Results 1 to 2 of 2
  1. #1
    95020
    Feb 2012
    nook color, kindle fire
    how to enable nook color usb debugging?
    I have a nook color software version is 1.4.1
    I could not make nook color working for adb. I could not find the tools->application->development on my nook color. How could I enable the usb debugging mode.
    Emmy
    Ads
  3. #2
    Points: 3,693, Level: 38
    Level completed: 29%, Points required for next Level: 107
    Overall activity: 0%
    Achievements:
    Veteran 1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points
    20706
    Mar 2011
    Mokelumne Hill
    120
    Thanked
    4 times
    Points
    3,693
    Level
    38
    Nook-Color stock, HP TouchPad CM10/WebOS, Nexus One CM7. Skyrocket CM10, Nexus 7 JB, Nexus 10 JB.
    On your Nook-Color screen, using the settings icon from your apps list,
    press Settings > Applications > Development > here you'll see a list, the top button should be USB debugging press that.
    Also while you're there press "Allow mock locations"; that's helpful for some sites that need GPS reference.
    Under the Applications menu you'll see "Unknown sources"; you may want to press that and leave it checked if you have a rooted device and plan on apps from other sites than Market.
    Mike
    Proud owner, Nook-Color
    Continually Ecstatic owner, HP TouchPad // CM-10.1, Nightlies
    Nexus 4
    Nexus 7
    Nexus 10
    'Ignorance more frequently begets confidence than does knowledge.'
    ~ Charles Darwin
Ads:
  1. Replies: 27
    Last Post: 01-30-2012, 12:26 AM
  2. How to add apps to an un-rooted Nook Tablet (not Nook Color)
    By BoloMKXXVIII in forum Nook Color Technical
    Last Post: 11-17-2011, 11:41 AM
  3. Replies: 4
    Last Post: 11-08-2011, 08:31 PM
  4. Nook-Color ? Cyanogen7 rc2 Nook Color tools ?
    By 1hen2ducks in forum Nook
    Last Post: 05-31-2011, 05:09 AM
  5. Replies: 10
    Last Post: 03-30-2011, 01:59 PM
USB Debugging nook color
debug mode on nook color tablet
enable debugging mode nook tablet
enable usb debugging nook tablet
how to enable usb debugging on nook color
how to enable usb debugging on nook tablet
nook debug mode
nook tablet enable usb debugging
nook usb debug mode
usb debugging color os
usb debugging nook
