Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thanks Tree1Thanks
Thread: Nook color stuck at "n" screen
  1. #1
    Member Achievements:
    250 Experience Points 100 Experience Points 31 days registered 7 days registered
    33771
    Jun 2011
    Texas
    58
    Nook Color
    I have found various threads that are close to my situation, but i dont think im asking the right questions to my mr. google machine...
    so ill post here and see what you guys can straighten out for me.
    i have tried to restore to stock numerous times, different stock images,
    and these clock work recoveries
    3.0.0.5
    3.0.1.0
    3.0.0.6
    and ive tried samuelhaffs suggestions from a lot of his posts
    such as repartition boot with stock
    ive also tried recovery fix
    and various stock builds
    i even tried using clockwork to flash cm7 builds..
    NOTHING.
    i always get n screen.
    8force reboots dont work
    power+n doesnt work
    and only on the cw 3.0.0.6 was i able to ACTUALLY SUCCESFULLY format /system and /data
    im not sure what else information i can give you to help me better, just let me know
    because this is day two of trying different combinations of fixes and nothing works.
    so help me troubleshoot so we can figure what is wrong, and then figure out how to make what is wrong, right!
    thanks in advance.
    Ads
    Advertising world
  3. #2
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Not sure here but you may have gotten off track. Not knowing what you are doing and trying everyting can lead to complications outside of the ordinary that make it hard to figure out what you did and get you back. Unfortunately this seems one of those situations where you kept digging the hole deeper and deeper so it might take a while for us to help you get back.
    First you need to understand the differences in the CWR versions that you are using, none of which are the most recent version. 3.0.5 is ext3, 3.0.0.6 is ext 4 and 3.0.1.0 is an early build of ext3 & ext4 that is known to have issues with certain combinations of B&N/autonooter.
    Now what is ext3 & ext 4? It is the format of the partition with some ROMs needing one format and other ROMs needing the other. B&N ROMs need ext3 and ROMs built on CM7 need ext4. It sounds like you may be trying to flash with CWR for ext4 which is why you can't get the stock stuff to work (it needs ext3). You need to slow down and read some more before you jump in and do things.
    First of all why don't you work on creating a bootable CWR SD card with the latest version of ClockworkMod Recovery on it. Once you have that decide on what you want to do (custom ROM or stock). Load the appropriate zip files onto the card. Powerdown and insert the card. Boot into CWR, clear your caches (if you don't know what this means read or ask where to read about it). Clear system and data. Flash your zips. Unmount and reboot. That is really all there is to it but you have to know which files to have and what you are doing at each step.
    JP
    xfeejayx thanked this.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  4. #3
    33771
    Jun 2011
    Texas
    58
    Nook Color
    if i dont flash to stock, and go straight to cm7, will all the guys stuff i bought this from still be on the device?
  5. #4
    33771
    Jun 2011
    Texas
    58
    Nook Color
    and thank you for clearing up the fact that i should use the most current cwr because i was at a loss as to which version i should be using! im going to try this as soon as i get home! (cause i found the most current version lol)
  6. #5
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Quote Originally Posted by jakestucker View Post
    No, if you flash a clean install of CM7 it will overwrite anything on the device. Besides that I think you have totally wiped it at this point We just need to get it going again now.
    JP
    Nexus 7
    Nook Color -
  7. #6
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    This should be 3.2.0.8
    Nexus 7
    Nook Color -
  8. #7
    33771
    Jun 2011
    Texas
    58
    Nook Color
    si senor, that is the version i found, its been a slow, but educational journey figuring this out. I was very fluent in jailbreaking and stuff with iphones, and i jumped abruptly to android, and i love it rooting has not been a problem, but as you can see through all the support you have given me, i know not quite enough to actually fix anything, lol give me a brand new stock android device and i got that $hi# down! lol. at least next time ill have a lot more to work with! once i get things (fingers crossed) up and running, if there is an update to cm7, do i just do the cwr sd card and put the newest version on there and install zip? or if im updating do i still need to do the format system and data? from what i know now, im assuming fresh install means format that stuff, but if i dont it should install over the current system? without removing anything?
  9. #8
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Just clear everything n the order I posted to be sure. Can't hurt since you want a fresh slate. Here is the link to the newest stable CM7 and Gapps that you will need. Latest Version - CyanogenMod Wiki
    Nexus 7
    Nook Color -
  10. #9
    1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    19674
    Feb 2011
    chicago
    61
    Thanked
    2 times
    Nook Color
    Did you get this working? My buddy's has the same issue.
    CM7, 1.3 GHz Nook Color
  11. #10
    33771
    Jun 2011
    Texas
    58
    Nook Color
    nope, i have not got it working yet.
Ads:
  1. Replies: 4
    Last Post: 02-23-2012, 08:51 PM
  2. froyo for my "rooted" nook color
    By superscott78 in forum Nook
    Last Post: 03-19-2011, 06:51 AM
  3. Replies: 7
    Last Post: 03-03-2011, 09:46 AM
  4. Replies: 1
    Last Post: 02-24-2011, 07:46 AM
  5. Replies: 8
    Last Post: 02-12-2011, 09:20 PM
fix nook tablet stuck on screen
nook color stuck at n
nook color stuck at n screen
nook color stuck on n
nook color stuck on n screen
nook display stuck
nook screen stuck on loading screen
nook tablet gets to n screen and thats it
nook tablet is stuck on the home screen
nook tablet stuck on n screen
rooted nook stuck on n screen
why is the nook stuck on the loading n screen
