Results 1 to 2 of 2
  1. #1
    Member Achievements:
    20425
    Mar 2011
    mississippi
    60
    nookcolor
    Nook Color Running CM7 Won't connect
    Hi
    I rooted my NC using the CM7.. it took me awhile to get used to it, but now?? I dearly love it!! However, a couple of days ago, it just quit connecting to the internet.
    I had this problem once before, but I have deleted all the Internet Options, uncluding Cache....plus one guy suggested I go to the ROM Manager, and go to Fix Permissions and so I did that. But, still it will not connect.
    I fear I am in for a unrooting process..... any suggestions?
    Rhonda
    Ads
    Advertising world
  3. #2
    Points: 8,762, Level: 63
    Level completed: 4%, Points required for next Level: 288
    Overall activity: 0%
    Achievements:
    Veteran 5,000 Experience Points 1 year registered 1,000 Experience Points 500 Experience Points
    6391
    Nov 2010
    california
    791
    Thanked
    63 times
    Points
    8,762
    Level
    63
    Droid, Haipad 701, Rooted Nook Color
    Rhonda this might be a case of airplane mode turning on and not being able to toggle back - to fix this open up the terminal emulator (it's in your app drawer)
    type the following (press enter after each line)
    su
    sqlite3 /data/data/com.android.providers.settings/databases/settings.db
    delete from system where name = 'airplane_mode_on';
    .exit
    here's where that was discussed - [Kernel][Eclair][Froyo][CM7] Dalingrin's OC kernel [4/04/11] - Page 196 - xda-developers
    Quote Originally Posted by Rhonda19 View Post
    Hi
    Rhonda
    Support my latest project - ACROSS TOWN - a graphic novel styled animated drama about the tragic consequences of gang violence
Ads:
  1. Installing the Android Market on the Nook Color running Honeycomb:
    By dandroid in forum Nook Color Apps and Games
    Last Post: 03-29-2012, 11:40 AM
  2. Replies: 0
    Last Post: 04-26-2011, 02:53 PM
  3. Nook Color running CM7 won't connect
    By Rhonda19 in forum Nook Color Technical
    Last Post: 04-13-2011, 10:14 AM
  4. Nook Color Running Android Froyo 2.2 from bootable SD card
    By pcsurgeons in forum Nook Color Technical
    Last Post: 03-27-2011, 05:55 AM
  5. Replies: 6
    Last Post: 02-06-2011, 06:49 PM
android market wont load on wifi nook color
cm 7 rooted my nook cant connect to wifi
cm7 nook wont connect to wifi
cyanogen nook will not connect to internet
cyanogenmod nook won't connect to internet
i've rooted my nook color and now the wi-fi wont turn on
nook color cyanogenmod 7 wifi working but won't connect to internet
nook wont connect to market
rooted nook color wifi wont connect
rooted nook color wont connect to pc
rooted nook will not connect to internet
rooted nook wont connect to internet
