great job again iiDiabolusZz!just waiting for a jellybean update for my v712, or do you think the jellybean firmware update for the v711 could work on the v712? ^^
What man make's... Man breaks... Then put's it back together, correctly.
Hello, just a question.
Ive done the installation of the firmware, the only thing ive done different in the first part is instead of ROOT.ZIP i used the UPDATE.ZIP, i didnt renamed.
So i used the press + volume, put wipe factory data, and then i put update from sdcard and choosed update.zip.
thats ok, now instead of the old chinese with bunch of chinese apps, its chinese at beggining but there is no chinese apps, i just changed the language to english
here are the details right now after the first part:
android version 4.1.1
baseband: 2.0
kernel version
3.0.8-g47c8511-dirty
connor.zhang@droid07-sz))
#1 SMP PREEMPT sat nov 17 14:23:55 CST 2012
build number
JRO03c.eng.g12refM805.20121117
now the second part.....
ive done that with root.zip, it shows the green droid, repair process (very fast by the way) and NOTHING HAPPENS
with either root.zip or with update.zip (like did in first part), both are the same result, there is no superuser app or root explorer in the apps section, so it didnt get rooted
so i cant install GAPPS because i cant have root permissions and so on, something is happening
you know what i could do? thanks
ps.: iv tried evertying again renaming update.zip to root.zip in the first part, and the same result, cant get it rooted (no superuser or root explorer apps)
ps2.: my tablet is a ONDA VI30 8gb
I put CLEAR warnings and instructions on guide for a reason, the reason you use update.zip renamed is to keep the possibility of rooting open, when you install the update with usb or recovery you are closing the door on rooting (for now atleast), google are making it (for what reason i dont know as they give anyone the android sdk) so companys have to register there hardware for access to google apps etc.. try installing 4.0.3 then follow the guide again, updating to 4.1.1 then try rooting 2-3 times and it should get there.
hello
I have flashed my tablet without problem, thanks for the tuto, it's perfect
I have just a question, the google market is not present, how can I installed it ?
Follow ALL instructions Flash Root GAPPS(google apps playstore..) http://www.androidtablets.net/forum/...-v1-0-a-2.html
ok ill do
how do i install this 4.0.3???
i tried this file New ICS 4.0.3 Firmware for Onda Vi10/Vi30/Vi30W/Vx610W/Vi10 DeluxeT&K Online Store Blog | T&K Online Store Blog
but it asks to install the USB DRIVER and i cant use the .INF to install (both win7 or xp) its failiing, there is a (android) in my hardware manager that i cant install, and so i cant update to 4.0.3.
do you have a guide/firmware i could use?
thanks
WHY WHY WHY () PLEASE anyone reading this if your going to use my guide then FOLLOW IT ALL, i have made it as easy as possible for you, it has the link to Onda GENUINE firmware, i uploaded the files you need so you know the links are my GENUINE files, all you need to do is know what tablet you have in your hands, thats it. If you start using other firmware/custom roms then dont blame me if the tablet BRICKS, if it doesnt Root try a few times if still no success then go back to 4.0.3 for now, we will get it and i will post as soon as... any other questions i am happy to answer!! (rant over)
well so im lucky that i havent installed anything but only the ones in your post, but i dont know how to return to 4.0.3, if you have a good procedure could you give me pls, so ill return it to 4.0.3 and do it again your guide. right now my firmware is the one that i downloaded from your post, how could i return to 4.0.3?
as you said i went to the link again that you gave where i can find firmwares and i found this one
Vi30F_v0.51.rar
factory firmware, no upgrades
ill try to use this one to return it to 4.0.3
thanks
