Register Hello & Welcome to Andriodtablets.net, is this your first visit?
(How To) CM7 Bootable SD
This is a discussion on (How To) CM7 Bootable SD within the Nook Color Technical forums, part of the Nook category; xda Instructions: [ROM][CM7] Size-agnostic SD Card image and CM7 installer for SD Cards. with updater - xda-developers CM7 Releases: Latest Version - CyanogenMod Wiki (scroll ...
+ Reply to Thread
Page 1 of 37 1 2 3 11 ... LastLast
Results 1 to 10 of 368
Thanks Tree41Thanks
Thread: (How To) CM7 Bootable SD
  1. #1
    Moderator
    Points: 16,964, Level: 83
    Level completed: 23%, Points required for next Level: 386
    Overall activity: 64.0%
    Achievements:
    1 year registered 10000 Experience Points 5000 Experience Points 1000 Experience Points 500 Experience Points
    12338
    Jan 2011
    Northern CA
    2,826
    Thanked
    426 times
    Points
    16,964
    Level
    83
    Exclamation (How To) CM7 Bootable SD
    (scroll to bottom for google apps)
    1. Download generic-sdcard-v1.3 img and unzip thefile.
    2. Download update-cm-7.1.0-encore-signed zip file (CM7 stable).
    3. Download gapps-gb-20110828-signed zip file(latest google apps).
    4. Burn the unzipped generic-sdcard image to sd card using Win 32Disk Imager.
    5. Copy update-cm-7.1.0-encore-signed and gapps-gb-20110828-signedzip files to SD card. *Do not change the file names.*
    5a. *Optional* If you want to run an overclock kernel you need to choose and download a compatible kernel for SD (not eMMC).
    5b. Move the uImage file from the SD card to your pc as a backup.
    5c. Rename the oc kernel you have downloaded uImage copy it to the SD card.
    6. Power down Nook and insert SD Card.
    7. Power on Nook and wait for CM7 boot program to run.
    8. Program will say install finished “It is safe to power off now” but wait until the screen goes blank.
    9. Hold power button for 10 seconds to power down Nook.
    10. Power up Nook.
    11. You will see blue text Android followed by CM7boot screen followed by a choice of com.android.provision.DefaultActivity or Setup Wizard.
    12. Choose Setup Wizard.
    13. Touch the Android to begin.
    14. Choose skip at google account.
    15. Choose next use location.
    16. Select time zone, check automatic then next.
    17. Press the n button.
    18. Then Menu>Settings>Wireless & networks>Wi-Fi settings and connect to your network.
    19. Once connected use the Back button twice.
    20. Choose Accounts & sync from the menu. Add account>Google.
    21. Choose next.
    22. Sign in with your Google account.
    23. Click OK.
    24. Select the Google apps to install (recommend Gmail, Google Maps, Google Voice andYouTube). Click OK.
    25. Click Accept.
    26. Click each selected app to download it.
    27. Choose if you want to use backup & restore, click next.
    28. Click Finish setup.
    You have now completed the major portion of the setup and can run CM7 J
    Extra setup -
    Menu>Settings>CyogenMod settings>Performance>CPUsettings>Max CPU frequency: 925MHz, Set on boot checked.
    Menu>Settings>CyogenMod settings>Tablet tweaks>Choosesoft-buttons: add Home, set others to preference.
    Menu>Settings>CyogenMod settings>Tablettweaks>Choose unhide button> Vol+ or Vol-
    Menu>Settings>Applications: Check Unknown sources
    Menu>Settings>ADWLauncher>Screenpreferences>Deskto p Columns: 8
    *Note according to micro SD card tests on the XDA forum choosing a card with a high small block Random Write speed (QD32) may result in performance increases in running bootable ROMs from a micro SD card while cards with poor QD32 performance may have issues with speed and force closing. For further information check this thread here http://forum.xda-developers.com/show...2&postcount=87 and the table listing tested QD32 speeds https://docs.google.com/spreadsheet/...lRDJQTEE#gid=0.
    Last edited by J515OP; 12-06-2011 at 06:25 PM. Reason: Added optional OC instructions
    DeeMat, AnimaTechnica, Abb0nz and 15 others thanked this.
    (SD): 1. CM7 7.1.0 RC1, 2. CM7 7.0.3 Encore
    (eMMC): CM9 sneakpeek2-fullofbugs
    Backups: Rooted Nook - Restored back to Rooted 1.0.1 - OC 1100MHz omap 3630; Flashed to Nookie Comb OC from Phiremod BETA 2 from Rooted 1.0.1 - OC 1100MHz omap 3630
    VTAB1008: Stock 1.4
    Advertising world
  3. #2
    Moderator
    Achievements:
    12338
    Jan 2011
    Northern CA
    2,826
    Thanked
    426 times
    Points
    16,964
    Level
    83
    First impressions of CM7 stable are great! This really gives you a tablet feeling and very much takes on the feeling of honeycomb in that regard. Runnung a 4GB Class 10 SD card and multitasking/switching tasks is slow but runs great once you are in the apps.
    I can see why so many people are happy with CM7 and this is a great way to try it out or have your tablet system and keep autonooter on eMMC for Nook functions.
    JP
    VTAB1008: Stock 1.4
  4. #3
    Points: 772, Level: 14
    Level completed: 72%, Points required for next Level: 28
    Overall activity: 2.8%
    Achievements:
    7 days registered 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    22962
    Mar 2011
    MD
    67
    Thanked
    2 times
    Points
    772
    Level
    14
    Quote Originally Posted by J515OP View Post
    JP
    I have a 16gb class 6 Transcend coming in the mail soon. I may try to run CM7 from the card and use my autonooter on the emmc. It just all depends on how smooth cm7 runs from the class 6 card though.
    Nook Color running CM7 7.0.2
  5. #4
    Junior Member Achievements:
    26891
    Apr 2011
    Hi,
    Stupid noob question. Can I use the remaining space of the SD card to store files/vids/etc? Do I need to partition it first?
    Thanks.
  6. #5
    Points: 3,520, Level: 37
    Level completed: 14%, Points required for next Level: 130
    Overall activity: 0%
    Achievements:
    1 year registered 1000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    17371
    Feb 2011
    A very small Island, Planet Earth
    528
    Thanked
    46 times
    Points
    3,520
    Level
    37
    Quote Originally Posted by nabwong View Post
    Hi,
    Thanks.
    No need to partition the "Size Agnostic" CM7 SD rom will leave the rest of the SD available for storage.
    NookColor- CM7 @1.3ghz,
    HTC Aria-CM7
  7. #6
    Achievements:
    22962
    Mar 2011
    MD
    67
    Thanked
    2 times
    Points
    772
    Level
    14
    Quote Originally Posted by LocalStain View Post
    How do you apply an overclock kernel to a bootable SD? I know CM& runs at 925, but how do we apply the latest updates from dalingren?
    edit: nevermind. i found there is a kernel designed specifically for the SD.
    should i wipe dalvik cache and cache partition before wiping this? Wouldn't that affect my emmc instead of the sd card setup?
  8. #7
    26891
    Apr 2011
    Much appreciated. Thanks.
  9. #8
    Moderator
    Achievements:
    12338
    Jan 2011
    Northern CA
    2,826
    Thanked
    426 times
    Points
    16,964
    Level
    83
    Quote Originally Posted by bluewhite79 View Post
    Yes, use the kernels for SD and no, don't wipe anything. Everything is contained on the SD and you are correct that wiping would only wipe eMMC.
    JP
    VTAB1008: Stock 1.4
  10. #9
    Achievements:
    22962
    Mar 2011
    MD
    67
    Thanked
    2 times
    Points
    772
    Level
    14
    JP
    so, once i place the OC.zip onto the root of the bootable SD, how do I "flash" it?
  11. #10
    Moderator
    Achievements:
    12338
    Jan 2011
    Northern CA
    2,826
    Thanked
    426 times
    Points
    16,964
    Level
    83
    From the XDA thread, verygreen explains it. I have added the emphasis in bold.
    OC Kernel installation instructions:
    After you have a running CM7 by doing the steps above.
    Get CM7 OC kernel from Dalingrin's thread. Unpack the zip file, the result should be a file with the name "kernel" and some other stuff. Rename the kernel file to uImage.
    Shutdown your nook and take the uSD card out (make sure the nook is not plugged into USB bus or it'll boot into eMMC then).
    Plug the SD Card into the computer, copy uImage file you just created to the first partition (the partition name would be "boot") instead of the existing file with this name (might want to save the original file just in case).
    Now you are ready to go again.
    You'll need to repeat these steps every time you upgrade to a new nightly build, because they carry their own kernels with them.
    I haven't tried it yet myself and not sure if I will geven that the limiting factor is probably the SD card more than the kernel speed in this case. You might want to run some bench marks before and after and see if you notice a difference.
    JP
    VTAB1008: Stock 1.4
+ Reply to Thread
Sponsors:
  1. [Firmware] Debian v0.3 for Flytouch SD bootable.
    By tipstir in forum Gome Flytouch Firmware
    Last Post: 02-20-2012, 05:16 PM
  2. Question re: Bootable - vs installed ROM?
    By Candlestick in forum Nook
    Last Post: 04-04-2011, 07:16 PM
  3. Looking for Bootable CWR Image link
    By bobsilver in forum Nook Color Technical
    Last Post: 03-17-2011, 05:47 PM
  4. [ROM] CM7 SD Bootable, w/ experimental BT working.
    By lifeisfun in forum Nook Color Technical
    Last Post: 03-11-2011, 02:39 PM
  5. [Q] ADB not recognizing my Nook (Mac OSX, Bootable HC v4)
    By arrjaytea in forum Nook Color Technical
    Last Post: 03-11-2011, 11:28 AM
boot cm7 from sd nook color
cm7 bootable sd
cm7 bootable sd card
cm7 bootable sd nook color
cm7 nook color sd
cm7 nook color sd boot
cm7 nook color sd card
cm7 sd card nook color
dual boot nook color cm7 sd card
generic-sdcard-v1.2.1.img
nook color boot from sd cm7
nook color cm7 bootable sd card
nook color cm7 sd
nook color sd boot cm7
run cm7 from sd card on nook color
update-cm-7.0.0-encore-signed.zip
update-cm-7.0.3-encore-signed
update-cm-7.0.3-encore-signed.zip
update-cm-7.1.0-encore-signed.zip
Tags for this Thread
Powered by vBulletin® Version 4.1.7
Copyright © 2012 vBulletin Solutions, Inc. All rights reserved.
