Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 32
Thanks Tree3Thanks
Thread: [MOD] Rooted PDN ROM (7/24, 8/6, 8/20 versions): Market, volume hack built-in
  1. #1
    Developer
    Achievements:
    Recommendation Second Class Recommendation First Class 7 days registered 31 days registered 3 months registered
    1423
    Aug 2010
    USA
    1,504
    Thanked
    105 times
    COBY KYROS 7015 | 7015A
    Exclamation [MOD] Rooted PDN ROM (7/24, 8/6, 8/20 versions): Market, volume hack built-in
    (note: keeping the original title, even though there is now a 9/23 update -- too many links to this location so I cannot change it)
    NOTE: This is presented "as-is" -- please USE AT YOUR OWN RISK! If you have any issues with this mod, you should be able to re-flash back to stock to get back to a stable baseline.
    What this is:
    A full firmware modification for the white Pandigital Novel (all versions, tmk). See the changelogs for details, as these mods have changed heavily with each revision. The main versions WILL wipe all user data, so be aware of that.
    ver1 (7/24 based) altered firmware link: S10_08_01_K_PD_INX7E_ENG_6410POP.zip
    md5sum: f2ca61787dc97493edba999397f6ba23
    ver2 (8/6 based) altered firmware link: S10_08_12_K_PD_INX7E_ENG_6410POP.zip
    md5sum: 7e2e71ca01c7ecd9d5539b56f4504336
    ver3 (8/20 based) altered firmware link: S10_08_27_K3_PD_INX7E_ENG_6410POP.zip
    md5sum: ec2d1481a1c462e909cdd748f829e510
    ver4 (9/23 based) altered firmware link: SD_PDN_4_01_GE_PD_INX7E_ENG_6410POP.zip
    md5sum: b2fffeb029e256b09a4f5c2bd4b7bd9a
    ver4 supplement (run after ver4, non-destructive): SD_PDN_SUPP10_PD_INX7E_ENG_6410POP.zip
    md5sum: 147f58ffb54f88cd751a656da8ccf7e8
    (supplement is a 4.00 / 4.01 add-on that fixes root on 4.00 and also fixes the rotation issues with both 4.00/4.01)
    ver1 (7/24 based) changelog: Adds the volume hack and the Google Experience Alpha. Just choose which home screen to use after the reboot, and you are in.
    ver2 (8/6 based) changelog: Additionally, I added the DVM update, the root hack as as well as Clockworx's "non-ugly" Market hack. I've heard that the ZIP file name syntax doesn't work. I would suggest renaming it to "S10_08_06_K_PD_INX7E_ENG_6410POP.zip" before putting it on your SD card
    ver3 (8/20 based) changelog: I added the root hack, a stripped down GE (using the 2.1 alpha as my guide), the "non-ugly" market hack, "PSMode=CAM" for Wireless, and the notification bar hack. The DVM update is being removed as some of you didn't care for it in the last mod. To get past the initial Google screen after the first reboot: tap all four black corners clockwise (starting with the upper left) and that will bypass the setup screen. It should not reappear. Also, a video I found on this, in case you have any problems: Android Quick Tip: How to Bypass Setup Wizard
    ver4 (9/23 based) changelog: Has full GE with non-ugly hack and Vending.apk October 2010 update, root hack, PSMode=CAM for wireless, notification bar, gottahavit soft buttons, 270 rotation (kind of works, crashes on some homescreens), Ubuntu font used as main font, a winhelp2002 hosts file to reduce adware, and a Cruz launcher with ability to add more icons to the homescreen. After the firmware install / first reboot, choose "home" as your homescreen, and choose it as the default if you don't want to choose after each reboot. The PDN launcher is still there and should still be accessible by accessing a PDN app in the pulldown menu.
    probbiethe1 and johnsmith41 thanked this.
    Devices: MID7015-4G | MOD: HoneyComb Hybrid HCV31.0 GB38 with Extreme Power Booster | ROM OS: Rooted Android OS 2.3.1a GingerBread
    Devices: MID7015A-4G | MOD: HoneyComb Hyrbird HCV15.0-B22V with Extreme Power Booster | ROM OS: Rooted Android OS 2.1a Eclair
    Devices: M150A12 | MOD: HoneyComb Hybrid HCV15.0-B22V with Extreme Power Booster | ROM OS: Rooted Android OS 1.6a Donut
    18x Tablets Owned/Tested/Configured/Tweaked: Running OS: 1.6, 2.0, 2.1, 2.2, 2.3 | Since 2010
    Ads
    Advertising world
  3. #2
    Member Achievements:
    7 days registered 31 days registered 3 months registered 1 year registered 100 Experience Points
    2152
    Aug 2010
    53
    Augen Gentouch
    If you have a v1 board, which I am positive that I have even though the "new" serial # ID method "claims" that mine is the "B" v2 board, yet I still have the MAX present in dmesg, anyways...
    wasted several hours flashing in various combos and 3 or 4 various new google IDs, dalvik cache purges, OEM fw flashing, re-flashing to v.4 of this release ALL of which ended up with an install in which attempting to install anything from the market resulted in an instantaneous failure to install on my WPDN...
    rolling back to the ver.3 version plus the soft button hack as that HAD been working great for me
    It's at times like these that I really miss having clockwork mod like we had on the GT...
  4. #3
    Developer
    Achievements:
    1423
    Aug 2010
    USA
    1,504
    Thanked
    105 times
    Both mine had version 1, and you know when I got the second one from Kohl's didn't have the shutter. Wasn't until I had flash ROM 9/23 on it and played the motion.mp4 video and wa-la same issue. I also had back-light bleeding around the edges just like you had reported.
  5. #4
    2152
    Aug 2010
    53
    Augen Gentouch
    With ver.3 back + soft button hack on my WPDN, everything is back to "normal". Market is installing again.
    [EDIT]
    As a precaution when I rolled back to ver.3 the final time, I installed OEM 8/20 fw first and THEN roebeet's ver.3. I had previously attempted rolling straight back from ver.4 to ver.3, however it appeared that some detritus from ver.4 may have survived the ver.3 flashing which led to further experimental flashing on my part, i.e. flash OEM 9/23 fw, then ver.4 + supplement, etc. before finally giving up to 8/20 OEM to ver.3 + softbutton hack...
    [/EDIT]
    Perhaps if I have time at some later date I will re-attempt ver.4 and mess around with the ugly market fix to see if I can get something going. Logs from logcat weren't helpful at all either as I couldn't see anything obviously wrong...
    This is just meant as a public service set of comments, as in if things w/ver.4 aren't quite working for you, it's most likely because it's a half-baked release and still needs some work.
    As to hw revision, I can't help but wonder if someone bought a 2nd WPDN from that BBB swapped a v1, maybe peeled off the serial # sticker and put it on the one returned in the box as that # matched the one on the box, and I seem to recall reading that early v1s lacked the sticker on the device. Also as I originally mentioned elsewhere it seemed that my box had been opened before as the "bottom" tape closure was open already which I didn't notice until I had gotten home.
    Backlight bleed: on mine(and tipstir's apparently) I can see a triangularish area of brighter light starting to just to the right of the Pandigital logo(orientation: portrait, Pandigital at top), most evident at "lower" backlight brightness settings. Bad for dark conditions when you'd want as low as possible backlight as I found it makes the areas just to either side of the bleed affected area too dim. Looks from that like they just used a LED backlight too given the bleed pattern. (anyways stopping now as I'm going way offtrack.)
  6. #5
    Developer
    Achievements:
    1423
    Aug 2010
    USA
    1,504
    Thanked
    105 times
    Bad panels need to be returned to the store. I can't stand to see back-light bleed. Brightness and contrast always get messed up also.
  7. #6
    Senior Member Achievements:
    Your first Group 500 Experience Points 250 Experience Points 100 Experience Points Tagger Second Class
    1547
    Aug 2010
    Michigan
    516
    Thanked
    13 times
    Waiting for a good iPod Touch Android Device
    Is this only for the white version?
  8. #7
    Junior Member Achievements:
    7 days registered 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    7870
    Nov 2010
    10
    Does the V.4 with the full GE and non Ugly hack still have the battery drain when in standby mode problem?
    ...also astro does not seem to install.
  9. #8
    Points: 2,591, Level: 30
    Level completed: 94%, Points required for next Level: 9
    Overall activity: 0%
    Achievements:
    1 year registered 1000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    8644
    Dec 2010
    New Hampshire
    33
    Thanked
    1 times
    Points
    2,591
    Level
    30
    White Pandigital Novel
    Love your mods. My only complaint is that the marketplace add doesn't work for me. I keep getting a "server error" when I try to start it. Also I'm wondering if your gonna mod the latest OEM update.
  10. #9
    9985
    Dec 2010
    PDN White
    Hi all
    I bought my family two white PDNs for the holidays, and am trying to root them. I've downloaded the v4 file in this thread, placed it in the root of my SD card, and when I hold power & volume up I get to the triangle! screen and it loops there until I hit the reset button. I've tried renaming the v4 file to "S10_08_06_K_PD_INX7E_ENG_6410POP.zip" as was suggested in V2. Am I missing something I need to do beforehand? I've been rooting android devices since the G1, but this has me stumped for some reason.
    Edit: After a few more google searches I realized the update needed to be on the internal SD card, not the external one. Flashing now!
  11. #10
    9986
    Dec 2010
    Norman, OK
    Thanked
    1 times
    PDN white
    Quote Originally Posted by Jaysn View Post
    Hi all
    You might try removing the internal sd. Pandigital » Pandigital Novel Android Open Platform kit. (White version) This prevents it from taking command and also saves the restore info in case you want to go back to stock.
    probbiethe1 thanked this.
Ads:
  1. [ROM] LY-706 256M 1.7.4 rooted v0.1i WORKING MARKET FROM FLASH
    By tipstir in forum Gome Flytouch Firmware
    Last Post: 02-05-2012, 09:05 PM
  2. [ROM] Gentouch78 Rooted v0.3 (for v1)
    By tipstir in forum Telechips TCC8902 Development
    Last Post: 12-07-2011, 04:09 AM
  3. [ROM] Flytouch 256MB 1.9_88 rooted with market installed v0.2
    Last Post: 09-12-2010, 09:53 PM
  4. [ROM] EPAD 128M 1.9_88 rooted v0.3i WORKING MARKET FROM FLASH
    Last Post: 09-07-2010, 11:30 AM
  5. LY-706 audio volume and app market
    By FMurtz in forum WonderMedia WM8505 Tablets
    Last Post: 08-20-2010, 10:41 PM
[mod] rooted pdn rom
how to root pandigital novel 7 fw s10 08 06 k pd inx7e eng 6410pop
pandigital 7 rom
pd inx7e eng 6410pop.zip
pdn 7 rom
rooted pdn rom
sd pdn 5 02b ge pd
sd pdn 5 02b ge pd inx7e eng 6410pop
sd pdn 5 02b ge pd inx7e eng 6410pop.zip
sd pdn 5 02b ge pd inx7e eng 6?410pop.zip
tim geek net nchntr files android home app installer update inx7e eng 6410pop
tim geek net nchntr files pandahome app installer update
