Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 52
Thanks Tree9Thanks
Thread: *ALL* Onda SD-Card Firmware Installer
  1. #21
    Points: 70, Level: 1
    Level completed: 40%, Points required for next Level: 30
    Overall activity: 3.0%
    Achievements:
    7 days registered
    155931
    Nov 2012
    15
    Thanked
    2 times
    Points
    70
    Level
    i tried but every firmware file has like LiveSuitPack_v1.07.exe
    i run this file, it creates a lot of files, then i plug my tablet and nothing happens, again an ANDROID in my hardware manager on windows and i cant do anything
    how can i install my vi30 on windows so i could use these firmwares with .IMG file and so son?
    thanks
    Ads
  3. #22
    Points: 318, Level: 6
    Level completed: 36%, Points required for next Level: 32
    Overall activity: 0%
    Achievements:
    250 Experience Points 3 months registered 100 Experience Points 31 days registered 7 days registered
    155453
    Nov 2012
    Points
    318
    Level
    Quote Originally Posted by asjohnston3 View Post
    Just curious, which apps are not working? I have a rooted 811 running 2.0 and everything I've tried so far has worked.....
    Hi
    The apps works great. The problem is in Google Play. They cannot be installed from Google Play because they are supposed not to work. I think it's an issue with the permissions of google play in these chinese tablets. I've got a fix for vi40 ICS but I don't know if it would work in this model.
    Regards
  4. #23
    Points: 4,070, Level: 40
    Level completed: 60%, Points required for next Level: 80
    Achievements:
    3 months registered 31 days registered 1000 Experience Points 7 days registered 500 Experience Points
    153473
    Nov 2012
    Newcastle, England
    441
    Thanked
    112 times
    Points
    4,070
    Level
    40
    Onda V701
    Quote Originally Posted by trustno12003 View Post
    Hi
    Regards
    Just to be sure, the problem your having is only with google apps? Chrome/Maps etc... if so your correct, its because onda have no permission to use the store, download the apps you want example <maps.apk> (google will find) and put them on your external sd card and repeat the process with root explorer used to put playstore on.
    What man make's... Man breaks... Then put's it back together, correctly.
  5. #24
    Points: 167, Level: 3
    Level completed: 34%, Points required for next Level: 33
    Achievements:
    31 days registered 100 Experience Points 7 days registered
    156162
    Nov 2012
    Sweden
    Thanked
    1 times
    Points
    167
    Level
    Samsung GT-P7310, Onda V712
    Excellent work OP. Bought a V712 in Shanghai yesterday, updated and rooted without any problems thanks to your guide today!
  6. #25
    Achievements:
    7 days registered
    155931
    Nov 2012
    15
    Thanked
    2 times
    Points
    70
    Level
    hello? how could i install the 4.0.3 version on my VI30??
    i run the file from that link on onda.cn, it creates a lot of files, then i plug my tablet and nothing happens, again an ANDROID in my hardware manager on windows and i cant do anything
    how can i install my vi30 on windows so i could use these firmwares with .IMG file and so son? or do you have another guide to install this 4.0.3?
  7. #26
    Achievements:
    153473
    Nov 2012
    Newcastle, England
    441
    Thanked
    112 times
    Points
    4,070
    Level
    40
    Onda V701
    Quote Originally Posted by sirknow View Post
    do you have any guide diabolouz?
    Yes this one you are replying on, just download your firmware from the link and follow the guide, do not run any files from it just find the update.zip folder. I am in the middle of working on pre-rooted firmwares if you wish to wait, keep checking this link for yours - Genuine Onda Firmware Pre-Rooted with SU and Google apps - iiDiablousZz
    sirknow thanked this.
  8. #27
    Points: 77, Level: 1
    Level completed: 54%, Points required for next Level: 23
    Achievements:
    7 days registered
    155918
    Nov 2012
    Australia
    8
    Points
    77
    Level
    Onda Vi40 v1
    Forgive this stupid question but in your walk through notes are you saying to save zip to external sd?
    If so I am snookered as I cannot see the external sd no matter what I do.
  9. #28
    Points: 176, Level: 3
    Level completed: 52%, Points required for next Level: 24
    Achievements:
    7 days registered 100 Experience Points
    156399
    Nov 2012
    España
    Points
    176
    Level
    ONDA VI30 Ultimate
    Hello Guy
    I Upgrade my Onda VI30 Ultimate to the android 4.1.1 firmware that onda release
    But i notice that it was not rooted as the others firmwares.... so i come to your work to try to root my tablet
    SO as I upgrade my tablet as onda said(livesuit), i go directly to your ROOTING section:
    ROOTING-
    Now download this file Root-Inside.zip **New 25.11.12**
    Inside the Download are 2 files root.zip and Factory update.aml
    Now take root.zip and factory update and put them on your sdcard *Please make sure you have no other root.zip files on sdcard*
    Now with tabet switched off press the home key and after 3 seconds press the power key the white bot should show then the green droid will start a repair process and it will reboot when done.
    After reboot you should be rooted. Now remove the 2 files from sdcard.
    So i download that file and unzipped then i copy both files, root.zip and Factory update.aml to my root directoryName:  Captura1.JPG
    Then i enter on recovery mode and nothings happen, just appear my android death!!Name:  IMG_20121126_210909.jpg
Size:  1.43 MBName:  IMG_20121126_210923.jpg
    It can be the factory_upload_param bad update_package path??? i saw when i open an file manager app that my sdcard is under mnt/sdcard i must chage that?
    Please Can you upload a video to show us what we have to do and what must happen?
    I would like to get my tablet rooted...
  10. #29
    Points: 1,692, Level: 23
    Level completed: 92%, Points required for next Level: 8
    Achievements:
    1 year registered 1000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    13110
    Jan 2011
    Utah
    16
    Thanked
    1 times
    Points
    1,692
    Level
    23
    None
    I have a VI20W, which seems to never get updated. It is a non-normal format. Which firmware is the best for this tablet? I can't seem to find a newer one than the original ics release for it. I know the VI40 VI30, etc. have newer updates. The only thing different about it is the aspect ratio. 4:3 instead of 1.66:1 or whatever it is on the others. Any thoughts?
  11. #30
    Achievements:
    156399
    Nov 2012
    España
    Points
    176
    Level
    ONDA VI30 Ultimate
    Guys, i could rooted my Onda Vi30 Ultimate with the official onda 4.1.1 firmware with this method Root MANY ANDROID! [Upd: 22.11.2012] - xda-developers
    I just download the file, unzziped on the desktop, activate the USB debugger on the tablet, run the RunMe.bat file and just follow the instrucction and it will be done!
    However, now i cant download all aplications from the play store, for example with 4.03 and 4.0.4 official roms i could download chrome app but not with this rom
    How can i solved that? anyone knows? (donwload the apk from internet and install on the device is not a solucion xD )
    Thanks!
Ads:
  1. Onda V2.1 Firmware Changes
    By benzi in forum Onda Tablet Forum
    Last Post: 01-07-2013, 09:03 AM
  2. Replies: 6
    Last Post: 12-08-2012, 05:09 PM
  3. Onda Firmware NOTE
    By iiDiabolusZz in forum Onda Tablet Forum
    Last Post: 11-13-2012, 03:01 AM
  4. Onda VI40 V3 vanilla 1.1 firmware
    By maddog1979 in forum Onda Tablet Forum
    Last Post: 06-26-2012, 02:03 PM
  5. Onda 1.2 firmware and BBC iplayer stuttering on Onda Vi40
    By mikeburton1955 in forum Onda Tablet Forum
    Last Post: 06-16-2012, 11:32 AM
all* onda sd-card firmware installer v1.0
alldro 3 speed firmware
how to install firmwares on onda tablet vi10
how to install onda firmware v802
how to install onda firmware v802 youtube
onda v712 rom
onda v802 firmware download
onda v802 firmware tutorial
onda vi30 ultimate firmware
onda vi30 ultimate firmware 4.1
rom onda v712
www.android onda mid 4.0.3 firware download
