Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
  1. #1
    Administrator Achievements:
    100,000 Experience Points Veteran 50,000 Experience Points 25,000 Experience Points 10,000 Experience Points
    795
    Jul 2010
    Canada
    3,486
    Thanked
    432 times
    [ROM] Generic Rockchip 7" Android 1.5 Tablet RK2808a Firmware Guide
    Full specs and more pictures here
    Before attempting to flash any firmware onto your device, please verify that you have a matching device.
    There has been at least 5 mainboard revisions for this device. Externally, they look identical.
    Firmware flashing guide post 2
    Should look similar to this, and has a Rockchip processor. It will also be running Android 1.5:
    Utopia models
    Batch 1) 5V Input Voltage, Red Power Indicator Light, No Camera, Plastic Casing Only
    Batch 2) 5V Input Voltage, Red Power Indicator Light, Front-Facing Camera, Plastic or Metallic Casing
    Batch 3) 9V Input Voltage, Blue Power Indicator Light, Front-Facing Camera, Plastic Casing Only
    Downloadable firmwares
    Official release firmwares are available here:
    Downloads - apad-irobot - Project Hosting on Google Code
    Unlabeledreleases are for batch 2.
    Hybrid firmwares by Rogerbraun for batch 2: SlateDroid - The BIGGEST Android Tablet Forum on the Web!
    Hybrid firmware by me for batch 2: HybridKangXau
    Discuss here: http://www.androidtablets.net/forum/...ad-irobot.html
    Other models:
    Batch 2/3 intermediate Sample Batches) 5V Input Voltage, Blue Power Indicator Light, Front-Facing Camera, Plastic Casing, iWeb box
    0630, firmware supplied by HiApad: BlueLED_RK2808a_SampleBatch_0630CN.zip - apad-irobot - Blue LED RK2808A Sample Batch Compatible Firmware 0630CN, NOT FOR BATCH 3 - Project Hosting on Google Code
    TabletStoreUK Hybrid firmwares types 1 and 2 (might work for others): Support - The Tablet Store
    Batch 3 from Moonse) 9V Input Voltage, Red Power Indicator Light, Front-Facing Camera, Metallic Casing Only
    I have seen multiple reports of this revision bricking upon flashing firmware. It is best NOT to flash anything if you have this revision.
    Anyways this is a mess. Apparently on some devices, shipping firmware is 0612, meaning that you can use batch 3 firmware.
    0802, firmware kindly supplied by HiApad: Multiupload
    Huawei Ideos S7-104 on Singapore ROM, HSG X5A, RK2818 RT7, (Past: IMX515 APAD, RK2808 APAD)
    My written articles are licensed under a Creative Commons Attribution-NonCommercial 3.0 Unported License
    本人現在已比較小時間瀏覽此論壇。有關和此論壇的合作關係,請聯絡admin或4Nines。
    Ads
    Advertising world
  3. #2
    795
    Jul 2010
    Canada
    3,486
    Thanked
    432 times
    How to for batch 1&2:
    Apad iRobot Firmware Update Tool (update.img) » HiApad
    Use the tool mentioned above with the downloaded .img file to flash.
    Here's a video of how it is done, using another tool. The method is similar.
    For 9v models, the firmware flash mode is different
    from Asure on Slatedroid
    1. Power switch off
    2. insert top USB to PC
    3. Power switch on, nothing happens, this is ok
    4. press & hold menu
    5. press & hold power
    6. keep pressing & holding both, the device is detected
    7. press the flash button in the rock usb flasher..
    It stays in loader mode, as long as you keep pressing the buttons.
  4. #3
    Junior Member Achievements:
    1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    4905
    Oct 2010
    philippines
    14
    epad MID701
    im using mid 701 android pad...with 9v input Voltage, Red Power Indicator Light, Front-Facing Camera..my android is v1.7.4 can you please help me re flash my unit?because my unit has no apps market installed and even i change the language onmy unit everytime i use it its still in chines language...please help me with this matter..tahnx!
  5. #4
    500 Experience Points 250 Experience Points Tagger Second Class 100 Experience Points 3 months registered
    6584
    Nov 2010
    México
    M1 SmartPad
    Hello xaueious,
    I'm not asking for help just information. I just bought a Chinaleap M1 Smartpad with RK2808 firmware 1.5, rockchip version 1.2.7, kernel 2.6.25... I have been looking for a way to update the firmware to 2.2 or 2.1 but I don't know if that's a good idea... Do you suggest I should do the update?
    Thanks in Advance!
  6. #5
    16299
    Feb 2011
    Hong Kong
    ASK 711 SP
    Hi Guys, I have a ASK 711 SP also know as "Ask Internet Smart Pad" ( details here:ASK COMPUTER TECHNOLOGY CO. --MP3¡¢MP4¡¢MP5¡¢Mobile Phone¡¢Digital Photo Frame¡¢SD card¡¢USB Flash Disk¡¢Others ) its a Rockchip based tablet. (similar to the so called "smartPad" )
    2 questions,
    1) is it possible to remove all the Chinese bloatware/apps that comes with it, do I need to unroot uninstall the apps I don't want then re root, if so how do I do it with this model?
    2) I am stuck on android firmware (cupcake) 1.5, which is basically obsolete now as most of the new apps and games wont run on this outdated OS. Is there anyway to update this model to at least 1.6 or better still 2.2?
    Many thanks in advance (noobie tablet-er)
  7. #6
    17266
    Feb 2011
    Colombia
    Apad Moonse E7001
    My power Button Has broken also my pc wont recognize my Apad
    Hi Guys i have read all this post and others about how to fix and Apad even a Mp4 or Mp5 device... First of all thanks all for your support patient and time. Thanks a lot.
    The procedures that you mentions doesnt work to me .. ( Basically My Apad Isn’t recognize for my pc , even using the procedure of the second entry of xaueious) .. I have try this. .even the short circuit into the flash device but my apad doesn’t respond.
    This is my situation, i bought a Moonse Apad E7001 with red led and plastic wrap, i used this device very well for 4 moths , I just have little problems like an usb port #1 doesn’t work , when i plugged the hedphones the apad turn off , the apad also turned off if I pressed a little with my hand in the power button area, Well wasn’t perfect but still the apad worked
    i let it used for a week sort of .. and the moment when i decided turn on , my apad just got black and won't boot. In the pass i fixed this pushing very hard the power button,. but this method stop working anymore, desperate I just started pushing the power button too hard that i break it. . so i decided to open to fix the power button that I suspect was the problem
    After take time to search on internet ,… well I released very late (after open the device and remove the power button ), that wasn’t the power button problem or a hardware problem instead a software fail or firmware fail so like I said before I’ll tried the xaueious steps ( but just pressing the menu button, like the youtube video says ) , tried the short cort circuit,.. Nothing
    I’am actually trying a battery drain ( i have read this in another forum ) but the apad battery don’t uncharge, I guess cause I have a month trying this (let It keeping the power button on ), when a put a wire in the power button the apad turn’s black or make a tiny flash
    I posted a pictures of my apad device, please take a look.
    ImageShack® - Online Photo and Video Hosting apad opened with a little description
    ImageShack® - Online Photo and Video Hosting apad opened power button zone
    TinyURL.com - shorten that long URL into a tiny URL apad opened back screen
    ImageShack® - Online Photo and Video Hosting apad opened screen and body
    Thanks you all for your support or suggestion.
  8. #7
    795
    Jul 2010
    Canada
    3,486
    Thanked
    432 times
    I don't really how how to fix these things, but the reliability of these unbraded RK2808 tablets was terrible. I think the failure rate is over 50% by now.
  9. #8
    37275
    Jun 2011
    after flashing "Wi-Fi Mac Address is unavailable how do i solve this? my older version is Yuixing and after flashing it was Ruixing
    anyone here have the Yuixing FW
  10. #9
    100 Experience Points 7 days registered 31 days registered
    48881
    Aug 2011
    Manila, Philippines
    Epad 9V 1.2
    Unhappy Epad query
    Dear Admin,
    I have an Epad 9v- 1.2 version. I want to upgrade it to the highest version that the market now has, can it be possible? I cannot play the videos correctly, It gets stuck at some point of time. I think the RAM cannot hold a lot of memory.
    If so, please e-mail me back at to_cath@yahoo.com. PLease send me the right files as well. I have a hard time finding the right link. There are so many and maybe I will be wrong.
    Waiting for your response.
  11. #10
    111798
    May 2012
    brazil
    irobot rk2808a
    Quote Originally Posted by xaueious View Post
    my irobot brikou, no longer recognizes the pc (usb) how can I do recognize it again? mine is a tablet irobot rk 2808A. silver (plastic) two usb, red light, I saw something about making a short on flash.
    if possible show me the correct firmware.
    Sorry my English because I am Brazilian. Thank you.
Ads:
  1. Replies: 17
    Last Post: 12-07-2011, 02:28 PM
  2. Rockchip 10 inch Android Tablet RK2808
    By cnadigtial in forum Rockchip RK2808 Tablets
    Last Post: 01-04-2011, 02:26 PM
  3. Generic Rockchip RK2808a 10" Tablet Specifications and Pictures
    By xaueious in forum Rockchip RK2808 Tablets
    Last Post: 08-11-2010, 07:30 PM
  4. Generic Rockchip RK2808a 7" Tablet Specifications and Pictures
    Last Post: 08-02-2010, 07:31 PM
  5. [ROM] HKX Custom Firmware for Batch 2 Rockchip 7" Apad iRobot - 0801
    Last Post: 08-02-2010, 04:34 PM
cmgm7
cost of a 7-inch android smart pad rockchip 1.2.7
firmware rockchip 2906
generic tablet firmware
msi m727hc rock chip android tablet firmware
redpower android pc
rockchip 2906 firmware
rockchip rk2906 firmware
rockchip rk2906 firmware download
rockchip tablet firmware
rom apad rk2808
tablet cmgm7
