Results 1 to 5 of 5
  1. #1
    Junior Member Achievements:
    31 days registered 100 Experience Points 7 days registered
    80566
    Jan 2012
    Australia
    samsung galaxy 10.1
    Mtp device installation issue
    Hi
    I got a galaxy tab 10.1 for chrissy and it is great. I have a small problem connecting it to my pc however. Each time i try and it begins installing the device i get an error stating it had a problem installing the mtp device with a code 18 in the driver. Now i have made sure i have the latest Kies installed so the drivers should be upto date and i have tried contacting samsung about it but there has been no help there yet. I have also tried different usb ports to eliminate that as the problem. The following is some additional details:
    Pc OS : XP sp3
    3Gb ram
    1.6GHz dual core cpu
    Kies 2.1.1.11124_17
    In addition I can connect to kies wirelessly though transferring anything large like a movie to the tab that way seems slow and i am hoping that a direct USB connection will be faster.
    Thanks in advance for any replies :-)
    Sent from my GT-P7500 using Android Tablet Forum
    Ads
    Advertising world
  3. #2
    80566
    Jan 2012
    Australia
    samsung galaxy 10.1
    Update - got the advice from samsung to hard reset the tab, sounds like a pretty sh!t solution to me, there must be a better way.
  4. #3
    95617
    Feb 2012
    mtp drivers
    The mtp drivers are part of the latest installation of Windoze Media Player and nothing to do with samsung.
    Install WMP11
    or
    In your windows directory
    rename C:\WINDOWS\system32\drivers\wudfrd.sys xxx_wudfrd.sys
    rename C:\WINDOWS\system32\drivers\wudfpf.sys xxx_wudfpf.sys
    rename C:\WINDOWS\system32\wudfhost.exe xxx_wudfhost.exe
    rename C:\WINDOWS\system32\wudfsvc.dll xxx_wudfsvc.dll
    rename C:\WINDOWS\system32\wudfx.dll xxx_wudfx.dll
    rename C:\WINDOWS\system32\wudfplatform.dll xxx_wudfplatform.dll
    rename C:\WINDOWS\system32\wudfcoinstaller.dll xxx_wudfcoinstaller.dll
    Then run this file UMDF.exe
    umdf.exe
  5. #4
    110702
    Apr 2012
    Spain
    Galaxy Tab 10.1 P7500
    Error with UMDF.exe
    Thanks pjclark1.
    I have the same problem but in W7. I renamed all files, but when I run UMDF.exe, the error is:
    "Setup error - Not enough storage is avaible to process this command" - "Installation did not complete".
    I tried to unzip the .exe file and replace the .dlls, but this doesn't works...
    When I conect my Galaxy Tab the error is on Samsung Mobile MTP Devices driver, code 39.
    Any idea?
    Thanks again!
    PD: Sorry if I make some mistakes writing English...
    EDITED: Thanks, I solved the problem. It was a Windows Media Player error, like pjclark1 said. I fixed it with Fix WMP utility.
  6. #5
    132239
    Jul 2012
    Solution to the problem of renaming the files
    Locate the *.sys (Where * can be any file) in C:\Windows\system32\drivers. Right click on the file, Properties > Security > Advance and select the 'Owner' tab.
    Click on 'Edit' button and mark the local Administrator and click apply.
    Close all the pop ups and you will be able to edit the file.
    Note: You need to be a local administrator. If the administrator is not present in the Security tab, you can add them once you do the above.
Ads:
  1. installation
    By cobla in forum Android Tablet Q&A
    Last Post: 01-04-2012, 02:15 PM
  2. App Installation Problems
    By KellyNinja in forum Android Tablet Q&A
    Last Post: 01-01-2012, 02:32 AM
  3. Specify The Location for app Installation
    By thamirh in forum Android Tablet Apps
    Last Post: 12-19-2011, 12:31 PM
  4. Installation Unsucessful fix
    By chezhed in forum Android Tablet Discussions
    Last Post: 05-16-2011, 08:44 PM
  5. Installation Aborted?!?
    By liquid85 in forum Nook Color Technical
    Last Post: 04-10-2011, 07:35 PM
android mtp driver for windows xp
driver mtp advan
how to solve mtp problem on samsung galaxy tab 2 10.1
installation mtp galaxy tab
mtp device code 18 for galaxt tab 2 on xp
mtp driver samsung galaxy tab 10.1
samsung mobile mtp device -- code 18
tablet mtp driver
there is a problem installing driver for samsung android
there was a problem installing android mtp
there was a problem installing this device samsung mtp
there was a problem installing this hardware samsung mobile mtp device
