bootable CWR SD car into a powered off Nook and then power on to boot into recovery.
    6. After following proper flashing procedures for your zip files, unmount the card and remove it before rebooting.
    FYI: Real life is really cracking down on me lately, if you need something please PM me here and I will reply asap. Hope to be back in full swing soon.
    [LEFT][B][FONT=Arial][SIZE=2]So You Bought a NOOKcolor, Now What? - aka The Complete Idiots Guide to their first day with a NOOKcolor
    [Step-by-Step] Installing-Updating-Removing CM7
    NC @ 1.1 Ghz [CM7 nightly] mine
    NC @ 1.1 Ghz [autonooter 1.0.1] wife
    T-Mobile G1 flying on CM6.1
    Advertising world
  3. #2
    Moderator
    Achievements:
    14664
    Jan 2011
    Pittsburgh, PA
    654
    Thanked
    140 times
    Points
    6,960
    Level
    55
    reserved for detailed instructions
  4. #3
    Points: 2,509, Level: 30
    Level completed: 40%, Points required for next Level: 91
    Overall activity: 9.0%
    Achievements:
    1000 Experience Points Tagger Second Class
    18757
    Feb 2011
    GREECE
    329
    Thanked
    20 times
    Points
    2,509
    Level
    30
    NOOK COLOR
    Excuse me, but what is the reason to make this if someone has already a ready card with the CWR that was coming with installation of CM7 v3?
    NOOK COLOR ON CM7 Nightly 233
    Kernel :
    OCed @1.200 Mhz
    Cover Case : Tuff-LuvTri-Axis Leather Case
    Quadrant score: 3415
  5. #4
    Moderator
    Achievements:
    14664
    Jan 2011
    Pittsburgh, PA
    654
    Thanked
    140 times
    Points
    6,960
    Level
    55
    Because the CWR on that card is likely only CWRv3.0.0.6 if it was created using the 'ext4 Bootable CWR thread' in preparation for loading CM7. If unsure, just pop that card in and boot with it, see what version is loaded.
    The reason for the update is that v3.0.0.6 was ext4 ONLY, and the new v3.0.1.0 is both ext3 and ext4 -- so you can flash any rom from stock 1.0.1 to CM7 and everything in between with the same card.
    Vichon thanked this.
  6. #5
    Points: 5,197, Level: 46
    Level completed: 24%, Points required for next Level: 153
    Overall activity: 0%
    Achievements:
    1 year registered 5000 Experience Points 500 Experience Points 1000 Experience Points 250 Experience Points
    12627
    Jan 2011
    Texas
    1,007
    Thanked
    119 times
    Points
    5,197
    Level
    46
    Nook Color
    Interesting...I am now wondering if we should update the revert to stock FAQ with the new CWR mSD image
    NookColor running CM7
    Darmeen should be spelled Darme'en (for proper pronunciation) *a holdout from my role-playing days...Everyone can call me Vic
    Revert your Nook back to stock and remove CWR
    All you young nooters out there remember to 'Wipe your caches before you flash!'
    http://dl.dropbox.com/u/19975069/thanks.JPG
  7. #6
    Moderator
    Achievements:
    14664
    Jan 2011
    Pittsburgh, PA
    654
    Thanked
    140 times
    Points
    6,960
    Level
    55
    Quote Originally Posted by darmeen View Post
    Well, really it means updating a lot of things if it is truly stable which I haven't tested myself yet.
    I was thinking about maybe taking this opportunity to combine a few of our [Recovery] write-ups into one good FAQ post. Do you want it? ;-)
  8. #7
    Points: 653, Level: 13
    Level completed: 6%, Points required for next Level: 47
    Achievements:
    20369
    Mar 2011
    Points
    653
    Level
    13
    nook color
    When I boot using this card it is still showing 3.0.0.5. I reimaged the card 2 times.
    Could this have something to do with the fact that I ended up with ROM manager having 3.0.0.5? Even after I did the process in the thread 8114-how-uninstall-clockwork-recovery-revert-stock-image without going back to the stock image since my NC kept rebooting into CWR?
    My setup is NC with 1.1.0, used Autonooter 3.
  9. #8
    Moderator
    Achievements:
    14664
    Jan 2011
    Pittsburgh, PA
    654
    Thanked
    140 times
    Points
    6,960
    Level
    55
    Quote Originally Posted by randomizzer View Post
    That is normal, my belief is that since you are on a ext3 based rom (1.1.0) then CWR acts like it is still v3.0.0.5 even though it really isn't. If you were to flash to an ext4 rom (ie CM7) then CWR would show as v3.0.1.0.
    As long as things are working as desired, don't sweat it.
  10. #9
    Achievements:
    20369
    Mar 2011
    Points
    653
    Level
    13
    nook color
    OK thanks, now I understand better.
    Learning a little bit more each day. Next step will be to try a ROM that is uSD bootable. Not quite ready to dump a ROM on the Nook yet.
  11. #10
    Moderator
    Achievements:
    14664
    Jan 2011
    Pittsburgh, PA
    654
    Thanked
    140 times
    Points
    6,960
    Level
    55
    Ya know, if you aren't then something is wrong...
Sponsors:
  1. Replies: 25
    Last Post: 12-21-2011, 04:33 PM
  2. creating a new folder
    By Dvhampton in forum Toshiba Thrive
    Last Post: 07-13-2011, 04:28 PM
  3. [PoV MobII] Creating your own ROM
    By Mikkass in forum Advent Tablets
    Last Post: 07-12-2011, 07:06 AM
  4. Reverting back after using EXT4
    By revenge8 in forum Nook Color Technical
    Last Post: 03-09-2011, 08:11 AM
  5. Replies: 43
    Last Post: 02-22-2011, 08:24 PM
16 gb bootable cwm 3.2.0.1
16gb clockwork nook
4 gb bootable cwm 3.2.0.1 sd card image
8 gb bootable cwm 3.2.0.1 sd card image download
boot to cwr nook
cwr 3.0.1.0
cwr boot
cwr.img
cyanogenmod nook tablet sd card format ntfs
how to boot tablet from msd
nook color cwr 3.2.0.1 boot loop mac
removecwr.zip mediafire.com
Copyright © 2012 vBulletin Solutions, Inc. All rights reserved.
