Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thanks Tree1Thanks
Thread: How do I fix a broken Market?
  1. #1
    Member Achievements:
    7 days registered 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    26104
    Apr 2011
    Post Falls, ID
    33
    Nook Color
    Question How do I fix a broken Market?
    Updated to 1.2 B&N
    Rooted CWM
    Loaded CM7 7.0.3 with 2011-03-07 gapps.
    Android Market will not download.
    Re-imaged to 7.0.2 and same behavior (WiFi working strongly on both attempts BTW)
    Now trying nightly CM7 build #75. If that does not work, I'll try Phiremod 6.2.
    What can be done to fix a broken Android Market? Why does it allow me in, choose apps, and then no downloads? So frustrating.
    My other Nook Color is setup the same, running 7.0.3 and works great!
    Nook Color (rooted)
    Sprint EVO 3D
    Ads
    Advertising world
  3. #2
    Senior Member Achievements:
    13256
    Jan 2011
    Western, NY
    800
    Thanked
    53 times
    Nook Color Rooted
    Try going into manage apps/select market then clear cache/data. Then see if it lets you sign back into market.
    Sent from my fascinate
    Steve = Rooted Nook Color Phiremod 6.1 • Rooted Fascinate
  4. #3
    Points: 69,894, Level: 100
    Overall activity: 100.0%
    Achievements:
    Recommendation First Class 1 year registered Overdrive Tagger First Class 50000 Experience Points
    23311
    Mar 2011
    Chicago, IL
    10,257
    Thanked
    1117 times
    Points
    69,894
    Level
    100
    NOOK Tablet Stock NOOKcolor Rooted & ManualNooted
    If it's important to you, you'll find a
    way. If not, you'll find an excuse.
    If you're too busy for friends,
    You're too busy.
    Attention lurkers! Join the forum,
    and enter Spider into the referrer
    field of the application.The $0.00
    USD fee will be waived.
    People will forget what you said.
    People will forget what you did.
    But, people will never forget
    how you made them feel.
  5. #4
    1000 Experience Points Tagger Second Class
    18757
    Feb 2011
    GREECE
    329
    Thanked
    21 times
    NOOK COLOR
    Also try from Applications, to Uninstall Updates for MARKET.
    NOOK COLOR ON CM7 Nightly 233
    Kernel :
    OCed @1.200 Mhz
    Cover Case : Tuff-LuvTri-Axis Leather Case
    Quadrant score: 3415
  6. #5
    70144
    Dec 2011
    United States
    Nook color
    I have a Nook color rooted with the RootMyNookColor preconfigured microSD chip. Everything works fine except when I try to download an app from the Android Market Place, I can choose the App click download and click Install and click Accept and Download then after a moment I get a message that the app cannot be downloaded because an error occurred. Sometimes, however, if I get up at like 4 a.m. I can get some apps to download for a short time. As a retired IT director, I must say it sounds like the Android Market's server is overloaded. But, I can download an app with my Droid 3 smartphone on the same wifi network at the same time I am getting an error on the Nook Color so it can't be that. I have tried uninstalling updates on the Market App, I have flushed the Market cache then rebooted, and lastly I have tried Flushing both the cache and the data on the Download Manager then did a force stop and rebooted - all suggestions provided in various threads on this forum, but still no joy. This is very frustrating! The Amazon App Store works beautifully but at present I am trying to download Blood and Glory (I'm a Roman history buff) and the Amazon App Store does not have this app available. Any help would be deeply appreciated. By the way, I also notice Google Talk won't sign in either even though my Gmail account is configured properly and I can read my Gmail on my Nook color.
  7. #6
    Super Moderator
    Points: 61,199, Level: 100
    Overall activity: 42.0%
    Achievements:
    50000 Experience Points Recommendation Second Class 25000 Experience Points 1 year registered 10000 Experience Points
    12338
    Jan 2011
    Northern CA
    5,159
    Thanked
    888 times
    Points
    61,199
    Level
    100
    Have you checked the allow Settings>Applications>unknown sources box in settings? If it is checked, uncheck and recheck it. It really sounds like you are having a Google account syncing issue though since some of your Google stuff is working and some is not. Go to Settings>Accounts & sync>Account and then remove the account. Then Settings>Applications>Manage applications>All>Google Services Framework>Clear Data (this last one is better accomplished through Titanium Backup if you have it).
    Reboot and the add your Google account and see if it works.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  8. #7
    70144
    Dec 2011
    United States
    Nook color
    Removed and resetup Google Account but Market still won't download application(s)
    Quote Originally Posted by J515OP View Post
    With the RootMyNookColor configuration I don't have (or couldn't find) the unknown sources box. (I went to Settings->Programs->All->Settings and looked through the list of checked items but there was no "unknown sources" in the list) So I moved on to your next suggestion and removed my Google Account, cleared my Google Services Framework Data and rebooted. Then I resetup my Google Account. Now, at least, I'm not getting an error from Google Talk and it will actually work now but I still can't download Blood & Glory. I noticed that Blood and Glory requires Phone settings. Since my Nook Color is not a phone, this may be a problem. So I attempted to download Paranormal Agency which does not have that requirement but it failed too with the same message (the application could not be downloaded due to an error) which is essentially the error message I have been getting all along. I noticed that in my system settings under "About Phone" there are fields for phone number, wireless providers, etc. but they are set to unknown and cannot be edited because this version of the Nook color does not support 3G.
    I read on one of the threads that the Market tries to authenticate the downloading device to determine if the app selected is compatible and the person recommended cloning my Nook's Mac Address in my wireless router. I know what my Nook's MAC address is but, I'm afraid I don't know how to clone it to my wireless router and they didn't explain the procedure. I do know how to access my router's configuration panel, however.
  9. #8
    70144
    Dec 2011
    United States
    Nook color
    Well, here's a new development. Early this morning I got up at 3:30 a.m. and attempted a download. I did not get an error and the download bar looked like it was doing something but kept running and running like it was stuck. I just let it run and went back to bed. Then I checked it at 7:00 a.m. and the download bar looked the same. So I rebooted the Nook. Then I could see download activity in the status bar - in fact two inboxes with arrows going into them. After a short time, the Nook reported it had installed Blood and Glory. Then I attempted to download Paranormal Agency and it downloaded and installed fine. Then I received a notification that the Market vending app had crashed. I did a Forced Stop. Then relaunched the Market and was able to select, download and install another title. The Market vending app crashed again. Again I did a Forced Stop and reloaded the Market and was able to select, download and install another app. It appears that I now have the capability of download apps although the Market vending app crashes pretty often. However, that's more of an annoyance than a problem so at least I am now somewhat functional. Which of the things I did that may have finally kicked in I'm not sure but this is at least a major step forward.
    By the way, the two inboxes were running because the Nook downloaded both versions of Blood and Glory, the regular one and the gory one. I had clicked on each one at different times during my troubleshooting.
  10. #9
    Moderator
    Points: 11,042, Level: 69
    Level completed: 48%, Points required for next Level: 208
    Overall activity: 0%
    Achievements:
    10000 Experience Points 1 year registered 5000 Experience Points 1000 Experience Points 500 Experience Points
    11725
    Jan 2011
    The Big Apple
    476
    Thanked
    21 times
    Points
    11,042
    Level
    69
    Nook Color (Rooted)
    I'm not having any problems with the Market. However, going into Settings and clearing the cache and data for Market fixes most issues.
    Samsung Galaxy Tab 10.1
    NOOKColor rooted (CM7)
    Coby Kyros 7015 rooted and running custom ROM (retired)
  11. #10
    70144
    Dec 2011
    United States
    Nook color
    Clearing the cache in the Market and the cache and data in Google Framework was the first thing I tried and unfortunately, did not work in my case. I also uninstalled the latest Market update that was also a suggestion but that didn't work either. So I went through the processes I described above and, although they didn't appear to work at the time, as I mentioned something must have kicked in as I can now download apps even though the Market vending app crashes periodically and I have to do a Force Stop and reload the market to continue.
Ads:
  1. Archos 70 with Broken LCD
    By tabletmama in forum Archos Tablets
    Last Post: 12-16-2011, 01:24 PM
  2. Broken Touchscreen
    By chickooiyer in forum WonderMedia WM8505 Tablets
    Last Post: 05-30-2011, 11:15 AM
  3. broken screen....
    By dudu77 in forum APAD IMX515
    Last Post: 05-13-2011, 07:52 AM
  4. Order came in with a broken screen
    By zittergie in forum Android Tablet Discussions
    Last Post: 03-03-2011, 06:25 PM
  5. anyone with a broken tablet...?
    By stevenbang in forum Rockchip RK2808 Tablets
    Last Post: 06-06-2010, 05:33 AM
android market broken
android market crashes on download
could not be downloaded due to an error (504)
could not be downloaded due to an error 504
could not download due to an error 504
error 504 android market
fix android market crash
how to fix android market
how to start market on rooted nook color
no matching content in android market
no matching content in android market fix
nook color android market fix
Tags for this Thread
