Results 1 to 6 of 6
  1. #1
    Junior Member Achievements:
    28710
    May 2011
    9
    Nook Color auto rooted
    Unhappy CM7 Nook Color apps running sluggish
    Hey there guy's I've rooted 2 nooks(mine and my wife's) with the information you have posted here for us noobs and I thank you for all you help. Yesterday I was playing Zenonia2 on my nook and noticed that it was running sluggish I had been playing it for 2 day's before and everytime it ran smooth, so I rebooted and still the same thing so I tried running another program HeavyGunner,(the selection screen lags it used to run smooth), Doubletwist(this one tried to watch a movie and the movie was twitchy start-stop for a second and keeps going like that.)
    I'm running kernel version 2.6.29-omap1, have 178mb/of 488mb available, CyanogenMod-7.0.2-encore, Android version 2.3.3 Build number GRI40.
    I did set the cpu to 300min and 925max also done before this issue.
    thanks for you help on this.
    Jack
    Ads
  3. #2
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Sometimes you will experience slowdowns. Speed depends on a lot of things. Maybe you were downloading or updating new apps in the background? Maybe email was downloading, Facbook was updating, Pulse was pulling in new feeds and your calendar was syncing. There is also a chance that you are running a memory intesive app and don't know it. Or that an app has gone rouge or has a memory leak.
    The point is that there is probably is no easy answer since it could be many things causing a general slow down. You can check to see if a particular app is being a resource hog and then kill it and see if that helps. If that doesn't work and over a prolonged period of time you still find the nook running sluggish you can try a fresh install of the ROM.
    JP
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  4. #3
    28710
    May 2011
    9
    Thanks J5150P for the information on my issue, after I posted this message my nook was back to running fine no issues...so I'm glad to know that it is possible to do a fresh install again.
    Smilnjack27
  5. #4
    Senior Member Achievements:
    1 year registered 500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points
    15075
    Jan 2011
    493
    Thanked
    31 times
    Nook Color
    When mine does that, I kill everything running with my app killer. Usually fixes it right up.
  6. #5
    1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    30169
    May 2011
    Ohio
    48
    Nook Color, Viewsonic G-Tab
    Not to overuse a cliche, but I believe there's an app for that. You need an app that shows which processes are running and how much of the CPU is being used by each. If it is an unecissary process, you can kill it off. Just like the Windows Task Manager. I don't think you need to do a fresh install, and I'm not sure that it would help. You probably just have a hoggish app running in the background.
  7. #6
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Just in case my post is being taken out of context, I am not suggesting that you jump to flashing a clean ROM. Yes there are ways to see how the apps are using resources. First see if the sluggishness is temporary and goes away in a reasonable amount of time. If not check your resources and see if closing some apps helps.
    If neither of those work and your Nook is just slow all of the time then you might consider flashing a new ROM or kernel (sometimes you can have worse perfomance if you flash a new kernel and it turns out to be a dud).
    JP
    Nexus 7
    Nook Color -
Ads:
  1. Installing the Android Market on the Nook Color running Honeycomb:
    By dandroid in forum Nook Color Apps and Games
    Last Post: 03-29-2012, 11:40 AM
  2. Nook Color Running CM7 Won't connect
    By Rhonda19 in forum Nook Color Technical
    Last Post: 04-30-2011, 12:50 AM
  3. Nook Color running CM7 won't connect
    Last Post: 04-13-2011, 10:14 AM
  4. Nook Color Running Android Froyo 2.2 from bootable SD card
    By pcsurgeons in forum Nook Color Technical
    Last Post: 03-27-2011, 05:55 AM
  5. Replies: 19
    Last Post: 01-21-2011, 08:57 AM
cm7.2 nook color slow
nook color cm7 runs slow
nook color cm7 sluggish
nook color cm7 very slow
nook color root slow
nook color rooted slow
nook color running cm7 is slow
nook color running slow
nook running slow
rooted nook color running slow
rooted nook color slow
why is my cm7 nook laggy?
