Register Hello & Welcome to Andriodtablets.net, is this your first visit?
(How To) CM7 Bootable SD
This is a discussion on (How To) CM7 Bootable SD within the Nook Color Technical forums, part of the Nook category; Got it! Thanks....
Page 37 of 43 FirstFirst ... 27 35 36 37 38 39 ... LastLast
Results 361 to 370 of 421
Thanks Tree48Thanks
Thread: (How To) CM7 Bootable SD
  1. #361
    Points: 856, Level: 15
    Level completed: 56%, Points required for next Level: 44
    Overall activity: 6.0%
    Achievements:
    3 months registered 500 Experience Points 31 days registered 250 Experience Points 100 Experience Points
    66612
    Dec 2011
    Upstate New York
    120
    Thanked
    14 times
    Points
    856
    Level
    15
    Asus TF, Nook Color, Pandigital ereader
    Got it! Thanks.
    Asus Transformer 16 gig with a 16 gig micro sd.
    Nook Color....Rooted!!
    Pandigital E-reader
    Apple I-touch 16 gig
    No android phone, too cheap to pay for the data package!
    Advertising world
  3. #362
    Points: 19, Level: 1
    Level completed: 37%, Points required for next Level: 31
    Overall activity: 0%
    88587
    Jan 2012
    Points
    19
    Level
    Nook Color
    My nook color is running the 1.3.0 OS I've did everything on the guide and this is not working for me. is there any other way to root it? Or is there any other file I should download to root my nook?
  4. #363
    Points: 22, Level: 1
    Level completed: 43%, Points required for next Level: 28
    89024
    Jan 2012
    USA
    Points
    22
    Level
    NOOKcolor
    I followed the instructions, got as far as 10, and when I powered the Nook back on, it just booted right into Nook. Didn't get the CM7 boot screen. My device is running v.1.4.1 of the Nook OS. Any thoughts?
  5. #364
    88587
    Jan 2012
    Points
    19
    Level
    Nook Color
    I know that the 1.4.1 os wont let you side load anything what i did was that I had to go back to a 1.4.0 to be able to side load here is the website i used to go back to a 1.4.0 on one of my nooks. [Stock Firmware]Restore Barnes & Nobel Nook 1.4.0 from SDCard - xda-developers
    I just need to figure out how to make one of my nooks go from a 1.3.0 to a 1.4.0 or a 1.2.1.
  6. #365
    Points: 1,057, Level: 17
    Level completed: 57%, Points required for next Level: 43
    Achievements:
    1000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    34054
    Jun 2011
    160
    Thanked
    12 times
    Points
    1,057
    Level
    17
    Nook Color
    Quote Originally Posted by skwaaone View Post
    The last poster is talking about using CM7. 1.4.1 has no effect on CM7. You can still boot from a card.
    CM7 nightly (currently 201)
    "The needs of the many outweigh the needs of the few (or the one)."
  7. #366
    Points: 2, Level: 1
    Level completed: 3%, Points required for next Level: 48
    90351
    Feb 2012
    Points
    Level
    Quote Originally Posted by christopherjohnson74 View Post
    I had exactly the same problem, and found it was down to installing CM7 and Gapp at the same time, it's like the SD is not bootable once you do this.
    I'm sure this will be fixed soon with a different build, but to get over it, I installed CM7 and gapps separately, and all worked fine.
    So for me, I followed the instructions on the first page 1 to 10, but only copy the CM7 zip file NOT the gapp zip to the SD card.
    Once running CM7, make sure you setup WiFi, this is very important otherwise the next step will fail and get caught in an install loop.
    Power off, install the SD card in your PC again and copy the gapp zip file to the root directory.
    Now power up the Nook in "recovery mode". Probably best to google this procedure, but it's press and hold the N button and power button until device starts to boot. Once booted into a boot option screen, select recovery mode on SD card, and you will see the install app running again, as you did in step 7. This installs gapps. Once it finishes, continue onto step 10 on the first page.
    If it get's stuck in an enter language loop then WiFi is messed up.
  8. #367
    Points: 31, Level: 1
    Level completed: 62%, Points required for next Level: 19
    Achievements:
    7 days registered
    90595
    Feb 2012
    Points
    31
    Level
    CM7 on a Nook Color
    I just want to give a big shout out to J515OP for all the info. Admittedly it took me a week to successfully accomplish it, but I'm now running CM7 on my Nook Color. The first couple of times I tried it, I only booted into stock Nook....third time was a charm, and I think it was because I wasn't using WinImager correctly (not as admin)...now to learn all about Android and figure out how to accomplish dual booting...I've heard it can be done...
  9. #368
    Points: 164, Level: 3
    Level completed: 28%, Points required for next Level: 36
    Overall activity: 2.0%
    Achievements:
    7 days registered 31 days registered 100 Experience Points
    90815
    Feb 2012
    Dj :D
    9
    Points
    164
    Level
    Nook Color
    hello,
    Ii have now sd with only 115MB max size instead 8GB. Need a advice how to increase size to max as previously. I have 8 mSD Kingston and with it it runs very smoothly. And CM7 is damn nice, because CM7 makes it more better Android Tablet than before, so high speed... etc. And another problem, somehow battery life is decreasing pretty a lot, even I closed any applications, but it seems it doesn't help.
    Quote Originally Posted by sheepshagger View Post
    And with your post it helped me a lot, cause I had same problem like you. Thanks again for tip
    So I have one problem.... After plug in to re-charge battery, touch screen is somewhat different, like unrensposive or going crazy just going to anywhere. But when I plug it to computer, it behaves good.
    Btw, how to wipe battery stats and recalibrate with it again?
    Thanks for CM7 development and let's meet again
  10. #369
    Points: 364, Level: 7
    Overall activity: 14.0%
    Achievements:
    250 Experience Points 31 days registered 100 Experience Points 7 days registered
    94910
    Feb 2012
    east islip n.y
    41
    Thanked
    1 times
    Points
    364
    Level
    7
    i saw on eaby somebody selling cm7 cards if i get my nook color should i buy from him he is good feed back
    this will save me a lot of time lol its got ics and ginger bread on the card
  11. #370
    Points: 43, Level: 1
    Level completed: 86%, Points required for next Level: 7
    Overall activity: 4.0%
    96058
    Feb 2012
    Midwest US
    Points
    43
    Level
    Nook Color
    Hi folks. I need a bit of help here. I just got an 8GB Nook Color and I wanted to boot CM7 from an MicroSD card to avoid having issues with the existing OS. I used the procedure outlined in the first message of this thread, but aftr using the disk image writer, the 16GB Class 10 Samsung MicroSD card I got only had 117MB of space in the primary partition. Whats more, Disk management would not let me delete the partition, or partition the unallocated space. I eventually found an SDformat program which did get all 16GB accessible again, but again, when I tried again, the same thing happened. I really don't want to just buy a pre-rooted card, they are just too expensive so I really want to do this myself. I am running Windows 7 Ultimate on my systems here. Oh and I tried it on different systems on my home lan, but the results were the same. I hope someone has a fix for this. I eagerly await a response and thanks in advance.
    Rich
Sponsors:
  1. [Firmware] Debian v0.3 for Flytouch SD bootable.
    By tipstir in forum Gome Flytouch Firmware
    Last Post: 02-20-2012, 04:16 PM
  2. Question re: Bootable - vs installed ROM?
    By Candlestick in forum Nook
    Last Post: 04-04-2011, 06:16 PM
  3. Looking for Bootable CWR Image link
    By bobsilver in forum Nook Color Technical
    Last Post: 03-17-2011, 04:47 PM
  4. [ROM] CM7 SD Bootable, w/ experimental BT working.
    By lifeisfun in forum Nook Color Technical
    Last Post: 03-11-2011, 01:39 PM
  5. [Q] ADB not recognizing my Nook (Mac OSX, Bootable HC v4)
    By arrjaytea in forum Nook Color Technical
    Last Post: 03-11-2011, 10:28 AM
boot cm7 from sd nook color
cm7 bootable sd
cm7 bootable sd nook color
generic-sdcard-v1.2.1.img
nook color boot from sd
nook color boot from sd cm7
nook color cm7 sd
nook color cm7 sd card
run cm7 from sd card on nook color
update-cm-7.0.0-encore-signed.zip
update-cm-7.0.3-encore-signed.zip
update-cm-7.1.0-encore-signed.zip
Tags for this Thread
Copyright © 2012 vBulletin Solutions, Inc. All rights reserved.
