Results 1 to 3 of 3
  1. #1
    66484
    Nov 2011
    WPDN
    Uninstall CynogenMod 6.2.0-BETAWPDN
    Hi,
    Since I flashed to this firmware from the latest Pandigital OFW, I can seem to connect by WPDN to my PC or even see the SD card. Any idea how I can flash back to stock?
    Ads
  3. #2
    70102
    Dec 2011
    Wink
    Hope this helps...
    I screwed up and flashed the s10 CM6 over the current sh20 and guess what... had issues. Since I'm a noob at this I thought I had bricked my WPDN as it got stuck in the flash loop. Hit the reset button and booted to PD screen then Android screen and froze.. couple of random up/dn vol hits (lots of cursing) and somehow I got into the system launcher (odd but hey I screwed it up anyway). Then like you, I could not get my pc to see my WPDN int/ex SD card no matter what i did until....
    When you plug the usb into your device a little memo comes across the top bar---pull the info bar down and then hit connect usb device or some such--this will take you to a second screen that asks if you want to connect your sd card via usb or something similar and presto change-o you are in. Then fix as you see fit --- me, went back to pd3/11 and will try going the OPDN Base route but last time the GAPPS vers killed my wifi
    Hope it helps -- but since this is an old post you probably already got your answer...
  4. #3
    84709
    Jan 2012
    plug in your charger and your usb when connecting to your pc
Ads:
  1. Help uninstall/removing apps
    By lori77563 in forum Sylvania Tablets
    Last Post: 11-22-2011, 11:21 AM
  2. Uninstall native Documents To Go?
    By pwalt in forum Android Tablet Apps
    Last Post: 06-08-2011, 08:40 AM
  3. how to uninstall the clockworkmod?
    By schagox in forum Coby Generation 1 Technical
    Last Post: 05-21-2011, 09:55 PM
  4. how do I uninstall the pre-installed apps?
    By bratcat in forum Gome Flytouch II Variant 2
    Last Post: 04-25-2011, 07:45 AM
  5. Uninstall unused apps
    By FMORA in forum Coby Tablets
    Last Post: 04-15-2011, 01:01 PM
how to hard reset wpdn
how to unbrick a pandigital novel
how to unbrick pandigital novel
how to unbrick wpdn
pandigital cm6 for s10
pandigital s10 cm6
remove firmware from pandigital novel
unbrick pandigital novel white
unbrick white pandigital novel
wpdn firmware
wpdn unbrick
