Results 1 to 4 of 4
  1. #1
    Points: 1,322, Level: 20
    Level completed: 22%, Points required for next Level: 78
    Overall activity: 2.0%
    Achievements:
    1 year registered 500 Experience Points 1000 Experience Points 250 Experience Points 100 Experience Points
    23570
    Mar 2011
    11
    Points
    1,322
    Level
    20
    nook color
    Cant get nook color to load past "android_" screen (CM7)
    I have two nook colors with cyanogenmod 7 on them
    but one was never quite right and didnt have google apps on it.
    I never really messed with it but today I thought I would fix it.
    originally I wanted to upgrade to jellybean for fun since this is one I have just to mess around with.
    But I wanted to roll it back to stock first.
    All the directions I saw for that were quite old and none of the downloads worked.
    I tried some one SD card and it didnt really work.
    It wasnt connecting to wifi and clockwork mod wasnt working (rom manager was there but it said clockwork mod wasnt working and I couldnt update it because wifi wanst working).
    I got all that sorted out
    then I decided to try to upgrade to the latest CM from rom manager
    but I would just give me download errors.
    so I downloaded the file directly to my SD card from the clockwork mod website
    I was able to boot into recovery and it backed up my nook
    but when it tried to install the CM it said there was an error and aborted
    not my nook when you power it up shows "touch the future of reading" then it goes to the "android_" (that pops up before the CM7 logo) and it just sits there
    any thoughts on what to do?
    Should I just make a bootable SD card with CM7?
    (how can I do that...im pretty rusty on all this, I havent messed with it much in a year or two)
    Ads
  3. #2
    Super Moderator
    Points: 61,199, Level: 100
    Overall activity: 42.0%
    Achievements:
    50000 Experience Points Recommendation Second Class 25000 Experience Points 1 year registered 10000 Experience Points
    12338
    Jan 2011
    Northern CA
    5,159
    Thanked
    888 times
    Points
    61,199
    Level
    100
    Hi there, you have 2 options. 1) you can create a bootable ClockWork mod recovery card. There are many instructions here on how to do that so check out the threads. Once you make a bootable recovery card then go to *. 2) If you have recovery on the internal memory you can boot into recovery by holding power+n when booting. Then using an SD card go to *.
    * Download the CM files you want to use (7 or 10) in zip format from the Cyanogenmod website and download the appropriate Google Apps (for Gingerbread/CM7 or Jelly Bean/CM10) also from the the CyanogenMod website. These should both be zip files and go in the root directory of the SD card (not in any folders). Next boot into recovery either from the SD card or internal.
    Choose Wipe Data Factory Reset.
    Choose Wipe Cache Partition.
    Choose Advanced>Wipe Dalvik Cache.
    Choose Install zip from SD card and select the CMx ROM
    Choose Install zip from SD card and select the GApps
    Choose Reboot Device (if you used a bootable recovery SD card go to mounts and unmount the card first and then remove it from the Nook before rebooting or you will go back to recovery).
    JP
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  4. #3
    Achievements:
    23570
    Mar 2011
    11
    Points
    1,322
    Level
    20
    nook color
    CM7 was loaded onto the nook its self and not the SD card, I dont know if that matters or not.
    ANyway is there any particular method for creating the bootable clockwork recovery card that you can link me to
    Ive tried about 5 different ways in the last two days to get that done and its not working for me.
  5. #4
    Super Moderator
    Achievements:
    12338
    Jan 2011
    Northern CA
    5,159
    Thanked
    888 times
    Points
    61,199
    Level
    100
    CM7 doesn't necessarily mean you installed ClockWorkMod Recovery on the internal memory though it is more likely that you did. If when you power down then power on then press and hold the power button and n button at the same time after about 15 seconds you will boot into recovery. To install CM7 you either installed this to internal memory or booted into it from a bootable recovery card at some point previously.
    These are all stickies in the this Nook Color Technical section.
    Post 2 deals with wiping the caches and flashing.
    To make a bootable recovery card [Recovery] Creating a bootable CWR mSD v3.0.1.0 or higher (ext3 & ext4 compatible)
    [RECOVERY] Official ClockworkMod Recovery Information and Versions
    Nexus 7
    Nook Color -
Ads:
  1. Replies: 1
    Last Post: 06-08-2012, 12:25 PM
  2. Replies: 4
    Last Post: 02-23-2012, 08:51 PM
  3. Nook color stuck at "n" screen
    By jakestucker in forum Nook Color Technical
    Last Post: 06-05-2011, 02:46 PM
  4. Replies: 7
    Last Post: 03-03-2011, 09:46 AM
  5. Replies: 1
    Last Post: 02-24-2011, 07:46 AM
cant get nook color past the nook color screen
cm7.2 nook
gapps nook color
nook color cant load gingerbread
nook color cm7 doesn't load
nook load stock
