Results 1 to 7 of 7
Thanks Tree1Thanks
  • 1 Post By leeshor
Thread: Using a 3G dongle
  1. #1
    Member Achievements:
    1 year registered 1,000 Experience Points 500 Experience Points 3 months registered 250 Experience Points
    106863
    Apr 2012
    Ireland
    44
    Using a 3G dongle
    I got the unlocking codes for a 3G dongle I had for an old contranct so I'm free to use the sim from my Galaxy SII that has an all-you-can-eat data plan, but I'm not sure How I would use it for voice calls if there happened to be incoming calls while it was connected to the Onda? Do I have to install some sort of SoftPhone app?
    Ads
    Advertising world
  3. #2
    Super Moderator
    Points: 20,461, Level: 90
    Level completed: 23%, Points required for next Level: 389
    Overall activity: 99.9%
    Achievements:
    Recommendation First Class 10,000 Experience Points Recommendation Second Class 1 year registered 5,000 Experience Points
    Awards:
    Frequent Poster
    77592
    Dec 2011
    Norcross, GA
    4,741
    Thanked
    914 times
    Points
    20,461
    Level
    90
    Transformer Prime & TF700
    I'm thinking you may have a problem. If your Onda wasn't designed for 3G, (take a SIM card) to start with that would be your first problem but I have not seen any way to use a SIM card in a tablet that would accept it for anything more than data. Tablets weren't designed to be a phone or to ba bale to be used for voice calls unless it was software based, like Skype or Google voice.
    With that said you could go to the Google Store and search for SIP, which is basically a soft phone to see what you come up with based on your location.
    leftygt thanked this.
    Locked out of your Tablet? - Printing from an Android tablet (or phone) - Connecting to the Internet with no WiFi - Move/copy/cut/paste files to and from your tablet - WiFi connection issues - Getting Flash Player
    TF201 & TF700 (stock) with dock, .
  4. #3
    119277
    Jun 2012
    Northern Ireland
    Onda Vi40
    Having similar diffs myself. Having done a bit of research on this, Onda sell what I assume is an Android dongle (unlocked) which they say will work with the Vi40. Similar ones on Amazon are about 30 so going to order one up and see what happens. The other option is Mifi which I believe is a good alternative but more expensive.
  5. #4
    127262
    Jul 2012
    Israel
    Onda Vi40 elite V3
    I have just received a Huawei 3G modem - E367. When connecting it to the USB port of the Vi40e at V1.2rcOTA tablet it will properly connect to a 3G network and I can properly use the internet.
    I did not succeed to use it as a phone as the PHONE and CONTACTS applications are not available on the tablet.
    I am not sure about it, but I think that those applications where available on the V0.6 firmware.
  6. #5
    106863
    Apr 2012
    Ireland
    44
    Any update on this lads? I unlocked my 3g dongle to take any network and have it working with my laptop once I downloaded the Huawei mobile partner - but I'm assuming I would need a similar program for it to work with the Vi40 Elite? not concerned about the softphone bit - just want it for mobile internet.
  7. #6
    Super Moderator
    Achievements:
    Awards:
    Frequent Poster
    77592
    Dec 2011
    Norcross, GA
    4,741
    Thanked
    914 times
    Points
    20,461
    Level
    90
    Quote Originally Posted by leftygt View Post
    So few 3G dongles work on Android your best bet would be to check with the WEB site for Huawei to see what they have to say about compatibility.
  8. #7
    106863
    Apr 2012
    Ireland
    44
    Quote Originally Posted by leeshor View Post
    Cant find a thing about connecting it to an Onda Leeshor, iis a Huawei E180 - have you any knowledge of them?
Ads:
  1. WHICH USB 3G dongle?
    By vijaykhai in forum Samsung Galaxy Tab 2
    Last Post: 05-04-2012, 08:34 PM
  2. How do i use a dongle
    By julestracy in forum Android Tablet Q&A
    Last Post: 01-10-2012, 10:01 PM
  3. How do i use a dongle
    By julestracy in forum New Member Introduction & Site Assistance
    Last Post: 01-10-2012, 05:37 PM
  4. 3G/4G. Dongle
    By walrus in forum Vizio Tablets
    Last Post: 09-07-2011, 01:10 AM
  5. usb 3g dongle??
    By MrFus in forum Zenithink Tablets
    Last Post: 07-06-2011, 10:41 PM
3G dongle for android tablet
how do i use a 3g huawei e367 mobile broadband for android tablet
how to use 3g flash on tablet
how to use a 3g dongle on my android tablet
internet 3g en onda tablet
pc internet plan with 3g dongle can i use dongle for tablet?
tablette samsung 3g dongle for android unlock
using dongle with android
what is 3g dongle for android tablet
what is 3g dongle for tablet
what is a 3g dongle for android tablet
what is a 3g usb dongle for tablets
