Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thanks Tree1Thanks
Thread: Onda V811 - v2.0 firmware (android 4.1.1)
  1. #1
    Junior Member Achievements:
    7 days registered
    154865
    Nov 2012
    Spain
    Waiting for my onda v811
    Hello,
    I'm new in the forum and I'd like to say you that you can now download new firmware for our Onda V811 (v2.0) . I think it updates to android 4.1.1 too.
    ONDA
    Buy
    Ads
    Advertising world
  3. #2
    Senior Member Achievements:
    3 months registered 31 days registered 1,000 Experience Points 7 days registered 500 Experience Points
    153473
    Nov 2012
    Newcastle, England
    441
    Thanked
    113 times
    Onda V701
    Hi and welcome to the forum thanks for the link and if you need anything just ask, a good bunch of peeps on here!
    What man make's... Man breaks... Then put's it back together, correctly.
  4. #3
    7 days registered
    154865
    Nov 2012
    Spain
    Thank you iiDiabolusZz, I supose I'll have lots of thinks to ask you (this will be my first tablet).
  5. #4
    153473
    Nov 2012
    Newcastle, England
    441
    Thanked
    113 times
    Onda V701
    Thats no problem, its a great site and good people, you will have no problems getting answers here, just noticed your status as waiting for onda v811, let us no when you get it and we will get it running as it should.
  6. #5
    7 days registered
    155046
    Nov 2012
    Ohio
    Onda v811
    I'm new here too!
    I updated to the 2.0 ROM. I haven't played with it a whole lot, but I haven't experienced any serious glitches so far.
    The only issue I have is this ROM is not rooted like the previous ROMs. A user on Slatedroid has reported that TPSparkyroot, SuperOneClick or ZhouDashi will not root this ROM.
    Anyone have suggestions as to how we may get root?
  7. #6
    3 months registered 1,000 Experience Points 500 Experience Points 250 Experience Points 31 days registered
    148014
    Oct 2012
    Irving, Texas
    41
    Thanked
    8 times
    Idolian 7" Idolpad Plus, Onda v811
    Ditto.... I had my 811 rooted w/ 1.5.5 using the tool provided by iiDiabolusZz elsewhere on this forum. (Many thanks!) I tried multiple variations of the SD card method with 2.0 without success. I finally had to use the Amlogic Flash tool with a Win7/32 PC. The 1st attempt froze up at 69% and my tablet was zombified. (no white bot, no reset, just dead, dead, dead.....) I ran it again, starting the tool as "Administrator" & it worked. However.... it removed the root! If anyone knows a workaround to root one of the Amlogic A9 dual core Onda tablets w/ 4.1, I would really appreciate the info.
    No matter where you go, there you are......
    Buckaroo Banzai
  8. #7
    153473
    Nov 2012
    Newcastle, England
    441
    Thanked
    113 times
    Onda V701
    Just put Thread on Rooting 2.0 firmware
  9. #8
    7 days registered
    155607
    Nov 2012
    Finland
    Onda V811
    I got today an Onda V811 and eagerly wanted to update it to 2.0. And it became a total nightmare. The update tool had some hiccups although I followed google-translated instructions as well as I could. After many trials I managed to get update progressing, but then at quite late steps (20/23) it faced some errors and eventually halted. Now the tablet doesn't anymore go the flashing mode (device recognised by Windows etc.), just the white droid coming up and the recovery menu.
    Alas, the BIGGG problem is that V811 doesn't have volume buttons, there is no way to move the highlight in the menu. I've tried everything. Touch input does nothing, home-button just toggles screen blank, and power button boots the device, and brings the menu back.
    It seems I managed to brick the device...
    I wonder if it's possibe to connect a USB keyboard to the USB port and move the highlight that way. But being in the boot menu, I could easily guess that it doesn't work even if it worked when OS is completely booted up.
    Man, next time I buy some real brand and avoid these Chinese crap. Unless, someone is able to help me out here...
  10. #9
    148014
    Oct 2012
    Irving, Texas
    41
    Thanked
    8 times
    Don't Panic! We can fix this! It sounds like you tried to use the Amlogic Flashing Tool. It has several problems. Go to this thread...
    http://www.androidtablets.net/forum/...er-v1-0-a.html
    (Once again, many thanks to iiDiabolousZz for all the time put in on this!!!!)
    Follow the directions. If you have any questions or problems, don't worry, you came to the right place. There are lots of very talented folks here who will help you get your 811 running so well, it will be the envy of all your friends w/ Ipad Mini's. Yes, it's a little more involved but, at least for me, that's part of the fun. I haven't enjoyed myself so much since I upgraded my 1st PC, an IBM 8086, with a 10 Mb. Hard drive!
    Oh, BTW.. You may have already figured this out, but just in case, The "home button" cycles between options on 801 & 811's and the "power" button selects. Also I put up an update on rooting the 811 here...
    V811 4.1 v2.0 rooting
    It's towards the end. Good luck!
    hmaki thanked this.
    Buckaroo Banzai
  11. #10
    7 days registered
    155607
    Nov 2012
    Finland
    Onda V811
    I'm impressed. That worked! I didn't yet root the device though.
    The firmware is missing some apps, notably the Google Play etc. Onda resource update zip contained also a patch.zip. Is that of any use?
    Update
    Reading that other thread revealed that some other person had also been wondering that and had found another version of factory_update_param.aml, which installed both root.zip and patch.zip. I didn't find such file, but manually edited it to install both. And it did so.
    Great forum this!
Ads:
  1. Onda V811 Won't Load Past White Android Symbol
    By Debebjo in forum Onda Tablet Forum
    Last Post: 05-02-2013, 02:38 AM
  2. Onda v811 vs MOMO8 - 2 IPS
    By darkfirebg in forum Android Tablet Discussions
    Last Post: 11-16-2012, 11:40 AM
  3. Need Help w/ v811 - 1.5.5 Firmware Installation
    By asjohnston3 in forum Onda Tablet Forum
    Last Post: 11-12-2012, 05:30 PM
  4. Onda 1.2 firmware and BBC iplayer stuttering on Onda Vi40
    By mikeburton1955 in forum Onda Tablet Forum
    Last Post: 06-16-2012, 11:32 AM
firmware onda v811
how to upgrade firmware onda v811
onda v811
onda v811 dual core firmware
onda v811 firmware
onda v811 firmware update
onda v811 rom
onda v811 root
onda v811 update
onda v811 upgrade
root onda v811
v811 rom
