Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thanks Tree1Thanks
Thread: Great Nook Color restore to defaults tool
  1. #1
    Member Achievements:
    500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points Tagger Second Class
    11436
    Jan 2011
    Ontario
    78
    Thanked
    11 times
    NookColor, G-Tablet
    Lightbulb Great Nook Color restore to defaults tool
    Great tool if you need to restore your Nook Color to defaults after rooting or CWM install
    [RECOVERY][ZIP]Nook Color Restore to stock - xda-developers
    Ads
    Advertising world
  3. #2
    Senior Member Achievements:
    25,000 Experience Points 10,000 Experience Points 5,000 Experience Points 1,000 Experience Points 500 Experience Points
    8499
    Dec 2010
    Charlotte, NC
    1,599
    Thanked
    266 times
    NOOKcolor
    Cool, nice find
    .... although CWR will do this for you as well. In the main menu, the "wipe data and factory reset" will take you back to unrooted 1.0.0 or 1.0.1, which ever version you had installed last.
    Tablet: B&N NOOKcolor @ 925 mhz
    Rom: Ultimate Droid Nook Color 3.3.0 (Gingerbread 2.3.3) ROM
    Kernel: 2.6.29-omap1
    Recovery: CWM 3.2.8
    NOOKcolor LendMe Participant
    NOOKcolor Owners thread
    NOOKcolor Frequently Asked Questions
    Android Tablet Forum FAQ
  4. #3
    11436
    Jan 2011
    Ontario
    78
    Thanked
    11 times
    NookColor, G-Tablet
    Quote Originally Posted by rico2001 View Post
    Cool, nice find
    Did you actually do it this way?
    My understanding is that it will not but I was wrong before
  5. #4
    8499
    Dec 2010
    Charlotte, NC
    1,599
    Thanked
    266 times
    NOOKcolor
    Quote Originally Posted by lifeisfun View Post
    Actually I have used it already on the NC when I was working with the new kernels and ran into endless loops. Though there was no other option, and was going to do the 8 reset trick. So before that I decided to see what the CWR's factory rest would do. Had nothing to loose, so gave it a try. It will wipe the internal storage and take you back to default. I had already upgraded to 1.0.1 so it took mine back to there. After boot, I had to re-reg and the whole nine yards. I was unrooted and no apps installed. See here for the whole Rico's new kernel mess up/fix/restore/success story: New overclocked kernel avaiable for the NOOKcolor
    Recovery: CWM 3.2.8
  6. #5
    11436
    Jan 2011
    Ontario
    78
    Thanked
    11 times
    NookColor, G-Tablet
    Well, that's great news
    What kernel are you using now ?
  7. #6
    8499
    Dec 2010
    Charlotte, NC
    1,599
    Thanked
    266 times
    NOOKcolor
    Using Quickie "She's A Screamer" Kernel. You must not have read the kernel thread or missed the post.
    lifeisfun thanked this.
    Recovery: CWM 3.2.8
  8. #7
    11436
    Jan 2011
    Ontario
    78
    Thanked
    11 times
    NookColor, G-Tablet
    I did, the reason I'm asking again is that it doesn't work for me
    My screen stops responding ( have to turn it off and back on again)
    also on first two boots I didn't have WIFI, that's working now.
    I did wipe my cache partition upon installing the kernel so I'm not sure what's wrong.
  9. #8
    8499
    Dec 2010
    Charlotte, NC
    1,599
    Thanked
    266 times
    NOOKcolor
    Hmm. Well my NC can run all three kernels (900, 950 & 1Ghz) fine but 1Ghz is has peaks of slowness, where I believe it downclocks to maintain stability. On some test, it benches slower than the "Screamer 950mhz) kernel.
    -Wipe then flash
    *Make sure you wipe both cache while in CWR: cache partition and dalvik cache (under advance menu). And I believe the dalvik cache is the more important one to wipe.
    Recovery: CWM 3.2.8
  10. #9
    11436
    Jan 2011
    Ontario
    78
    Thanked
    11 times
    NookColor, G-Tablet
    I did wipe both but no joy
    900MHz runs perfect without problems.
    If I have some time I'll do complete reset and I'll try again
  11. #10
    8499
    Dec 2010
    Charlotte, NC
    1,599
    Thanked
    266 times
    NOOKcolor
    Well not all cpus are created equal and according to those on xda, experiences, results and stability with these kernels vary. Are you on b&n software 1.0.1?
    Recovery: CWM 3.2.8
Ads:
  1. Nook Color vs eLocity A7
    By JackOnan in forum Nook
    Last Post: 03-05-2011, 10:24 PM
  2. Nook Color at Walmart $249
    By gadgetrants in forum Nook
    Last Post: 02-18-2011, 01:21 PM
  3. Replies: 18
    Last Post: 01-13-2011, 01:48 AM
  4. Use of Nook Color Slideshow
    By curttp in forum Nook Color Apps and Games
    Last Post: 12-24-2010, 11:46 AM
  5. Nook Color
    By Darkseider in forum Nook
    Last Post: 12-11-2010, 05:52 PM
factory reset nook color after rooting
hard reset nook color 8 times
how to reset nook color from android to factory settings
how to reset nook color to factory settings
how to restore nook color to factory settings
nook color 8 reset
nook color hard reboot
nook color infinite boot loop
nook color reset
restore nook color to factory settings after cwm
