[ROM][Feb. 15 2011] >>>>> phiremod nook BETA <<<<< Themed Froyo 2.2.1 - xda-developers
Welcome to phiremod for Nook! This rom is based off Cicada’s Nookie Froyo 0.6.7. Your warranty was void long ago, so I am not responsible for any damages you may encounter (though you probably won’t). This is a Clockwork flashable zip only. It WILL erase your internal memory. Please make the necessary backups.
Features
- Froyo 2.2.1
- Sudo-Gingerbread theme (ADW)
- Default LCD density of 160 (user adjustable)
- Some larger framework image files for the larger screen
- Miui Music and Gallery
- Droid X keyboard
- Swype keyboard
- gTab simi Clock widget included
- LCDDensity included
Why Beta?
- Having trouble getting Market to work
- System fonts are still black (so status bar text/menu setting text aren't readable)...
Changelog:
BETA2
- Added Market Enabler which fixed the Market loading
BETA
- First release, see features for details
Download:
Nook Color Roms - phiredrop Android Development
AS ALWAYS, USE AT YOUR OWN RISK!
26Thanks
LinkBack URL
About LinkBacks![[ROM][Feb. 15 2011] >> phiremod nook BETA 2 << Themed Froyo 2.2.1-phiremod_nook_header.png](http://www.androidtablets.net/forum/attachments/nook-color-technical/1241d1297792355t-rom-feb-15-2011-phiremod-nook-beta-2-themed-froyo-2-2-1-phiremod_nook_header.png)
I don't like v1 of anything.
HTC Aria-CM7
