Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thanks Tree3Thanks
Thread: (How To) Restore stock recovery from CWR.
  1. #21
    Junior Member Achievements:
    7 days registered
    55974
    Oct 2011
    NC
    7
    Nook Color
    NC stuck with half of restore! Help pls!!
    I followed the directions to install the Monster Rootpack but it didn't work. So I decided to restore my nook back to factory settings. Then it was stuck... so I looked for ways to remove CWR and restore NC. I did that and it was stuck and is stuck with half of the original things working in stock. I get to a partial screen with "home" and "soft keys" if I try to go to the home page I get the message "Initial loading from Media Provider failed to load" so I followed the directions that another person got. I'm still stuck the same way and have no clue what to do! I hope someone can help me get back to factory settings and restore the basic NC!
    Ads
    Advertising world
  3. #22
    7 days registered
    55974
    Oct 2011
    NC
    7
    Nook Color
    Thank you so much!! I was having the exact same problem especially with the 8 reboot, couldn't get it done and this shortcut is fabulous and my NC is now doing factory reset too!
    SuperGirl!!
  4. #23
    7 days registered
    55974
    Oct 2011
    NC
    7
    Nook Color
    Lost storage capacity!
    Quote Originally Posted by dividj View Post
    I have restored everything back to stock but it does not show my storage capacity... it shows 0% of 0%! How do I get my media storage back?! I can't download anything and can't upgrade Nook either. My computer does not recognize Nook and there is no media storage showing on my computer either!!
  5. #24
    Senior Member Achievements:
    1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    34054
    Jun 2011
    160
    Thanked
    12 times
    Nook Color
    Follow the instructions here and make sure you use the latest version of CWR (3.2.0.1) except, instead of installing the 2 .zip files mentioned use this stock 1.3 ROM instead:
    Instructions: Nook Color: How to Install Cyanogenmod 7.1*|*Maurice Mongeon
    Stock ROM:
    CM7 nightly (currently 201)
    "The needs of the many outweigh the needs of the few (or the one)."
  6. #25
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    There are many simple ways to restore. If you want to restore to the latest stock ROM (B&N 1.3) create a bootable CWR SD card ([Recovery] Creating a bootable CWR mSD v3.0.1.0 or higher (ext3 & ext4 compatible)) and flash the file above. You can also flash older versions of the stock ROM or custom ROMs.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  7. #26
    84282
    Jan 2012
    nook color
    I want to remove CWR 3.2.0.1, but it won't recognize sd cards anymore
    I want to remove CWR 3.2.0.1, but it won't recognize sd cards anymore at all, and won't power up if one is inserted.
    I had made a booted sd card to run CM7 and it was working really well.
    I also made a bootable honeycomb sd card and it also worked pretty well.
    But for some reason, after sitting for a week or so without a card in, my sd reader stopped working.
    So now I can not boot from the cards or use a card to reset the recovery to stock.
    I have tried multiple cards and they all open fine in windows explorer but the nook will not recognize them at all from CWR.
    And if I put in a card while running nook 1.3 it powers off and will not turn back on unless I remove the card.
    I don't know what to do now, I want to get the reader fixed but I don't know how to get it back to stock without the card.
    And it wont let me install the update either, it comes to a android man with a triangular exclamation mark sign.
    Then when I push the power button it loads CWR.
    So if they try to update it my warranty is voided isn't it?
Ads:
  1. [RECOVERY] Working recovery with UI glitches
    By perivarlura in forum Huawei Ideos S7 Development
    Last Post: 02-17-2012, 05:46 PM
  2. Replies: 185
    Last Post: 06-15-2011, 01:13 PM
  3. [RECOVERY] Clockwork Recovery for Coby Kyros MID-7015
    By razor950 in forum Telechips TCC8902 Development
    Last Post: 04-18-2011, 02:24 PM
  4. [RECOVERY] Clockwork Recovery Test Image for Haipad M701 4GB (HY)
    By fun in forum Telechips TCC8902 Development
    Last Post: 03-24-2011, 07:40 PM
  5. I want to restore OS
    By TabletUser6680 in forum Android Tablet Discussions
    Last Post: 12-28-2010, 05:32 PM
android restore stock recovery
clockworkmod restore stock recovery
cwr flash
how to install stock recovery
how to recover stock recovery android
how to restore android stock recovery
how to restore original recovery
how to restore stock recovery
how to restore stock recovery?
how to uninstall clockworkmod nook color
stock restore android
