Results 1 to 5 of 5
  1. #1
    97322
    Mar 2012
    Nook color CM7 7.1 problem with syncing google
    Ok now i already have everything installed and everything runs clean i just cant get android market to work so i found out i had to sync. all i get is a fail to connect to server when ever i try to sync my device. i am sitting right next to my wifi hub and can surf the web. i have fixed permissions rebooted over and over and still nothing. do i need any more programs to successfully sync do i need gapps installed( i have tried with gapps 6.11mb) and what version if i need a certain nightly which one becuase i have spent more time getting this to work than actually having fun with it. I am going bald pulling my hair out over this. One less problem means more hair on my head
    Ads
  3. #2
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Yes, you need Gapps. DO you have internet nut not a sync with Google servers? Go into settings accounts and sync and make sure you have the correct gmail address and password.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  4. #3
    97322
    Mar 2012
    thx
    I will try that i dont know how to find my gmail address and when it says server do i type in google or google.com
  5. #4
    97322
    Mar 2012
    ok it still doesn't let me it still says cannot conect to server and i just set up a gmail account can you give me a link to download gapps becuase i installed the market through cwm and it still wont wont show none of the apps
  6. #5
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Gapps can be found here Latest Version - CyanogenMod Wiki at the very bottom of the page. Save the zip file to the root of your SD card (not in any folders) and flash from ClockWork Mod Recovery.
    Once you are booted into CM7 go into Settings>Accounts & Sync and make sure you have the correct gmail and password entered.
    Nexus 7
    Nook Color -
Ads:
  1. How do I associate my B&N color Nook with my google account?
    By ndiniz in forum Nook Color Technical
    Last Post: 10-16-2011, 11:30 PM
  2. Nook color problem with fpse
    By Astralking in forum Nook
    Last Post: 09-26-2011, 10:13 AM
  3. color nook sync with google calender
    By tocoty in forum Nook Color Apps and Games
    Last Post: 08-28-2011, 03:08 PM
  4. Replies: 2
    Last Post: 06-06-2011, 09:42 PM
  5. Problem rooting Nook Color 1.1.0
    By Sanne1313 in forum Nook Color Technical
    Last Post: 03-10-2011, 06:48 PM
add nook to google account
cm7 accounts sync
cm7 nook google play server error
dont have permission to sync with server, nook
google account not syncing nook
google play and nook color how to sync
google play server error retry cm7 nook tablet
how do i sync my nook color to google play
how to add google account to nook color
nook color cm7 google play
nook email dont have permission to sync with this server
problems with cm7.2 encore and gapps no connection
