Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    61258
    Nov 2011
    Nook Rooted CM7
    I'm running CM7 on my nook from the microsd card. I'm not really a geek, just newbie. Can i do this to my CM7 to fix the mono sound ?
    Ads
  3. #12
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    The Nook only has one speaker so it will always be mono. This fix just mixes both L and R so you don't get only the default one as well as increasing the sound out put. So you hear both L and R instead of only one or the other but they are still mixed into a single source and come from a single speaker.
    Most of the time you won't notice one of the channels is missing since most media doesn't have that much channel separation but on occassion you'll get something that sounds funny because they are explointing the use of a L and R channel for a specific effect.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
Ads:
  1. Replies: 28
    Last Post: 05-05-2012, 11:53 AM
  2. Replies: 10
    Last Post: 03-30-2011, 01:59 PM
  3. Run Honeycomb From Nook Internal Memory
    By WenWM in forum Android Tablet News
    Last Post: 02-06-2011, 09:59 AM
  4. You can install Nookie Froyo to the Nook internal memory
    By csrabear in forum Nook Color Technical
    Last Post: 01-20-2011, 08:57 PM
android mono downmix
how do i make my nook louder
how to increase volume on nook color
how to make nook color louder
how to make nook hd louder
how to make nook louder
how to make sound louder on my nook
how to make sound louder on my nook book
how to make the sound louder on my nook hd
make nookcolor sound louder
nook color sound too soft cm10
nook color volume boost
