Results 1 to 7 of 7
Thanks Tree1Thanks
  • 1 Post By gbeardmore
Thread: How to copy corrupted SD card?
  1. #1
    Senior Member Achievements:
    1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points Tagger Second Class
    18757
    Feb 2011
    GREECE
    329
    Thanked
    21 times
    NOOK COLOR
    Post How to copy corrupted SD card?
    It seems that my current SD card, of the sudden started to have lags at some games.
    Only way to come back to normal, is to reboot my NOOK.
    I think that its time to replace my current card.
    Can I just copy all data from this card to another through PC and then put the new card back to Nook for normal use?All apps would work fine?
    NOOK COLOR ON CM7 Nightly 233
    Kernel :
    OCed @1.200 Mhz
    Cover Case : Tuff-LuvTri-Axis Leather Case
    Quadrant score: 3415
    Ads
    Advertising world
  3. #2
    Junior Member Achievements:
    22308
    Mar 2011
    Green Bay, WI
    16
    Thanked
    1 times
    Nook Color (1.1.0 Rooted - 1100 Mhz)
    Quote Originally Posted by RASTAVIPER View Post
    Here's a thought before you go out and buy a new card. How 'bout you back everything up with Titanium Backup to Dropbox. Then try reformatting your card right in your Nook. Restore from your Dropbox TB and give it a whirl.
    If it still misbehaves then it's probably time for a new (faster?) card.
    RASTAVIPER thanked this.
  4. #3
    1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    13582
    Jan 2011
    Montana
    106
    Nookcolor& Droid 2 (Froyo)
    Thought I would ask while my NC is backing up in TB, how do you save the backup in drop box?
    Sent from my DROID2 using Android Tablet Forum
    :-)CLS(-:
    Nookcolor Rooted! Yea!
  5. #4
    22308
    Mar 2011
    Green Bay, WI
    16
    Thanked
    1 times
    Quote Originally Posted by CLSmith View Post
    Don't remember exactly, but you need 2 things. You need a Dopbox account and the paid Pro version of TB. After yu have Dropbox set up, start TB and click the menu icon. Go to Preferences and check Enable Dropbox. You'll figure it out from there. Good luck with the SD card!
  6. #5
    1 year registered 5,000 Experience Points 500 Experience Points 1,000 Experience Points 250 Experience Points
    12627
    Jan 2011
    Texas
    1,007
    Thanked
    119 times
    Nook Color
    Or just copy the entire contents of your card to your PC, reformat the card in your NC, move the files back and see if it helps. Its kinda like defragging your SD Card to help with speed issues.
    NookColor running CM7
    Darmeen should be spelled Darme'en (for proper pronunciation) *a holdout from my role-playing days...Everyone can call me Vic
    Revert your Nook back to stock and remove CWR
    All you young nooters out there remember to 'Wipe your caches before you flash!'
    http://dl.dropbox.com/u/19975069/thanks.JPG
  7. #6
    18757
    Feb 2011
    GREECE
    329
    Thanked
    21 times
    NOOK COLOR
    Thank U all for your replies.
    The matter is a bit complicated, as it seems the lag it happens only at Townspeople6 game.I thought it was a problem of the card, cause in Vplayer also in videos started having black screens, but after some uninstall and reinstall of Vplayer, everything fine there.
    So since I dont see any other problems with other apps, then I think its not a problem of the card.
    Anyway, all the opinions here helped with knowing more about what to do in the future.
    Darmeen are U sure that just by copying the card to pc and back to the card, everything should work?The same can happen with other card or maybe Nook marks a card when its using it?
    Also, very useful info about Titanium and Dropbox.I would give it a try.
    Kernel :
    OCed @1.200 Mhz
  8. #7
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    You can copy data from a card to the pc and back to any other card. The nook doesn't do anything special to distinguish one card from another. The only problem you might have with that method is if your files are corrupted then coping to your pc and back to an SD card will mean you are just copying corrupted files back and forth to the new or cleaned SD.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
Ads:
  1. How to copy files to SD card
    By crusty in forum WonderMedia WM8505 Tablets
    Last Post: 03-31-2012, 03:59 AM
  2. Avoiding Corrupted Boot Partition and BSOD
    By ElectronikBrain in forum Nook Color Technical
    Last Post: 03-07-2011, 08:35 AM
  3. internal micro SD card copy requested
    By ksporry in forum Freescale Based
    Last Post: 02-25-2011, 11:27 PM
  4. How do you copy files to Tablet SD card??
    By basil281 in forum Android Tablet Q&A
    Last Post: 02-25-2011, 12:44 PM
  5. Way to copy files from sd card to external hard drive?
    By okiediver in forum Gome Flytouch
    Last Post: 02-04-2011, 11:04 PM
back up damaged sd card
backup corrupted sd card
backup damaged sd card
can you clone n2a card to use on another computer
cannot copy files to corrupt android sd card
copy damaged sd card
copy n2a card
copying corrupt sdcard
how to backup sd card that is damaged
how to clone a n2a card?
how to restore a corrupt sd card in kindle fire
reinstalling a n2a card from nook
