Results 1 to 7 of 7
Thanks Tree1Thanks
  • 1 Post By dave63
Thread: Pipo S1 Charging & English Manual Questions
  1. #1
    159478
    Dec 2012
    Washington State
    Pipo S1
    Hello! I am new to this so forgive me for not knowing all the protocol. I just received a Google Android 4.1 jellybean I ordered for my Grandson. To my astonishment the manual is in Chinese. It also did not come with the AC adapter I asked for. I bought it through Amazon, and the maker is Pipo S1. It did come with 2 cords that appear to be USB.
    It did come on but only a few seconds so I assumed it needed to charge. I took a chance and hooked it up to my
    pc. Now it doesn't turn on at all. I hope I didn't break it. I've emailed the seller, but no reply. I only see my Grandson twice a year so I really wanted it set up for him on Christmas morning. I would appreciate any advise you can provide.
    I must point out that I am blonde, senior, and had two strokes so keep it simple. LOL I'm convinced our generation did not come with the computer gene installed. Thanks in advance,and I wish you each a Merry Christmas.
    Harli
    Ads
    Advertising world
  3. #2
    Senior Member Achievements:
    1,000 Experience Points 3 months registered 500 Experience Points 250 Experience Points 31 days registered
    149231
    Oct 2012
    Australia
    147
    Thanked
    24 times
    Google Nexus 7
    Hi Harli. I've noticed you've tried several avenues to fix the problem. One suggestion recommends you remove the battery and then replace it and try the power switch again. This may or may not work. You should contact the seller to see if they can supply the power supply and an English manual. This would be good grounds to return the device as it incomplete or may be a bad unit. Charging via USB should not break it but may take longer to fully charge the device. Have you considered a better more mainstream device like a Google Nexus 7 or a Samsung Galaxy Tab 7? They may cost a little more but as they're more popular they're better backed warranty wise and come with power supply unit in the box.
  4. #3
    Points: 4,773, Level: 44
    Level completed: 12%, Points required for next Level: 177
    Overall activity: 0%
    Achievements:
    Veteran Recommendation Second Class Tagger Second Class 1,000 Experience Points 1 year registered
    6397
    Nov 2010
    Kansas
    656
    Thanked
    38 times
    Points
    4,773
    Level
    44
    Xoom / HP Touchpad / Samsung Galaxy / Viewsonic gTablet
    Hello and welcome to the forum!
  5. #4
    Points: 98,910, Level: 100
    Overall activity: 100.0%
    Achievements:
    Veteran 50,000 Experience Points 25,000 Experience Points Recommendation First Class Recommendation Second Class
    23311
    Mar 2011
    Chicago, IL
    13,076
    Thanked
    1551 times
    Points
    98,910
    Level
    100
    NOOK Tablet Stock NOOKcolor Rooted & ManualNooted Google Nexus 7 (2013) 32GB
    Hello Harli, welcome to the forum, glad you decided to join us here at Android Tablets. I'm moving your thread to the Rockchip RK3066 Tablets forum for you, where more people familiar with that tablet are likely to join the discussion and try to help you. Enjoy the forum!
    If it's important to you, you'll find a
    way. If not, you'll find an excuse.
    If you're too busy for friends,
    You're too busy.
    Attention lurkers! Join the forum,
    and enter Spider into the referrer
    field of the application.The $0.00
    USD fee will be waived.
    People will forget what you said.
    People will forget what you did.
    But, people will never forget
    how you made them feel.
  6. #5
    Super Moderator
    Points: 3,185, Level: 34
    Level completed: 90%, Points required for next Level: 15
    Overall activity: 12.0%
    Achievements:
    1,000 Experience Points 31 days registered 3 months registered 1 year registered 100 Experience Points
    53159
    Sep 2011
    602
    Thanked
    72 times
    Points
    3,185
    Level
    34
    Welcome to the site.
  7. #6
    161640
    Dec 2012
    UK
    Thanked
    1 times
    pipo S1 SAMSUNG GALAXY TAB 2 10.1
    Hi I hope you have resolved you charging issue. I have a pipo s1 and had a similar problem with mine. When I plugged the charge cable in the red led by the HDMI came on but the screen did not power up as it should. I then plugged the cable into my samsung Galaxy tab charger and the tablet powered up. I can only assume the charger amperage was not high enough. I have since bought a 2amp usb wall charger and it has worked great since. Hope this helps
    kellogg thanked this.
  8. #7
    168013
    Feb 2013
    Spring TX
    PIPO S1
    Hopefully this may be of some help although I see that you have not been on in a while.
    I have the same tablet that you got for your grandson, the two cable that come with it are as follows a) short micro usb/b (male) to USB (female) adapter (for a keyboard) and b) longer micro usb/b (male) to USB (male) for data transfers, and c) a medium length charging cable with a USB (male) end for charging, you can buy any 5v USB charger adapter for this cable OR plug it into the USB on your PC. I actually use a spare power adapter for our MajicJack phone adapter that is also 5v, and it works fine for charging the S1, the ONLY complaint about the charging cord I have is that it is too short for using other than charging (ie: keeping it charging while you are sitting somewhere using it).
    Other than that it works great and is pretty peppy thanks to the 1.6ghz dual proc.
Ads:
  1. English Manual
    By craftycaroline in forum Android Tablet Q&A
    Last Post: 11-26-2012, 10:41 AM
  2. english manual
    By sadiki in forum Android Tablet Apps
    Last Post: 11-13-2012, 05:29 PM
  3. English user manual
    By macthecat in forum Onda Tablet Forum
    Last Post: 05-17-2012, 05:37 PM
  4. English Manual
    By Royandroid in forum Allwinner A10 Based
    Last Post: 04-28-2012, 01:47 PM
  5. English manual for Cube U9 GT
    By Madra_Rua in forum Rockchip RK2918 Tablets
    Last Post: 10-16-2011, 01:34 PM
how to charge pipo s1
my pipo tablet wont turn on
pipo s1
pipo s1 charger
pipo s1 charging problem
pipo s1 doesnt turn on
pipo s1 manual
pipo smart s1 manual
pipo tablet english manual
pipo tablet manual
pipo user pipo1111
pipouser pipo1111
