Results 1 to 3 of 3
  1. #1
    Junior Member Achievements:
    25063
    Apr 2011
    NYC
    16
    Nook Color
    After burning CM7 to SD card I can't read the card
    I used the instructions in the sticky and was able to burn generic-sdcard-v1.2.1.img on my uSD card using the windiskimager. However when I try to explore the contents of the uSD card from windows I can't. Windows says the card isn't formatted and prompts me to format the drive. So now I can't install the additional files like update-cm-7.0.3-encore-signed.
    The uSD card works because I have installed a version of Phiremod on there and re-installed it successfully.
    Any suggestions would be appreciated.
    Ads
    Advertising world
  3. #2
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    That is to be expected any time you burn an image to the card. Just copy the files then right click on the card in My Computer and slect paste it will put the files on there. alternatively your Nook will be able to read the card. Boot to your internal Nook OS (stock or however you have it setup) then insert the card. Next connect the Nook to the PC via usb. You will now see two additional drives in My Computer. One is the internal memory and the other (smaller of the two) is the SD card. Now you can see which files are there and move files to and from the SD.
    JP
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  4. #3
    25063
    Apr 2011
    NYC
    16
    Nook Color
    Dude thanks for the tip! I got stuck on that for the longest.
Ads:
  1. won't read sd card?
    By alekos557 in forum Android Tablet Q&A
    Last Post: 08-18-2011, 02:43 PM
  2. Flytouch 2 will not read MicroSD card.
    By Alasdair Hutchison in forum Gome Flytouch II Accessories
    Last Post: 04-27-2011, 08:46 PM
  3. How to read TF or Micro SD card with your tablet?
    By exnoiuh in forum Android Tablet Discussions
    Last Post: 04-24-2011, 12:47 PM
  4. Can we read images from SD CARD or USB
    By ranjiths26 in forum Android Tablet Q&A
    Last Post: 04-10-2011, 10:55 AM
  5. Moving files from USB external card reader to Galaxy's micro SD card
    By fred615 in forum Samsung Galaxy Note/Tab
    Last Post: 02-21-2011, 03:52 PM
android cant read sd card after formatting
can not read sd card after cm7
can't burn img to micro sd card
cannot read sd card after cm7 from windows
cant view sdcard from windows
cm7 usb can't read
nook color cm7 cannot see sd card
reading nook cm7 sd card contents from pc
reading nook cm7 sd card from pc
windows can't read android nook sd card
windows cannot read sd card
