Results 1 to 7 of 7
  1. #1
    Junior Member Achievements:
    9294
    Dec 2010
    15
    Thanked
    1 times
    Openandroid firmware
    well i made the plunge and flashed the White Novel to open Android. The install went flawlessly. I gained a much improved response from the screen. The following apks downloaded from various sources work. New fav reader is Ireader which reads Palm PDB and txt file which i convert using Calibre. MP's play well on "3" and the stock video runs well on any videos i convert using anyconvert (free) and set it to google android config.
    Wifi is good, Keyboard is usable, It would be nice to have a flash but the market i get around using a slideme.apk which give some access to applications. (note i installed a 16 gb micro internally, (removed before flashing, then installed after) After the update it is remapped to /data and is used behind the scenes when u install apps. nook app crashes but i haven't deleted the .so file needed to make it run smoothly. Haven't seen any good note taking apps, but always searching for working apk's. Might want to make a list of stuff that runs. Thanks to the Board for making my search easier!
    3_Cubed_1.0.70.apk
    aCommander_1.0.1.apk
    AK_Notepad_2.2_updated.apk
    Aldiko_Book_Reader_1.2.14.apk
    Algeo_0.8.1.apk
    Android_Blackjack.apk
    Android_Torrent_4.5.1.apk
    AndroRadio_1.4.apk
    Angry_Birds_1.4.2.apk
    Angry_Birds_Seasons_1.1.1.apk
    APKtor_1.0.8.7.apk
    Appslib_2.apk
    arcMedia_0.34b.apk
    BestTube_1.1.apk
    bn.ereader-v2.4.0.apk
    com.access_company.graffiti.apk
    com.amazon.kindle_v1.1.0.90220088.apk
    com.chaozh.iReader-1.apk
    com.google.android.apps.maps_v4.7.0.apk
    com.kobobooks.android-v2.2.159.apk
    com.kobobooks.VMBordersUS.android-v2b150.apk
    com.reader.books.laputa.ui_v3.0.3.apk
    DolphinBrowserHD-v4.0.0.apk
    Jewels_1.85.apk
    jp.sourceforge.soopy.hidden.ssid.enabler.apk
    k9mail-3.316-release.apk
    Linpack-for-Android_v1.1.5.apk
    MaplePaint_1.2.apk
    OfficeSpace_Soundboard_2.0.0.apk
    PAC-MAN_1.0.3.apk
    RockOn v1.4.8.apk
    sam.apk
    Solitaire_1.12.1.apk
    TitaniumBackup_latest.apk
    VMBordersUS-v2b150.apk
    vudroid-1.2.apk
    Ads
  3. #2
    8478
    Dec 2010
    Nice job posting the apps that worked for you anhaux. I'm wondering about Angry Birds. I have it on my Sony Xperia running 2.1 and I tried downloading it for my PND. It installed but the backgrounds are messed up but worse then that it runs very, very slow to the point of being unusable. Did you have to hunt around to find those two versions that worked? I downloaded Angry Birds Lite and Season from the Market with the same results. I'm running OpenPlatform V3 with Market built in. Thanks.
  4. #3
    9294
    Dec 2010
    15
    Thanked
    1 times
    Im not exactly sure what site i got angry birds from, I dont have the V3 open android, so i actually have no market except for slide me, im not sure if there is a difference in micro SD speeds so accessing it might be affected. seem to run smoothly, my actual fav game is a bejeweled clone... and of course using it as a book reader...
  5. #4
    9294
    Dec 2010
    15
    Thanked
    1 times
    I loaded v3, market didnt work, unit slowed way down, and when i reinstalled the version from pan digitals website, angry birds didnt work anymore...but season still does...not sure what changed
  6. #5
    10707
    Dec 2010
    8
    pandigital novel white 7 inch
    do you have a link to a tutorial on how to replace the internal storage?
  7. #6
    9294
    Dec 2010
    15
    Thanked
    1 times
    Remove back panel
    No link, all I did was use a flat bladed screw driver plave in the small lip and slowly twist, once there was a gap i pried up using another screw driver. Its held in by three tabs, if you put the flat of the balde directly under the G in pandigital you miss the tabs and can pry it up and off. then to the left abouve the molex connector is the micro sd, push up and then lift the sd out and replace. Right now i went overboard on the 16 gb cant ever see being able to fill this up...
  8. #7
    9294
    Dec 2010
    15
    Thanked
    1 times
    Pictures
    Unless your using the Cruz firmware 2gb or 4 gb is plenty and 16 gb is over kill, most time syou want the largest sd card external you can find, its much more useful siince you have no access to the interanl card (i think it shows up under root as the data folder) here are some pictures from another siteName:  HXDsG.jpg
Size:  163.7 KBName:  ZuNhA.jpg
Ads:
  1. New White firmware is available.
    By exscentric in forum Pandigital Novel White Firmware
    Last Post: 04-17-2011, 06:25 PM
  2. M001 1.74 Firmware
    By g4jnw in forum WonderMedia WM8505 Tablets
    Last Post: 02-09-2011, 06:31 PM
  3. Firmware 2.02
    By ImagineThat in forum Sylvania Tablets
    Last Post: 01-19-2011, 09:14 AM
  4. firmware where to find ?
    By indiandevil in forum WonderMedia WM8505 Tablets
    Last Post: 12-02-2010, 06:39 AM
  5. where can i download firmware 1.7.2?
    By Amper in forum WonderMedia WM8505 Tablets
    Last Post: 08-23-2010, 08:31 PM
Slideme.apk
angry birds apk for pandigital novel
angry birds para android pandijital
bn.ereader-v2.4.0.apk`
descargar sam 4.0 slide me para tablet
hidden ssid enabler apk
hiddenssid enabler apk
kobo apk for android 2.1
kobo books apk
pandigital ereader apk
pandigital novel internal sd card
