Page 1 of 13 1 2 3 11 ... LastLast
Results 1 to 10 of 122
Thanks Tree10Thanks
Thread: [How To] Install CyanogenMod / Phiremod Builds to Internal Storage
  1. #1
    Moderator Achievements:
    5,000 Experience Points 1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points
    15401
    Jan 2011
    India
    425
    Thanked
    64 times
    Nook Color
    Following is the How To Guide to install CM7 and Phiremod [Gingerbread] builds on your Nook Color. I have tried my best to keep the instructions as simple as possible, still if you have any doubts then don't hesitate to ask me. And seriously, it is as simple as it sounds in this guide.
    I. Installation :
    Caution : This is not faint of hearts. If something happens then I am not responsible. Hey wait, nothing gonna happen to your Nook Color if you read instructions carefully. And make sure you have read them thrice and have no doubts. As it will be installed to internal storage, all your data will be wiped.
    Following are the things you need :
    1. Rooted Nook Color
    2. Micro SD Card
    You will need this as you are going to prepare EXT4 SD card. Keep this in mind that, by doing this all your data in your memory card will be wiped. Hence take back or use a spare memory card. And if you have only one SD Card, then use it, after you can make it back to normal.
    3. The following files :
    a. EXT4 Compatible Bootable Clockwork SD Card
    For this process you need CWR 3.0.0.6 which will be booted from SD Card. If you are using 1GB card, then download 1gb_clockwork-0.1-ext4.tar.gz and so on. Never download file which is bigger than for your card.
    for
    1GB Micro SD - link MD5 - 0aad5d16eb9a274f2a72b12f7be44c55
    2GB Micro SD - link MD5 - 598262de35053f2d34480175ac337d7c
    4GB Micro SD - link MD5 - 71ba12fc908c6bcc643aec6e9359b9f1
    8GB Micro SD - link MD5 - 41ac8d2b425f47db3f811676d35bd904
    b. CM Nightly / Phiremod Build File :
    Download either of the following :
    1.Download the CM build file from here
    CM7 RC4 build - link MD5 - cb54db554f92ee0706846f8c51362162
    (or Latest Nightly build, CM build 36 [05/Apr/2011] - Download Link MD5 - 727000179e086329e2798c2f00574336
    Change log - link )
    2. Download Phiremod build from here - link
    Note : This is Phiremod Gingerbread Version, not Froyo one. Please make sure you are downloading correct version.
    c. Google Apps [Gapps] File :
    Source link
    Gapps for CM7 - Download Link MD5 - 45e175c25a498c8945c543d92d92e782
    d. OC Kernel file [only if you plan to OC]
    Source
    1.1GHz - Download Link MD5 - 0bf22eface5c313c783b627d7a85d475
    Please double check md5 sums before doing anything. I have given source links for a reason, so check them before for any updates if available. Also make sure you have atleast 60% of battery.
    Lets get to the business.
    1. Take back up !
    Before doing anything first job is to take back up. [Use this link if you don't know how to back up.]
    2. EXT4 SD Card
    Preparing EXT4 Compatible Bootable Clockwork SD Card :
    a. Download the required EXT4 file suitable for your Micro SD card.
    b. Extract the zip file with suitable zip manager.
    c. Burn the image to SD card using Win32Disk manager or similar. [ How to link ]
    That't it ! Your SD card is ready !.
    3. Installation
    Now move the CM build, Gapps and OC Kernel files to SD card. Your SD card should look like this :
    a. Now power down your NooK Color. Insert the Micro SD Card. And power up.
    b. It should boot into CWR automatically. A animation of skull appears and make sure CWR version 3.0.0.6 appears at bottom.
    c. Now move to 'mounts and storage' and format
    - system
    - data
    - cache
    d. Go back to Main menu. Go to 'install zip from sdcard'
    'choose zip from sdcard' > select "cm_encore_full-7.zip"
    In the same way install Gapps and OC Kernel file.
    e. Now go back to Main Menu. Select 'mounts and storage' and press 'unmount sdcard'. Now take out SD card from Nook Color. Go back to main menu again and press 'reboot into system'
    Congrats ! CyanogenMod is installed in your Nook Color !
    4. What next ?
    a. Turn the Nook Color. You will see ANDROID at the bottom and next CM logo.
    b. Configure your WiFi, set up Google Account and also you can select apps if you want to install in coming steps.
    5. SD Card
    If you have used spare memory card, then you can keep it for future builds of CM. If you have used your main SD card, then connect it to PC and format it. [Never format it in Nook color itself.] After formatting you can use your SD card as storage for Nook Color.
    II. Installing CM7 Build update files :
    If you have used a spare memory card and it is flashed to EXT4, then you can use it again. If you have only SD Card, then you might want to take back up again and make it EXT4 compatible. Follow steps above mentioned in EXT4 SD Card.
    You need :
    1. EXT4 SD Card
    2. CM7 Update file
    How to :
    1. Download the latest build from here - link or Phiremod update from here - link
    2. Place the Update file on the root of your EXT4 SD Card. Installing update reverts NC back to stock clockspeed. If you want to OC, place OC kernel file in root of your SD card.
    3. Turn off your Nook Color and place the EXT4 SD card in your NC.
    4. Power on the device. Now you will be booted in Recovery with CWR version 3.0.0.6
    5. Chose 'install zip from sdcard'
    then select 'choose zip from sdcard' > 'latest update file'
    again, to OC, 'choose zip from sdcard' > 'OC Kernel file'
    6. Now unmount the SD Card.
    'mounts and storage' > unmount sdcard > remove sdcard
    III. Restoring to Stock, bye bye CM7 :
    Here is the easy guide to revert back to stock. link The thread is very much self explanatory, hence I am not giving instructions here. But once you install CM7, you will never wish to go back to stock
    Comments and suggestions are always welcome. Special thanks to Rico, Vic and faceman for their support and encouragement.
    Ads
    Advertising world
  3. #2
  4. #3
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Looks good. Haven't tried it out yet or read critically for errors but this will be helpful. I am sure some of the others will let you know if there are errors. My suggestion is to make the formating bold and big in Step 5 to draw attention to it.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  5. #4
  6. #5
    15401
    Jan 2011
    India
    425
    Thanked
    64 times
    Nook Color
    Waiting for official CWR 3.0.0.6 zip, then the installation will be lot easier. As of now one can install it via ADB.
  7. #6
    Senior Member Achievements:
    1 year registered 500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points
    15075
    Jan 2011
    493
    Thanked
    31 times
    Nook Color
    What is the starting point for this? I'm rooted 1.0.1 and my wife's is rooted 1.1..
  8. #7
    15401
    Jan 2011
    India
    425
    Thanked
    64 times
    Nook Color
    Nope. It doesn't matter as it will be installed directly to eMMC aka internal storage.
  9. #8
    500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    13256
    Jan 2011
    Western, NY
    800
    Thanked
    53 times
    Nook Color Rooted
    Thanks for the guide You may want to put in a warning to people that it will wipe internal memory, and replace it with a completely new Rom/Custom OS. Also that it is bit of a process to go back to a previous backup as ext4 requires a workaround to return to an autonootered nook backup image.
    Steve = Rooted Nook Color Phiremod 6.1 • Rooted Fascinate
  10. #9
  11. #10
    15401
    Jan 2011
    India
    425
    Thanked
    64 times
    Nook Color
    and will soon post another guide about how to uninstall it and switch back to stock.
Ads:
  1. Internal vs System storage for apps
    By TapNClick in forum Archos Tablets
    Last Post: 07-08-2011, 10:05 AM
  2. Moving files from sd card to internal storage?
    By applewhite29 in forum Samsung Galaxy Note/Tab
    Last Post: 02-13-2011, 07:21 PM
  3. App for viewing internal storage
    By ballyoran in forum Android Tablet Q&A
    Last Post: 02-05-2011, 03:04 PM
  4. App for viewing internal storage
    By ballyoran in forum Gome Flytouch II
    Last Post: 02-05-2011, 02:41 PM
  5. Internal storage of 101
    By duckredbeard in forum Archos Tablets
    Last Post: 01-20-2011, 08:50 AM
cm7 gingerbread builds as cwr 3.0.0.6
cyanogenmod assert failed getprop ro.product.device encore
how to back up internal storage before rooting gt-s6102
how to install cm10 on nook color internal storage
how to install cm10 on nook tablet internal storage
how to install cyanogenmod 9 on gt-s6102
how to install cyanogenmod to nook tablet
how to load md5 on nook
install cyanogenmod on nook color internal storage
md5 - 45e175c25a498c8945c543d92d92e782
nook hd cyanogenmod review
phiremod nook color
