Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
  1. #1
    Junior Member Achievements:
    29985
    May 2011
    Houston, TX
    19
    Thanked
    2 times
    Nook Color (Rooted)
    It keeps on saying nook col, nook col, nook col
    Hello everyone,
    I have come back yet with another question that you all may already know the answer of.
    I upgraded my nook to 1.2 and then rooted it with manual nooter. Everyone was really great and worked so cool. I backed it up and rebooted.
    And now it just keeps on saying Nook Col, nook col, nook col, nook col.
    I tried to reboot it a couple of time but it just never goes beyond nook col.
    Can anyone please tell me what is wrong with it. What have I missed or done wrong. Thanks in advance
    Nook Color: CM7 (eMMC) OC 1.2GHz
    Ads
    Advertising world
  3. #2
    7857
    Nov 2010
    21
    Thanked
    2 times
    Think you need to do restore and try again.
  4. #3
    16231
    Feb 2011
    11
    Thanked
    1 times
    I had this for awhile and noticed it was only after I updated to flash 10.3 in the market. Don't allow flash to update and you should be OK.
  5. #4
    1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    19173
    Feb 2011
    St Paul, MN
    75
    Thanked
    1 times
    Nook Color, Vibrant, MyTouch, G1
    Quote Originally Posted by Shimmy View Post
    I may be misunderstanding but his problem is he CAN NOT BOOT. His screen just sticks on the "NOOK COLOR" screen.
    Google G1 - 2, T-Mo MyTouch - 2, Samsung Galaxy S Vibrant - 2, B&N Nook Color - 2 All rooted and running Cyanogen Roms.
  6. #5
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Quote Originally Posted by claxdog View Post
    Yes, just try a restore from the backup you made. Hold power and n together for 8 seconds to boot into internal CWR (if you installed internal) or insert your bootable CWR SD card (in either case the sd card with your backup should be inserted before bootup). Once in CWR, wipe your cache partition and dalvik cache then restore from your working backup.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  7. #6
    16231
    Feb 2011
    11
    Thanked
    1 times
    Quote Originally Posted by kabbie1882 View Post
    No misunderstanding. He needs to do a restore or go back to stock and re-root. Then...don't allow flash to update in the market. When and if it's rebooted after it's updated to flash 10.3, it will be stuck in a boot loop. At least that's what happened to me. I've had no problems since I figured that out.
  8. #7
    7857
    Nov 2010
    21
    Thanked
    2 times
    I updated my flash and have had no issues what rom are you guys using.
  9. #8
    29985
    May 2011
    Houston, TX
    19
    Thanked
    2 times
    Nook Color (Rooted)
    Thanks guys, I restored back to stock and then did eMMC CM7 with OC 12Ghz. So far its running flawlessly.
  10. #9
    Senior Member Achievements:
    1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    29078
    May 2011
    149
    Thanked
    8 times
    Nook Color Gen. 1
    Quote Originally Posted by kashif977 View Post
    Of course I know what you mean. but if I had my NC running at 12Ghz, it would be flying.
    NOOKcolor Gen1
    B&N 1.4.2 (rooted)
  11. #10
    29078
    May 2011
    149
    Thanked
    8 times
    Nook Color Gen. 1
    I was able to recreate this but I haven't tried fixing by stopping flash install after first boot. I will test later when I get home as I'm on my way out.
    used MN 4.5.18 to root by the way.
    edit: I restored to my nand backup pre-root. Then rooted with MN 4.5.25 (just out) instead. It didn't download gapps and flash after logging on so I guess they were built into MN. I rebooted a couple of times and so far don't have any issues with the boot-loop.
    NOOKcolor Gen1
    B&N 1.4.2 (rooted)
Ads:
  1. Replies: 10
    Last Post: 03-30-2011, 01:59 PM
  2. S7 vs Nook?
    By verymagicalguy in forum Huawei Ideos S7
    Last Post: 02-17-2011, 04:46 PM
  3. Cloning Nook apps to another nook
    By spacemonkies in forum Nook
    Last Post: 01-21-2011, 01:57 PM
  4. Nook Color Nook App for other tablets?
    By skicavs in forum Nook Color Apps and Games
    Last Post: 01-18-2011, 06:11 PM
  5. Nook SDK Available
    By OffWorld in forum Nook Color Technical
    Last Post: 12-07-2010, 03:47 PM
colnook
fix nook color 1.2 boot loop
flash player for rooted nook color
manual nooter boot loop 5.08.20
manualnooter boot loop
manualnooter nook color keep rebooting
nook co loop
nook color app keeps saying installing
nook color download problem keeps saying download after installing
nook color loop manualnooter
nook color stuck in update loop
rooted nook color keeps rebooting
