Page 7 of 8 FirstFirst ... 5 6 7 8 LastLast
Results 61 to 70 of 72
  1. #61
    Super Moderator
    Points: 61,199, Level: 100
    Overall activity: 42.0%
    Achievements:
    50000 Experience Points Recommendation Second Class 25000 Experience Points 1 year registered 10000 Experience Points
    12338
    Jan 2011
    Northern CA
    5,159
    Thanked
    888 times
    Points
    61,199
    Level
    100
    Quote Originally Posted by RASTAVIPER View Post
    From what I can see, latest OC kernels are not so good in passing 3000 score limit.
    Anyway, when I will find some kernel to keep my NC stable at 1,3+ Ghz, then I will check if I can go beyond my previous score.
    Even being in the 2500s is really impressive if you think about it.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
    Ads
    Advertising world
  3. #62
    Junior Member Achievements:
    7 days registered 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    8880
    Dec 2010
    7
    It may just be the specific build of some Nooks..I guess you and I got good ones..Latest Nightly, Latest Dal Kernel....consistently over 3K....Name:  uploadfromtaptalk1308906865075.png
Size:  68.0 KBName:  uploadfromtaptalk1308906865075.png
    Sent from my NookColor using Tapatalk
    Attached Images Attached Images
  4. #63
    Points: 6,505, Level: 52
    Level completed: 78%, Points required for next Level: 45
    Overall activity: 0%
    Achievements:
    5000 Experience Points 1 year registered 500 Experience Points 1000 Experience Points 250 Experience Points
    21718
    Mar 2011
    Fulton,MS
    151
    Thanked
    22 times
    Points
    6,505
    Level
    52
    Huawei Ideos S7, Nook color
    Anyone know what sort of quadrant scores folks are getting from tegra chips? Just wondering how our nooks stack up to the big boys
  5. #64
    Senior Member Achievements:
    1000 Experience Points Tagger Second Class
    18757
    Feb 2011
    GREECE
    329
    Thanked
    21 times
    NOOK COLOR
    New personal record at 3415!!!
    With latest nightly at 1.325mhz.
    Sent from Nook Color on Phiremod 6.3 @1.3Ghz
    NOOK COLOR ON CM7 Nightly 233
    Kernel :
    OCed @1.200 Mhz
    Cover Case : Tuff-LuvTri-Axis Leather Case
    Quadrant score: 3415
  6. #65
    26080
    Apr 2011
    PA
    22
    Thanked
    3 times
    Rooted Nook Color - Samsung Galaxy Tab
    I no longer try to game Quadrant
    Instead of trying to get the best score possible, I just do a couple of Quandrant passes after I install the latest build, with the Nook allowed to load all the stuff it normally does, CPU set to ondemand and with Nook Tweaks peaking peformance at 1300.
    Generally, I see Quandrant scores in the 2700 range, but with Build 129, the performance jump has been significant. My first three runs of Quadrant were all over 3000.
    NOOK COLOR - CM 7 + Nightly
    CWR: 3.0.2.8
    Verizon MiFi 4510L 4G/LTE
    Pharos iGPS-BT
    Samsung Galaxy S II i777
    Siyah 2.6.7
    SHOstock v1.9
    Samsung Infuse (AT&T)
    Samsung Galaxy Tab 7 (T-Mobile)
  7. #66
    18757
    Feb 2011
    GREECE
    329
    Thanked
    21 times
    NOOK COLOR
    So, what is the different thing that you are suggesting that you do??
    Sent from Nook Color on Cm7 Nightly 129 @1.325Mhz
    Kernel :
    OCed @1.200 Mhz
  8. #67
    26080
    Apr 2011
    PA
    22
    Thanked
    3 times
    Most folks seem to do a fresh boot, stop applications, clear up memory, set the CPU to Performance, etc. I don't bother. In general there are about 30 background apps, I don't boot then run the tests immediately, I don't tweak the Nook for better results.
    I could increase the CPU speed, clear out running apps, set CPU to performance, etc., and I wouldget higher numbers. I don't see the value of that in evaluating the builds for day to day use.
    CWR: 3.0.2.8
    Pharos iGPS-BT
    Siyah 2.6.7
    SHOstock v1.9
  9. #68
    18757
    Feb 2011
    GREECE
    329
    Thanked
    21 times
    NOOK COLOR
    Fyi, I got this result without clearing anything from background tasks and with my standard governor of ondemand.never saw any difference with Perfomance.
    Fresh boot is always essential though.
    And this was my 2nd run.no better results if I try more.
    Kernel :
    OCed @1.200 Mhz
  10. #69
    Super Moderator
    Achievements:
    12338
    Jan 2011
    Northern CA
    5,159
    Thanked
    888 times
    Points
    61,199
    Level
    100
    The capabilites of the Nook's processor have certainly been answered both in benchmarking and real world use. To be consistently getting around 3000 with the latest ROMs is impressive. Not bad for a $250 e-reader particularly considering when it debued there were very few dual core chips in use outside of the prototype teaser tablets.
    Nexus 7
    Nook Color -
  11. #70
    18757
    Feb 2011
    GREECE
    329
    Thanked
    21 times
    NOOK COLOR
    I have been playing with another bench called Antutu, which is available at Market.
    Has also online ranking.
    Best score for me was 2916 at 1200 MHz.At higher speed, program closes.
    Sent from Nook Color on Cm7 Nightly 129 @1.350Mhz
    Kernel :
    OCed @1.200 Mhz
Ads:
  1. Cloning Nook apps to another nook
    By spacemonkies in forum Nook
    Last Post: 01-21-2011, 01:57 PM
  2. Rooted Nook Settings Question
    By zero9046 in forum Nook
    Last Post: 01-21-2011, 06:21 AM
  3. Nook Color Nook App for other tablets?
    By skicavs in forum Nook Color Apps and Games
    Last Post: 01-18-2011, 06:11 PM
  4. wifi performance
    By pedro_ in forum Huawei Ideos S7
    Last Post: 01-13-2011, 05:28 PM
  5. G tab performance issues
    By BloodLust in forum Viewsonic gTablet
    Last Post: 12-25-2010, 11:36 PM
best performance settings for nook
best performance settings for nook color
best performance settings for rooted nook color
can i improve my nook performance
how to improve nook color performance
how to improve nook performance
improve nook tablet performance
improving nook color performance
increase nook color performance
nook color cm7 performance settings
nook color cyanogenmod performance settings
