This is a discussion on (How To) CM7 Bootable SD within the Nook Color Technical forums, part of the Nook category; Originally Posted by J515OP You are probably going Menu>Settings>Accounts & sync>>Add account>Corporate which is not what you want unless you are actually trying to add ...
That should be a menu choice under Add Account (corporate with google below it). If not I can see why you are having issues.
Nook Color -
(eMMC): CM9 Nightlies
Nook Tablet 16GB: Rooted
VTAB1008: Rooted
Android OS Help & How To
Goes right to add and exchange server.
Nook color 1.3
Autonooter
Android 2.3.3
CyanogenMod-7.1-encore (sideloaded)
I did get the usb working!!
Nook color 1.3
Autonooter
Android 2.3.3
J515OP
Got it working this thread helped a lot [ROM][CM7] Size-agnostic SD Card image and CM7 installer for SD Cards. with updater - xda-developers
One thing I don't have the tablet tweaks in my menu you where talking about adjusting. Thanks again for your help!!!!
Menu>Settings>CyogenMod settings>Tablet tweaks>Choosesoft-buttons: add Home, set others topreference.
Menu>Settings>CyogenMod settings>Tablettweaks>Choose unhide button> Vol+ or Vol-
Nook color 1.3
Autonooter
Android 2.3.3
you don't have tablet tweaks? are you sure you have the latest cm7 encore 7.0.0??
Nook Color running CM7 7.0.2
Nook color 1.3
Autonooter
Android 2.3.3
I am getting stuck at step 4.
When I try to write the image to the usd I get the write error "Not enough space on disk."
But I have a blank 16 gig usd????
Any suggestions appreciated
Edit* I was able to get it going and it works great.
I did some searching and found that for some people (me being one), the img must be in the root of the pc and I had to use the older version of win32 disk img, but was able to make it happen.
Nook Color -
VTAB1008: Rooted
Its much faster than I am and if B&N don't have good apps, it will get the full root.
