Results 1 to 2 of 2
  1. #1
    Junior Member Achievements:
    23799
    Mar 2011
    Nook Color
    Nook SD card Formatting fat32 or ext?
    I just finished setting up the nook with phiremod nook v5.1 and it runs great. I am going to format the 16 gig microsd card and i was wondering what format is the best or should be used. I would like to transfer some apps to it so i can free up the internal memory. Thanks in advance.
    Peace
    Ads
  3. #2
    1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points Tagger Second Class
    17014
    Feb 2011
    Wellington
    52
    Thanked
    5 times
    HTC Wildfire, Barnes&Noble NOOK Color
    all sd cards should use FAT format. high capacity ones like your one should use FAT32
    BARNES&NOBLE NOOKcolor
    stock 1.1 -> rooted 1.1 -> hc v4 on sd -> hc v4 2nd ed on emmc -> cm7 nightly 29 -> cm7 nightly 25 and dual bootable hc with gapps -> monster rooted stock B&N 1.1 -> cm7 video test build
    (all were and are overclocked to 1.1GHz)
Ads:
  1. Formatting Micro SD HC cards
    By gustav2011 in forum Zenithink ZT180 10 Generation 2
    Last Post: 06-30-2011, 05:12 PM
  2. [How To] Access Nook Color SD Card over WiFi !
    By avi in forum Nook Color Technical
    Last Post: 06-04-2011, 04:12 PM
  3. Nook Color Running Android Froyo 2.2 from bootable SD card
    By pcsurgeons in forum Nook Color Technical
    Last Post: 03-27-2011, 05:55 AM
  4. [How To] Access Nook Color SD Card over WiFi !
    By avi in forum Nook Color FAQ
    Last Post: 03-05-2011, 12:02 PM
  5. Rooted Nook Color card upgrade
    By soky157 in forum Nook
    Last Post: 02-01-2011, 06:49 PM
android fat32 ext
can nook tablet read ntfs sd card
fat32 format nook hd tablet
format fat32 apps for nook color tablet
format microsd nook hd
how to format sd card nook color
how to reformat micro sd card nook color
nook color use sd card fat 32 or ntfs
nook hd fat32
nook hd ntfs
nook sd card format
nook tablet sd card format
